Question about Cycling
What are the gears for - Cycling
    Genius:
  • 1,788 Answers
To make it easier or faster, remember it is the number of teeth that the chain is on that makes the changes. Gears closest to the bike frame are the easiest, whether it is a 7 speed or 21 speed. I hope that is what you are asking.
Posted on Oct 04, 2010
How do the gears work
Have a read and watch some videos.
  • How do Bike Gears Work? ' Design Squad - YouTube www.youtube.com/watch?v=oauDyIu_swM
    • BY DESIGN SQUAD GLOBAL
    • 3 MIN
    • 107K VIEWS
    2012-10-12 · How do Bike Gears Work? ' Design Squad ... What Is Inside A Bike Freewheel/How Does It Work? - Duration: 3:56. RJ The Bike Guy ...
  • Bicycle Gears - How Bicycles Work ' HowStuffWorks adventure.howstuffworks.com/outdoor-activities/biking/bicycle3.htm Bicycle Gears - Bicycles aren't just for kids. ... How Bicycles Work. by Marshall Brain Adventure ' Biking. Bicycle Gears. Prev Next . You have ...
  • Bike Gears: How Do They Work - Sportive Cyclist sportivecyclist.com/bike-gears-how-do-they-work Now, if you'd like to learn more about bike gears, and chainsets in particular ... Bike Gears: How Do They Work (learn what terms like '53/19? mean) ...
  • Bicycle gearing - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Bicycle_gearing Bicycle gearing is the aspect of a bicycle drivetrain that determines the relation between the cadence, ... Hub gears work using internal planetary, ...
  • How to use Bicycle Gears ' Gears on a Bike bicycleuniverse.info/eqp/gears.html How to use Bicycle Gears. ... This works because the higher gears move you farther for each spin of the pedals, making you do more "work" ...
  • Hub gear - Wikipedia, the free encyclopedia https://en.wikipedia.org/wiki/Hub_gear A hub gear, internal-gear hub, or just gear hub is a ... 1959 Elizabethan Apr. 35/1 My lightweight bike with 4-speed hub gear ...
  • Technique: How to use your gears efficiently ' Total Women ... totalwomenscycling.com/...how-to-use-your-gears-efficiently-9497 Total Women's Cycling . ... Find out how to change gears on a bike and learn to use your gears efficiently, ... Liked this guide on how to use your gears efficiently?
  • How do bicycle gears work? - Ask.com www.ask.com > ... > Biking & Cycling > Bicycles Bicycle gears work by moving the bike's chain on varying chainring and cog combinations to match the desired drive wheel speed, cadence and pedaling speed of ...
  • Apr 21, 2016 | Cycling
    Sounds like there could be gear damage in 5th gear. Isn't 5th gear a straight through arrangement? G. Nye
    All the gears inside the transmission are driven off a main gear called a cluster gear. Though the gear ratio changes as you select different gears, each "gear" you select engages several gears inside the unit to achieve the one you selected. Actually if it was possible to have a straight through arrangement, that would happen in fourth gear. Fifth is overdrive... the input actually turns slower than the output so the engine turns slower and saves fuel.
    Feb 21, 2011 | 1992 Jeep Wrangler
    94 caprice classic rear spider gears shot 12 or 16 possi what other rear ends are compatible for this 5.7 liter
    . Axle Code >>>>>>>>>>>Standard
    2YN Gear Ratio >>>>2.56<<<<< Ring Gear Diameter 8.5 Standard 2GA Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GB Gear Ratio 2.73 Ring Gear Diameter 7.6 Standard 2GH Gear Ratio 2.73 Ring Gear Diameter 8.5 Standard 2LW Gear Ratio 3.08 Ring Gear Diameter 8.5 Standard 2LR Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LY Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 2LT Gear Ratio 3.23 Ring Gear Diameter 8.5 Standard 6YF Gear Ratio 3.23 Ring Gear Diameter 8.5
    Axle Code>>>>>>>>> Limited Slip
    2LQ Gear Ratio >>>>>>>>2.93<<<<<<<<<<< Ring Gear Diameter 8.5 Limited Slip 2YG Gear Ratio 2.93 Ring Gear Diameter 8.5 Limited Slip 2LX Gear Ratio 3.08 Ring Gear Diameter 8.5 Limited Slip 2ND Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LZ Gear Ratio 3.23 Ring Gear Diameter 8.5 Limited Slip 2LS Gear Ratio 3.23 Ring Gear Diameter 8.5
    Nov 28, 2010 | 1994 Chevrolet Caprice Classic
    How do you know what ratio a subaru wrx gearbox is if it doesn't have a trans code sticker on it?
