Question about Canon PowerShot SD40 Digital Camera
My camera shows an error that says: error restart camera object. I can do?
    Brigadier General:
  • 3,006 Answers
Your camera most likely has a lens error, this is such a common fault that I hope you don't mind me pasting my stock generic answer below. No point in reinventing the wheel!
Stuck lenses are probably the most common reason that compact digital cameras get thrown away, but there's a fair chance of recovering use of your camera again
The fault is commonly caused by dirt or grit blocking the mechanism, or due to it having suffered a recent fall. Another common cause is that the camera was in a pocket or bag and the power button accidentally activated and tried to open the lens against resistance. The mechanism may have simply become dislodged or there may be parts which have broken.
If your camera is still under warranty and has definitely not been subject to misuse then contact the Canon service department in your country to find out about a free repair. If the warranty has expired though a professional repair will far exceed the cost of replacing your camera. You will therefore have nothing to lose by trying to fix this yourself.
Please click here and you will be taken to an excellent article provided by the Camera Repair website. For the most part, you'll be guided on how to physically manipulate your camera to try and clear the fault. Although the article mentions Canon a few times, the advice applies equally to all cameras with lens errors and is not model-specific.
If the link doesn't work then cut and paste the following address into your browser:-
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Good luck, I hope you manage to use this information to fix your camera. Please take a moment to rate the free answer I have provided for you and any testimonial which you might wish to add is always welcome!
Posted on Oct 04, 2010
Hi there. A mystery error shows the Display of my Finepix S2 pro. Its like that: "o - -" or "o _ _" in the upper Display. Has anyone an idea for that? Best regards, Harry
Try resetting the camera by removing the battery for 15 mins. Replace the battery then go to the camera's Menu and scroll through the settings to set the Date and Time.
Apr 18, 2013 | Fuji FinePix S2 Pro Digital Camera
Panasonic BL -C30 netcam: unable to send e-mail after being triggered by sensor. error log shows: division 4/code 1
Hi.
Try resetting the camera.
Some of the cameras have a small recessed button on the bottom that can be hit by using a small pointed object (such as a paperclip or pen). Other models have a flap on the side that has a reset and a restart button.
If that does not apply try disconnecting power (and removing battery) from all units connected to the system, including main control unit.
Aug 13, 2010 | Panasonic BL-C30A Network Camera
My Nikon Coolpix S60 makes a ticking noise when first turned on. It shows my home screen, but continues to make the noise and then later shows a "lens error" warning on the screen. I have cleaned my...
there is a worm gear on the motor shaft which is running when you turn camera on but the gear around lens is out of timing so it doesnt move...and it shows error you need to show it to tech to get timing adjusted.
Dec 16, 2009 | Nikon COOLPIX S60 Digital Camera
Lens error, restart camera
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Dec 11, 2009 | Canon PowerShot SX100 IS Digital Camera
PowerShot SD630 lens stuck out, says lens error, restart camera
This is probably THE single most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 20, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
I caoldnot find restart botom on camera
when i am goning to start the camera, it is show this alarm "lens error, restart camera", but i couldnot find restart bottom?
please help meeeeee
Jan 01, 2009 | Canon PowerShot SX100 IS Digital Camera
Error in lens Restart camera
error with cannon powershot sd100, lcd is black,. how do you reset the camera.
Aug 25, 2008 | Canon PowerShot SD100 / IXUS II Digital...
My new Canon SX100IS is having "Lens error, Restart Camera" error
It seems the lens assembly has an internal problem and needs to be repaired.
The lens replacement requires a qualified camera repair technician, unless you want to try in repair it yourself, which requires tools (scredrivers, soldering iron, desoldering tool, magnifier glass with light, etc).
The reason of it it may be a spring or a metal post located in the focus sub-assembly, but the only way to confirm it is opening the camera and the lens assembly.
Best regards,
Jul 25, 2008 | Canon IXUS V2 Digital Camera
Canon PowerShot SD40 Digital Camera Logo
99 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
