Question about Consew 226R-1
Consew model 226 (NOT 226r) Need to adjust stitch length
2 Suggested Answers
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
I have used consew bls-600 industrial sewing I purchased recently. The stitch length 0-4 dial was not working and was very tight. I tried to open it. Now the reverse handle is also not working and t
Shorten your stitch in reverse the machine can't do a stitch that long in reverse. Also google your make and model machine and the word Manual so you can properly learn to use the machine safely.
Cheers,
Kelly
San Diego, CA
Embroidery Services
Nov 04, 2014 | Consew Sewing Machines
Part number for the stitch length adjustment knob
This machine doesn't use a knob, there's a button to push which engages the stitch regulator under the machine.
Jan 22, 2014 | Consew 255RB-3 Mechanical Sewing Machine
New Consew 146 rb 1-a Stitch length dial is set at
I would suggest taking the machine in to be adjusted and make sure they can work on that model machine, and if they can, then the same day you get it back, sew on it to make sure the problem is fixed.
Oct 23, 2013 | Consew 7360R-1 Mechanical Sewing Machine
I have just aquired a consew 288r-1(no manual) How do I adjust the stitch length, and tensions?
The stitch length adjustment is the same as some other Consew post models, located on the manual advance wheel
See :
http://consew.marginspluslive.com/images/products/instruction%20manuals/287RB.pdf
page 4
May 11, 2011 | Consew 288RB-1
I have a Consew 206RB and it feeds backwords. How can I fix this?
I have a Consew 206RB-1 , if I had This problem I would think the stitch length setting or the downward pressure of the upper walking foot is wrong.
If you set the stitch length to less than 0 it would be in reverse and feed backward.
Dec 02, 2010 | Consew 206RB
My stitch length is not what I have it set for. I set it on 5
I assume you mean it stitches 6 or 8 when set at 5.
Because the number shown on the wheel says "5" doesn't necessarily mean 5. It's just an approximation. You'll note that when turning the wheel there's tension. The numbers are just numbers. It isn't a micrometer, its a sewing machine. So, you can simply adjust to get the stitch you want then make a mark on the wheel at that point. You may end up between 4 and 5, or between 5 and 6. No matter. Wherever you get 5 per inch is where the adjustment is.
Aug 05, 2009 | Consew 226R-1
Jun 16, 2009 | Consew 226R-1
Consew Industrial Machine 2270 stitch length dial not working
Sounds like it is either out of time or the adjuster spring needs to be replaced.
Mar 14, 2009 | Sewing Machines
In need to know how to adjust my stiching and needle adjustment/ the bobing is jamming(not stiching)
Stitch length is adjusted by holding down the small button in the bed and turning the wheel to the desired number of stitches. The numbers are either on the wheel, next to the belt pulley, or under a small cover on top of the machine. Hold the button and turn the wheel either toward or away from you to get the stitches you want.
Bobbin jamming is either because of incorrect top tension or incorrect threading. Go to www.consew.com and get a parts and operation manual for free for a 224. It 's the same as the 226.
Mar 10, 2009 | Consew 226R-1
Consew 226R-1 Logo
217 people viewed this question
Top Consew Sewing Machines Experts
SewTechWayne
SewTechWayne
Shehu Pro
Shehu Pro
Irene Tulloch
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