    This information is from my genuine service manual. I hope it is of help.
    Non-turbo
    Turbo
    Sedan Wagon
    Type 5-forward speeds with synchromesh and 1-reverse
    Transmission gear ratio
    1st 3.454 3.454
    2nd 2.062 1.947
    3rd 1.448 1.366
    4th 1.088 0.972
    5th 0.780 0.738
    Reverse 3.333
    Front reduction gear Final
    Type of gear Hypoid
    Gear ratio 4.111 3.900
    Rear reduction gear
    Transfer
    Type of gear Helical
    Gear ratio 1.000 1.100
    Final
    Type of gear Hypoid
    Gear ratio 4.111 3.900 3.545
    Front differential Type and number of gear Straight bevel gear (Bevel pinion: 2, Bevel gear: 2)
    Center differential Type and number of gear
    Straight bevel gear
    (Bevel pinion: 2, Bevel gear: 2 and viscous coupling)
    Transmission gear oil GL-5
    Transmission gear oil capacity 3.5 2 (3.7 US qt, 3.1 Imp qt)
    Mar 21, 2010 | 2007 Subaru Impreza WRX Sport Wagon
    What is the gear ratios on a 1990 heritage soft tail 5 speed
    Here are the stock gear ratios:
    Gear Ratio (1): 10.11
    Gear Ratio (2): 6.96
    Gear Ratio (3): 4.95
    Gear Ratio (4): 3.86
    Gear Ratio (5): 3.15
    Dec 21, 2009 | 2005 Harley Davidson FLSTC - FLSTCI...
    GEAR SHIFTING CAMRY 2004 2.4 XLI
    This might be because of the gear box problem. By any chance, did your car face flooding? In such cases, please drain the gear box and replace it with new gear fluids. Also, check if you go in low speeds, you might be able to engage it with ease. Please come back to me if you feel this doesnt solve your issue.
    Regards,
    Hari
    Aug 27, 2009 | 1998 Jeep Grand Cherokee
    1984 Honda XR250 with wrong clutch, I think.
    The kick shaft gear, idler gear, and clutch drum gear on the 1985 xr250 and below are smaller tooth gears than 1986 and newer. I have an 85 and an 88. I had to replace the 85 kick gears 3 times. The last time I replaced them I found that the larger gears on the 88 fit as long as you replace only the gears. The kick gear comes off the shaft and the larger tooth gear fits on the shaft. The larger idler gear fits where the smaller tooth idler was and the drum gear comes out and the larger tooth gear will fit there. Or the drum you have with the larger gear will now fit the other gears. This is a better solution than finding another drum with the smaller tooth gear because the smaller tooth gears will not last. I hope this helps.
    Jun 09, 2009 | 1985 Honda XR 250 R
    Need a drawing of the worm shaft and spool valve assy.
    closest I have is 94 explorer. may be similar.
    Item Part Number Description 1 3E501 Steering Gear Sector Shaft Seal 2 3524 Steering Gear Input Worm Gear and Rack 3 3647 Steering Gear Worm Ball 4 3523 Steering Gear Ball Return Guide 5 3A670 Steering Gear Worm Thrust Bearing Adjuster 6 — Locknut (Part of 3577) 7 3571 Steering Gear Worm Thrust Bearing 8 3575 Steering Gear Sector Shaft 9 3524 Steering Gear Input Worm Gear and Rack
    May 09, 2009 | 1983 Ford F 250
    Slippage in second gear,pulls fine in all other gears and shifts fine,feels like broken tooth off gear or something of that nature
    A broken gear tooth will cause a clicking sound. Start out in 2nd gear going slow. Hear any clicking? If so then TWO gears need to be replaced > the broken gear and the gear that meshes with it. If enough pressure was on a gear tooth to cause it to break, then similar pressure was on the gear it was engaged in. The gear may look okay, but it isn't. ALWAYS replace gears in sets.
    Please rate this answer. Thanks John!
    Apr 17, 2009 | 1997 kawasaki VN 800 Vulcan Classic
    Cycling Logo
    43 people viewed this question
    Top Cycling Experts
    Michial Gueffroy
    Andrew Taylor
    Andrew Taylor
    Are you a Cycling Expert? Answer questions, earn points and help others
