Question about Canon PIXMA MP530 All-In-One InkJet Printer
Mx320 faxes in memory but doesnot print - Canon PIXMA MP530 All-In-One InkJet Printer
  • 7 more comments
  • ayeletkal Oct 04, 2010
    yes its mx320
    yes it printed before, now it does not
    and its a mx320
    ok so now in fax priority mode what is the setting selection
    the choices are ring start time
    telephone ring time
    default action
    which one should it be
    once you select default setting you then have to set the reception setting , what should the correct seeting be the selectionsare
    manual/auto switch
    remote rx
    rx image reduction
    rx start speed
    rrx report
    fax reception reject
    all i get is message received in memory
    its 1 in the am here, I am in Israel, getting a solution?
    Tim
    you helped a lot, however the problem was related to the setting for
    print when out ofink y or n
    message were also coming that black in needed replacing, when I switched to print when out of ink, it printed all the faxes thanks
    stan
    TIm is great
    President:
  • 2,777 Answers
Strange, did it used to print all faxes received? Let me know and I can help you fix this and get them printed from memory. It is a Pixma MX320 correct?
Posted on Oct 04, 2010
  • 5 more comments
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    OK press the FAX button then MENU button and go through the menu there and look for the options for receive mode and anything else applicable to how it receives fax. What is receive mode set to? You should be able to change it to something normal like Fax Priority Mode...
    Thanks
    Tim
  • Tim Grayson
    I think that is the selection is it not? What are your options?
    Tim
  • Tim Grayson
    Default action... I am getting the full manual now for this unit..
  • Tim Grayson
    Ok also, when you're done with that to print from memory hit FAX then MENU then go to PRINT ALL RX DOCS, and hit OK, it will ask you to confirm, hit OK on YES and it will print them all.
    Tim
  • Tim Grayson
    That should be all you need!
  • Tim Grayson
    From the main screen keep hitting MENU until you get to USER SETTINGS. Under User Settings go to AUTO PRINT and make sure it is ON.
    This should be the issue for it storing everything
    Tim
  • Tim Grayson
    These are the only ways it will store a fax in memory:
    Conditions of the Memory Receiving
    • If the machine receives a fax under one of the following conditions, the machine will not be able to
    print the received fax and will automatically store it in its memory.
    • Ink has run out while receiving a fax.
    • Paper has run out while receiving a fax.
    • Paper other than A4, Letter, or Legal-sized papers are loaded.
    • OFF is selected for Auto Print in User Settings.
    • Using Useful Fax Functions Page 73 of 817 pages
    • You pressed the Stop button to cancel printing of a fax.
    And I've told you how to print from memory, between this post and the one about printing from memory you should be able to get it. Also the full manual is here:
    http://files.canon-europe.com/files/soft...
Cannon LBP 2900B printer doesnot printing documents but when it restarts it was printing please help me what to do
Dear
pl. try to make printer on line.
click on START-PRINTER AND FAXES-right click on printer ICON-select USE PRINTER ONLINE,make a test print, if it ok, check your anti virus lapse date or reinstall OS.
Thanks.
Feb 26, 2015 | Cannon Office Equipment & Supplies
How to fax something using a canon mx320
If you have connected the device to a phone line, to send a fax simply press the FAX button, load the documents you wish to send in the top feeder, dial the number you wish to fax them to & press either start button
Aug 22, 2014 | Canon PIXMA MX320 Color USB InkJet Printer
Hi I have Canon PIXMA MX320 Colour. How can I fax a document. Do I need to face down the document or not?
Hello!
Place the paper on the ADF (Automatic Document Feeder) with the prints facing up.
Once it is loaded, press the fax button, enter the phone number then press the start button (the black or color button)
Aug 30, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Hi my mx320 canon printer won't print as it says "printer is offline". what do i do?
Printer Spool offline:
Disconnect the USB cable, go to RUN and type in services.msc and then find print spool and right click, then choose restart.
Also:
Start-->printers and faxes-->right click on the printer-->properties-->make sure it
Jan 20, 2011 | Canon PIXMA MX320 Color USB InkJet Printer
Message saying "received in memory", what does it mean and how do I get rid of it?
It means there are pending documents in the memory of the printer awaiting to be printed. This documents could be a received fax documents or a documents failed to send.
Just press the menu button to enter fax setting: under it the appears "receive mode set"...... use the right arrow button to go to "memory referrence" then click OK button.
Use again the arrow buttons to delete documents in memory.
Oct 15, 2010 | Canon PIXMA MX320 Color USB InkJet Printer
A incorrect fax number got loaded into the memory by mistake. How do I delete it. It is a Pixma MX320 model
If you mean the fax number for your fax machine, you should be able to press the Fax button on the printer and then press the menu button, then go to settings. You should be able to change the original set-up information, including the fax number and other identifying features for your faxes.
If you mean for memory for other fax numbers, you should be able to to to the directory in the settings and edit or delete the memory settings much the same.
Sep 23, 2010 | Canon PIXMA MX310 All-In-One Printer
Canon PIXMA  MP530 All-In-One InkJet Printer Logo
1,510 people viewed this question
old marine
old marine
