Question about Craftsman Garden
I recently bought a Craftsman weed wacker 33cc full crank 4 cycle from a flea market. It came with out a spark plug and I wanted to know what kind of spark plug it takes and how to start it with a flooded tank. I believe it might be flooded from one too many presses on the choke. And if so, I would also like to know if there is a pdf or online instruction manual for this product when it comes to repairs and specifications of this piece of equipment. Lloyd M. Harper
  • 413 Answers
SOURCE: I have a 33cc 14 inch poulan chainsaw and its' flooded? Help
Check the muffler for dirt dobber nest etc. This is many times the problem with all types of engines after setting for awhile. Another is to replace the plug no matter how good it looks.
Posted on Apr 12, 2009
slohry
  • 87 Answers
SOURCE: redmax weed wacker wont stay running
Have these unit been stored with fuel in them or sitting around for a long period of time? If so the carbs may need to be overhauled. Also check for a clogged fuel filter and vacuum test the fuel lines for cracks.
Dolfoff
  • 148 Answers
SOURCE: Craftsman 4 cycle weed wacker, only runs while
Be sure fuel lines are healthy...especially any places where they bend. If you feel confident enough you can go into the carb itself and check the inlet screen which is just under the inlet needle. These are a common trouble spot.
The screen will appear to be fine at first glance, but remove it and hold it up to the light and you'll find it to be swollen completely shut!
Might as well install a kit while you're in there. It's only about 10 bucks and the amount of time and effort it costs you is the same.
NOTE: Get a "REPAIR KIT" for your carb...NOT just a diaphragm kit.
Zama carb repair kits found here.
Walbro carb repair kits found here.
Hope this helps!
Posted on Sep 29, 2009
Testimonial: "DolfOff gave a complete detailed explanation, complete with links to the parts websites if needed. Thanks!"
dontbother10
  • 2220 Answers
SOURCE: 353 husqvarna chainsaw, floods during start process
Husqvarna says the initial carburetor needle valve settings are from lightly seated 1 turn CCW for both H & L.
Your Operator's Manual can be downloaded here:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140204-95.pdf
Once flooded Huskys are very hard to start. This works well on my 359.
Start Procedure
Cold:
  1. Ignition on/off to on
  2. Set compression release – optional step even if saw is equipped with a compression release
  3. Pull (close - sets fast idle) pull starter and listen for an attempt to start. once heard (usually two pulls)
  4. Set compression release – optional step even if saw is equipped with a compression release
  5. Push (open) choke pull starter until it starts. (usually the next pull)
Warm:
  3. Pull (close - sets fast idle) choke, - Don’t pull with choke closed.
  4. Push (open - fast idle maintained) choke, pull starter until it starts. (usually first pull)
Hope this helps
Lou
Posted on Oct 03, 2009
dontbother10
  • 2220 Answers
SOURCE: I bought a second hand Craftsman 33cc chainsaw and
I was THAT close. Lou
Posted on Mar 17, 2010
What powers carburetor solenoid on a craftsman model 316.711200 weed wacker
The power source comes from the ignition module(coil), Power is stepped down internally in ignition module to something between 9v and 18v(can't remember exact voltage for sure at this time).
I don't recall seeing one on that model go bad. usually it ends up being the carburetor. Or incorrect spark plug that is the culprit(If cylinder is O.K. and you have spark).
Hope this helps.
Mar 08, 2016 | Craftsman 27cc 2 Cycle Crank Straight...
No spark
To test the spark you will need a spark plug tester. Put one end of the tester on the spark plug and the other in the plug wire. Pull the cord and see if fire is there. If not you will need to replace the coil.
Jun 28, 2014 | Craftsman 27cc 2 Cycle Crank Straight...
How to test a wweedwackers magnito
Use a spark tester and place it between the spark plug wire and the spark plug. Pull the start cord and see if there is spark to the plug. Hope this helps.
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Weed wacker wont start
You do know my neighbor took her sears craftsman edger in and got a new one after a year. TAKE IT BACK!!!!!!!!
Jun 09, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
124 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
