Question about Coleman Heating & Cooling
My coleman heater model 5440-751 electronic ignition doesnt work but it could be start with a match. How much is the part to replace ?
3 Suggested Answers
  • 306 Answers
SOURCE: cleaning
If the unit isn't too old it doesn't need a tune up. Only thing make sure you change the filter often based on how dirty it is when you change it. say you change it every 2 months and it is filthy go to 6 weeks maybe 30 days would be good. Now if you use a Air Bear filter they last 6 months they say but depends on how dirty it is. you have a flame proving device located at the last burner in line say you have 4 burners it looks like a piece of 10 gauge wire sticking down right next to the flame it does need cleaned maybe every other year with a piece of steel wool very lightly rub the sensor to take the carbon off. It only takes few strokes to clean. And do not even get close to the hot surface igniter it is very fragile and will shatter if you even bumb it.
Posted on Nov 24, 2008
  • 233 Answers
SOURCE: Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Posted on Jul 14, 2009
Need yo connect thermistat to coleman model DGAA070BDTB central air unit
Here is a list of each common terminal and what their commonly used for. Alsolisted is what colors are commonly used. NEVER ASSUME these are what youhave. Verify all your wires by following each to each piece of equipment. Thiswill help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101If you have further questions, then comment back to me...
Oct 10, 2011 | Coleman Propane Forced Air Heater...
I have a Coleman Natual gas forced air Model 7970C856 The poilet light stays on but furance burner does not kick on. What could it be?
Hello, this could be a problem with the thermocouple or gas valve. Start by replacing the thermocouple since it is very inexpensive, if that does not get it going sounds like the gas valve will need to be replaced
Oct 04, 2011 | Coleman Propane Forced Air Heater...
Read the instructions on how to light the pilot but where I need to put the match I am not sure where to direct the flame to. I see the housing for the pilot but not where inside
You noted above it is a Coleman forced air Heater with a electronic ignition? You don't need a match to light the pilot, it lights automatic on a call for heat at the thermostat.If it does not light, then you have other problems. Let me know.
Good Luck,
Shastalaker7
Nov 04, 2009 | Coleman Propane Forced Air Heater...
Jul 13, 2009 | Coleman (5040B750) Patio Heater
Coleman propane space heater
Google "Coleman" and go to "Propane Heaters" you should see a "contact us" or some such type in your problem along with when you bought the product they will be more than happy to help you.
Jan 29, 2009 | Coleman Propane Forced Air Heater...
Coleman furnace blower runs continuously
You should be seeing 120 volts to the igniter. Anything less requires either a replacement of the transformer, start relay or control module.
Dec 19, 2007 | Coleman Propane Forced Air Heater...
Heating & Cooling Logo
209 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
