Question about Uniden SMH1525DT 2-Way Radio
Need a mic end digram for a uniden smh 1525 dt vhf radio
Benimur
  • 6966 Answers
SOURCE: VHF transmit power
Hi, It is not typical but neither is there a problem with the radio. Transmit Power output is loosely dependent on the: 1. Frequency or channel you are transmitting. Normally, Marine Band VHF are calibrated for max (25 in your radio) at Ch16 or 156.800Mhz; 2. If the SWR of the antenna is not a flat 1.0, power tends to go down; 3. After some time, the TX side of the radio needs to be re-calibrated; 4. Power Supply - some radios will push max output only when powered with 13.8 and tends to go down when used with 12 volts. Hope this be of some help/idea. Post back should you need additional information. Good luck and kind regards.
Posted on Oct 04, 2007
hydetech
  • 113 Answers
SOURCE: Uniden VHF Marine DSC Series 25 Watt Radio
Typically there is an inline fuse in the power cord. It is not built into the back of the unit. If access to the back is restricted, they should have cut out the fuse and installed it near the power buss that the power cord is attached to. How was it flush mounted if you don't have access to the back of the unit? It's not possible to attach the flush mount brackets without access. It's possible that the radio is held in place using sealant. If you are sure there's no way to pull the panel, try gently prying the radio out of the hole working around the edge to break the seal.
Posted on May 10, 2008
Agent Ken
  • 250 Answers
SOURCE: Raymarine 215 DSC radio mic
Hello myrtlbch1,
For replacement microphones for the Ray 215 DSC you can contact the manufacturer via their website http://www.raymarine.com. It appears there are two different versions available, a traditional style handheld microphone and a multi-function handset style mic.
Hope this helps!
Ken
"Go Ahead. Use Us."
Posted on Jun 30, 2008
SOURCE: ANTENNA UNIDEN MYSTIC
Good News!!  I just received the email from Jessica at Uniden but when I called to place the order, I learned they are back-ordered( 550 Units) and are not scheduled to arrive until Nov 28, 2008.
So hopefully we will get them.  There is a $10 shipping charge in addition to the antenna.
L Meier
Larry,
Thank you for your inquire. I apologies for the information you may haven been given. But You are able to order the antenna for this model. They part your needing is part number BATY0461001 Cost is 27.16. This part is on back order. If the jack that the antenna screws on to is also damaged you most likely can buy this part but there are no instructions on how to install it.
To send the unit in due to the jack being the damaged part. You would be asked to box the unit up attaching a note explaining the problems your having along with a check or money order for the flat rate repair fee of 59.95. This amount includes all parts labor and return shipping. The unit will then carry a 90 day warranty.
Posted on Aug 01, 2008
vrc_tech
  • 109 Answers
SOURCE: Uniden VHF Hand held Radio HH940
There are several avenues for you. 1. do a serch on ebay for the battery. 2. try your local two-way dealer or 3. go to Unidens web site.
Pat
Posted on Aug 20, 2008
I have a uniden vhf radio that transmits but won't receive
send it for repair
Uniden - Online Repair Form - Uniden Repair Center - Uniden Americahttps://repair.uniden.com/repairInstruct.cfmRepair Procedure -Brand New Products. Marine Radios=3yr Warranty, Scanner Radios=1yr Warranty. GPS System=1yr Warranty, Digital Camera=1yr. Warranty.
uniden vhf radio Google Search
Jun 24, 2017 | Uniden Radio Communications
I have a Uniden380 Vhf radio that receives good but when I press the mic button the radio shuts down, release the button it comes back on. tried 2 different antennas,cables. Any suggestions?
have u tried a dummy load , i suspect something may shorted. i have gotten tons of uniden vhf marines wont turn on but uniden offers no schenmtic or service manual. they will repair rigs, go to web site repair enter ur model no will tell u how much to fix it. I have had several newer scanners serviced did great job. depending how old and new price to replace it would be a factor . Take care R&2WAY
Jun 07, 2017 | Radio Communications
Need a schematic for a UNIDEN HH979 VHF Marine radio.
Go direct to UNIDEN or a repair statin that services this unit
Oct 15, 2014 | Uniden Hh979 Vhf Marine Handheld Radio...
My Solara Dsc radio, which has worked well for several years, suddenly began blowingthe 2 amp fuse on the red power line whenever the transmit button was pushed on the mic. Why?
No worries here.
According to Uniden, the 6 amp fast blow fuse is the correct one.
Not entirely sure why there'd be a 2 amp with your old radio, but I suspect the radio is good.
-Steve
Uniden VHF radio fuse Google Search
Dec 04, 2013 | Uniden Solara DSC VHF Marine Radio
How do replace the face plate/mic assembly on uniden oceanus dsc
I realize this question has been around for a long while, but with the price of a new radio being so low, I can't imagine why anyone would be bothered with trying to source the part (spendy...) and try to repair the unit.
Welcome to the age of disposable electronics.
-Steve
Feb 15, 2012 | Uniden Oceanus DSC Wham ready Fixed Mount...
Where can I get a mic for my solora radio
It will be hard to find a mic for the Solara radio today. I'm using 15 of these radios and found out the radio is obsolete and that the Chinese are not making any more parts for this radio and I bought every Mic I could find because this is a good radio beside the mic. If interested you can email me at rockharbor504@yahoo.com and I would be able to let you have a mic.
Jan 18, 2011 | Uniden Solara DSC VHF Marine Radio
Can i bay a new microphone fro my uniden solara
Uniden Sells the Mic/Face assembly. Which is the faceplate with the microphone wired in.
Runs about $30.00 the part number is BMKYSOLDSC - Mic Assembly For Solara DSC
Jul 21, 2009 | Uniden Solara DSC VHF Marine Radio
I have a uniden solara and my 2 year old yanked my mic of the dash. Can I get the plastic part on the back on the mic replaced?
The modification can be found here
http://radiosyelectronica.terapad.com/index.cfm?fa=contentNews.newsDetails&newsID=19512&from=list
Apr 20, 2009 | Uniden Solara - VHF Marine 2-Way Radio
Pat
Aug 16, 2008 | Uniden HH940P Handheld, programmable...
Uniden SMH1525DT 2-Way Radio Logo
94 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
