Question about Canon PowerShot A520 Digital Camera
No power indication lens does not move - Canon PowerShot A520 Digital Camera
    Master:
  • Canon Master
  • 443 Answers
The baterys may be in bacwards
Posted on Dec 26, 2011
Blurry pictures
A common problem is a finger print on the lens. If needed, clean the lens with a microfiber lens cloth. Commonly available with spectacle cleaning kit. Did you drop it? Are you actuating the shutter by "squeezing" the button and not pushing on it, moving camera around? Try using a shaky hand setting, often indicated with a hand icon and wavy lines, indicating movement.
May 04, 2013 | Kodak EasyShare M532 Digital Camera
Lens error restart camera
  • 1. Begin by turning the power on and off 4 times. If this does not work, remove the battery with the power still on, wait about 15 seconds and replace the battery. Once you have installed the battery, turn the power on. You can plug the audio/visual cable into the camera preventing the LCD screen from powering up. This will allow for more power to be directed to extending or retracting the lens.
  • 2. Try using compressed air to clean around the lens barrel area, this may dislodge the debris that is preventing the lens from extending or retracting.
  • 3. Gently tap on the bottom of the camera while holding the camera with the lens facing the ground. Try using the palm of your hand or the rubber pad on the USB compartment. You want to dislodge any dirt or debris that is lodged within the camera.
  • 4. With the power OFF, place the camera flat on the table with the lens facing the ceiling. While holding the shutter button down turn on the power, this will cause the lens to auto focus hopefully seating the lens barrel guide pins.
NOTE: The next step is the most forceful procedure, therefore use extreme caution when performing. Remember, if a click is heard during this step then stop and check to see if the lens error has been resolved. Clicking sounds may indicate that the lens barrel guide pins have reset.
  • 5. While turning the power on GENTLY twist, pull or push the barrel while the lens is extending or retracting. You want the barrel to move in or out evenly. The idea behind this step is to overcome the friction that is caused by misalignments or dirt within the barrel.
Jun 20, 2012 | Canon PowerShot SD850 IS Digital Camera
The lensof my digicam was not move to the normal it's already steady on but not open yet
Good day,
This tip will explain a few methods on how to try and fix your lens if it is stuck or you get a lens error on your screen.
Please note that all these methods are used at the users own risk and that I can not be held responsible for any damages or losses that occur while trying these methods.
1. If your camera is still under warranty, send your camera to the manufacturer to be replaced or fixed professionally.
2. If your camera is out of warranty try these methods.
Make sure your batteries are fully charged.
Remove the batteries for 10min. Replace the batteries and see if the problem persists.
Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
If any of the methods listed above failed to work for your lens problem it would be wise to take it on to a professional to get your camera repaired.
Thanks for taking the time to read my tip and feel free to let me know if it was of any help.
You can also visit http://www.fixya.com/support/r7041378-digital_camera_lens_problems
Regards
15073327
Feb 05, 2011 | Sony Cyber-shot DSC-S750 Digital Camera
The lens of my DMC-FS20 is not moving correctly (it comes out when switched off and in when switched on) and I am unable to press shutter. A message is displayed telling me to switch off and on again, but...
Good day,
  • Make sure your batteries are fully charged.
  • Remove the batteries for 10min. Replace the batteries and see if the problem persists.
  • Try compressed air. This method can be useful if there are any sand or any other object stuck in the lens motors. Use compressed air with a fine tip. Direct the air between the camera body and lens and move in a circular motion around the lens to complete a full rotation.
  • You can also try to tap the padded USB cover firmly on a flat surface like a table. This is sometimes a surprisingly effective method.
  • The last method is to try and force the lens. Turn of your camera and place it on its back on a flat surface. Look at the spacing between the lens and the body and see if the gap is consistent all the way around the lens. If the gap is not even it is likely that the camera fell while the lens was extended. Now VERY GENTLY push down on the lens were the gap is the biggest until you her a "click". This will indicate that the lens is back in place. Try powering back on.
  • If the lens does not extend or it extend and retracts turn of the camera. Hold the camera in your one hand and with the other hand turn the one part of the lens in a circular motion. Rotate both sections of the lens until you hear a "click". This will indicate that the lens popped back in place. Power the camera back on.
