Question about Behringer EUROPOWER EP2500 Amplifier
Schematic behringer EUROPOWER EP2500 - Behringer EUROPOWER EP2500 Amplifier
5 Suggested Answers
fredycruger
  • 322 Answers
SOURCE: no sound
Manuals list: Brandnames starting with B - Mr Manuals - manuals and ... try this site hope it helps @/
Posted on Feb 02, 2008
  • 4234 Answers
SOURCE: the circuit breaker on my behringer europower
Yes this is repairable, but there is no "reset" switch. There is a good possibility that the output transistors have failed. This unit requires service. If you have no experience with audio amplifier repair, take this to a service shop. Expect a parts cost in the $50 range.
Dan
Posted on Aug 24, 2009
  • 5603 Answers
SOURCE: behringer pmp2000 europower no sound
Probably the power amp has arced and popped a lot of components.
When teh amps go usually the final pwer transistors, their drivers and sometimes even the power supply gets zapped.
Check the output of the preamp at the inserts for the final amp with headphones to see if anything is coming through.
Posted on Jun 25, 2010
caroldon
  • 17130 Answers
SOURCE: my behringer europower EP2500 poweramp has a bad
There is a possible noise build up on your CH2 due to failure or weakness of the LCR network of the preamp circuit. It could also be a noise within any semiconducctor or the preamp IC. Unless you can do a signal test with the elimination of the input to the output amplifier, the fault will not be say to isolate. Hence if youarre familiar do the test by approching from the output amplifier's input, proceeding to the main input where the faulty section can be identified. Hope this helps. Good day
Posted on Jul 18, 2010
Audio input line
Behringer Power Amps has the input lines on the back, it has either XLR balanced and 1/4 unbalanced inputs, now what are you trying to ask?
Oct 11, 2013 | Behringer EUROPOWER EP2500 Amplifier
I need schematic diagram
you can download if from here.
Thanks,
gylacz
Jan 13, 2013 | Behringer EUROPOWER EP2500 Amplifier
Needs service manual for EP 2500
if it is enough you can get the schematic diagram of this amplifier.
Thanks.
gylacz
Nov 25, 2012 | Behringer EUROPOWER EP2500 Amplifier
Behringer amp 240 to 120 volts
What you may need is a
Voltage converter ' Voltage Transformer ' step up and step down ...
Connect the 220V line output to EP2500
And the 110V input to your 110V convenient outlet
Aug 20, 2012 | Behringer EUROPOWER EP2500 Amplifier
My EP2500 died, the capacitors are swollen on the top in the power supply.
Unless you are a qualified audio service technician, you should refer repair of this unit to an authorized Behringer service depot. The capacitors you refer to can store lethal amounts of electrical charge. Also, Behringer service manuals and schematics are notoriously difficult to get.
Oct 07, 2010 | Behringer EUROPOWER EP2500 Amplifier
Nothing comes on on a europower ep2500 power amp
Hi...
Check fuse in the rear where AC comes in and there should be a couple of small fuses ( 20mm long ) inside the amp. CHeck those too
Mar 15, 2010 | Behringer EUROPOWER EP2500 Amplifier
Service manual
The good news is that I have access to the schematic. The bad news is that it is on paper only. Can you describe what you need? Perhaps I can provide it.
Dan
Jan 14, 2010 | Behringer EUROPOWER EP2500 Amplifier
Behringer pmp2000 europower no sound
Jan 28, 2009 | Behringer EUROPOWER EP2500 Amplifier
Behringer EUROPOWER EP2500 Amplifier Logo
182 people viewed this question
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
Michial Gueffroy
Alvan Dawkins
Alvan Dawkins
Level 1 Expert
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
