Question about Pioneer DEH-2700 CD Player
Dph-2700 why can't I get it to go into auxiliary mode
  • 20 Answers
I don't believe it has an aux input, here is info on the radio from crutchfield.
http://www.crutchfield.com/p_130DEH2700/Pioneer-DEH-2700.html?tp=5684&tab=features_and_specs
hope this helps. dave
Posted on Oct 05, 2010
Tip
No special firewall rules needed for DPH-540 and Dlink DI-604 router
My DPH-540 works fine behind a DI-604 NAT router, without any special firewall configuration on the DI-604 (I connect to either RingCentral or SIPPhone). I hope to get another SIP phone and see if both phones can work simultaneously behind the NAT router; many web sites suggest that a different proxy port must be used (the default is 5060).
on Jan 05, 2009 | D-Link DPH-540
Using D-Link DPH-50U with a softphone ie. Xlite,eyeBeam, etc
That phone looks exactly like the one I use from sjlabs.com. I have a SIP account with FWD on mine. The router should have nothing to do with it unless you are behind a corporate router with strict ACLs. The soft phone is software based. Just make sure your STUN server and SIP proxy is set up correctly. The Xlite should provide all the info needed,
Jan 29, 2009 | D-Link DPH-50U (0790069289750) Router
Can't get the D link DPH 540 TO GET A CONNECT TO WI FI
Dear Stoneway,
First create a network profile if not yet done so
Menu > Profile > Network Profile
then edit it, go to Account Choice and select "Default".
The "No SIP Account" error most likely comes from having a blank field in "Account Choice".
It's easier to set up the DPH-540 from the web admin interface, so you can try first to at least get an IP address assigned to the phone then use that IP address to access the phone from another laptop on that same wireless network. But again by the time you manage to thumb your way to get an IP address assigned, you have 3/4 of the problem already resolved so you may as well thumb in that finishing touch :-)
Viet
Jan 24, 2009 | D-Link DPH-540
2004 Ford Expedition rear floor cool/heat
Item Part Number Description 1 — Air inlet door 2 — Temperature blend door 3 — Headliner airflow 4 — Auxiliary mode door 5 — Floor airflow 6 18476 Heater core 7 19860 Evaporator core 8 19805 Blower motor
The auxiliary A/C and heating system has the following features:
  • The auxiliary A/C and heating system is functional whenever the instrument panel mounted A/C control is in any position except OFF.
  • The auxiliary blower motor recirculates the air inside the vehicle. Outside air is not available to the auxiliary system.
  • Air is cooled and dehumidified by the auxiliary A/C evaporator core only if the instrument panel mounted A/C control is adjusted to a position that requires A/C compressor operation.
  • The temperature blend door and the auxiliary mode door are controlled by electric actuator motors.
  • Movement of the auxiliary temperature control between COOL and WARM causes a corresponding movement of the temperature blend door to mix air flowing through and around the auxiliary heater core.
  • Movement of the auxiliary mode control between PANEL and FLOOR causes a corresponding movement of the auxiliary mode door to direct air flow between the panel (headliner) registers and the floor duct.
I would say the auxiliary mode door (#4) electric motor is not wokring.
Auxiliary Blend Door Actuator —Air Distribution Removal and Installation
  1. Remove the RH quarter trim panel cup holder and access panel.
  1. Remove the screws.
  1. Disconnect the blend door actuator electrical connector.
  1. To install, reverse the removal procedure.
Jan 14, 2009 | 2004 Ford Expedition
DPH-50U default audio
I had the same problem. I just reinstalled the hardware manually through the install new hardware module in XP. Once I did that, Skype "saw" the D-Link adapter.
'I went into "add new hardware" clicked "yer, hardware is already installed" then selected the D-Link device that will be listed. You have to have the driver already installed, then let the OS install the hardware as it always does and then you should see the D-Link driver as one of the choices.
This drove me crazy too. I hope this works for all of you. Good Luck.
Oct 24, 2008 | D-Link DPH-50U IP Phone
Southern Telecom Phone DPH-201 wired 13 memory phone
The manual doesn't seem to be available online, but you can contact the manufacturer directly: http://www.southerntelecom.com/contact.htm Here is a link to their product page for your phone: http://www.southerntelecom.com/products/cordeddph201-1.htm
Mar 25, 2007 | Southern Telecom DPH-201 Corded Phone...
Update the firmware of D-Link DPH-70s to support SIP protocol
this phones doesnt got support for standard SIP protocol, so its not supported by any major voip provider.
Jan 11, 2007 | D-Link IP PHONE DPH-70S WITH BUILT IN...
Pioneer DEH-2700 CD Player Logo
184 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