  • The last method you can use is to turn the lens while powering on the camera until you hear a "click". Power the camera of and back on to see if it works.
Regards
15073327
Jan 25, 2011 | Panasonic Lumix DMC-FZ7 Digital Camera
Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX VR Vs. Nikon Nikkor 55-200mm f/4-5.6G ED IF AF-S DX are they the same len or not? thanks, Ricky at rpotter@eatel.net
No. The VR lens has 15 elements in 11 groups, the other has 13 elements in 9 groups. This indicates that the two lenses have different optical designs. The main difference, however, is that the VR indicates "vibration reduction." This lens has motion sensors and tiny motors that move the lens elements to compensate for camera motion, producing clearer pictures when hand-holding the camera.
Oct 23, 2010 | Nikon Cameras
When power ON the screen displays"Lens Error!" & lens does not open.
This error indicate that focusing ring got stuck or jammed due sand, dust, may be due to external shock caused by dropping the device.
  • You can gently bump the camera to try to free the focusing ring.
  • You can try to turn camera ON at the table (facing it to the ceiling), don't put camera down face to the floor when opening.
If motor is running but lens won't retract sometimes lens would slip off with the gear or break off a tooth in the gear when it gets dropped. Try to gently move the lens barrel around with the finger and see if it is moving, but if tooth or gear is broken lens will move onces or twice then it will stuck again.
Else your camera need to be disassembled to get at the focusing ring at Service Center.
Thanks...!!
4 thumbs rating keep us motivated to answer more free questions.
Oct 04, 2010 | Nikon Coolpix L1 Digital Camera
DVD samsung P231 does not play commerical level DVD. No picture, no sound. after loading tray, Samsung logo continues on TV screen. display on DVD says "load" then "menu" then the clock runs for a few...
I still bet that this is not a Composite Cable Problem. This is a Mechanical / Electrical Problem.
Your description is significant as it indicates a mechanical problem. The most likely suspect would be the traverse drive / mechanism. This is responsible for moving the laser / lens (carriage) to slide along and move the laser reader from the near inner area of the disc towards the outer edge. In most portable DVD players, the laser lens would be visible as well as the slot it moves along. The challenge would be effecting the repairs without fully opening the unit.
The correct solution would be to effect repairs on the disc player assembly and replace the mechanism or at least the laser lens carriage assembly. A possible workaround is to clean the traverse drive / mechanism. A can of compressed air may be used to remove accumulated dust while WD40 may be used to lubricate and all other moving parts. Use the WD40 sparingly and exercise care that the lens does not get smudge with the lubricant. The laser lens could be cleaned with Q-tips or foam swab.
If that is OK, the next could be Circuit Board. That is the one which controls all the functions.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Mar 28, 2010 | Samsung DVD-P231 DVD Player
Lens error
This is probably THE most common failure among digital cameras.
There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Feb 15, 2010 | Nikon Coolpix S210 Digital Camera
Samsung S800
Lens mechanism can be stuck. Try gently to drag or straighten it.
Feb 13, 2008 | Samsung Digimax S800 Digital Camera
Camera rapidly beeps 6 times when powered up and immediately turns off!
I HAVE SOLVED THIS!
I Totally fixed my CAMERA!
If you turn on your camera, the lens does not come out, and it just beeps then turns off, then listen to me.
You need to unscrew the outer casing and take off the metal shell.
Hold the camera in one hand, palming it, looking down at the LCD (ie the lens is pointing into your palm). This is to orient you.
If you look at the left SIDE of the camera, near the upper left corner of the LCD, you can peek through some of the windows of the black plastic casing and see 2 PLASTIC GEARS. The top one is white, the other is black. These are the gears that actually move the lens in and out. All I did was give the white gear a good jiggle with the tip of a pen and evidently it made the teeth of the gears mesh together like its supposed to and .... VOILA .... the lens came out when I powered it on and all is well! I know this is gonna help someone!
Dec 18, 2007 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot A520 Digital Camera Logo
21 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
