Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Every time we start washer f1 comes up and shuts down machine
  • 2,382 Answers
Hi..
Keypad/User Interface Failure
A fault code of "F" then "1" flashes when there is a primary control failure.
You will need to replace the machine/motor control assembly.
Page 14 and 16, in the manual link below will help you with this.
HE Top Load Washers
Models:
F1 Error Code
WTW6200S WTW6300S WTW6400S WTW6600S WTW6700T
MTW6300T MTW6400T MTW6500T MTW6600T MTW6700T
Serial Numbers: CT01 - CU52
There are four areas of concern that can cause the F1 Error Code. Each area must be sequentially addressed to ensure
that the diagnosis is correct and the proper repair is completed.
A) Air leaks in the air pressure (switch/sensor) hose.
a. Inspect the hose for cracks, pin-holes or loose connection.
b. Replace the hose and harness assembly (W10058730) if it is compromised.
B) Moisture in the air pressure (switch/sensor) hose.
a. Inspect the hose for evidence of water.
b. Replace the hose and harness assembly (W10058730) if water is detected.
C) Lint or flashing in the air dome hose connection port.
a. Inspect the air dome hose connection port for lint or flashing.
b. Use a small round device (small screwdriver) to ensure that there is nothing blocking the air dome outlet on
the tub.
D) The control needs to be replaced.
a. Replace the control only after you have completed steps A - C above, and verified that there are no issues
with the air pressure system.
Posted on Oct 05, 2010
Kenmore elite washing machineshuts off and shows
with an f1 code most likely youd have to replace the control board f1 is also know as the code of death 99% of the time it is the main control board
Apr 07, 2010 | Kenmore Elite 45986 Front Load Washer
F1 code coming up on my Oasis HE washer
YES! Serious problem...more annoying than anything else. Wait until your machine stops at the spin cycle and displays "F1" again. We just had a repair tech out today and received a quote of $384+ to fix/replace the circuit board. Kenmore & Sears are fully aware of this problem and have issued a recall on a model that is one digit off of the model I have yet they will not do anything about this even though it is the same problem. These machines are huge dogs!
Jan 15, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE shuts off during wash cycle and gives F1 error
F1 error means the main control computer board. see other posts in this section as there are many who are complaining about the same problem. buying the new board (revised) will solve the F1 problem, but other problems will soon crop up on this POS washer. if you have the chance to return it to sears, return it immediately!!!!
Mar 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
F1 error code on cabrio washer
CALL 18002531301 AND TELL THEM YOU HAVE THE F 1 CODE PROBLEM. THEY HAVEN'T CALLED THIS A RECALL, BUT THEY ARE CALLING IT A CUSTOMER AWARENESS PROBLEM.
WHIRLPOOL IS SENDING TECHNICIANS OUT NEXT DAY FREE OF CHARGE.
T W
Feb 02, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio top loader,always having to "reset" 2 times 1 cy
Hi Curtis: File a class-action suit against the Whirlpool company. There is something wrong with the electronic module that tells the washer to shut down during the rinse cycle.
If you pause, lift the lid, pour in about 3 gallons of water into the tub, close the lid, push start, the washer should continue without having to wear out your fingers pushing the buttons. The buttons will eventually be pushed down into the control panel and you will have to use a pencil to reach them.
Also helps to have a nice cool bottle of regular beer (not the light stuff) before you start the load, the washing duty will work out much smoother. Good Luck.
Dec 29, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Washer stops with an F1 Code during rinse cycles.
Well I have the same problem the only way I have found that my washer works is that on the soiler level make sure you put that on the heavy. And that should work I know its a pain but thats what I do and my washer washs with out stopping
Dec 04, 2008 | Whirlpool Cabrio WTW6600SBT Top Load...
Kenmore Elite Oasis HE/ Error Code F1
repl/ main control board reason for error code F 1 ,,,nothing else
Nov 08, 2008 | Kenmore Elite HE4 Electric Dryer
LG washer comes on then shuts off
I need a little more info, does it make any sounds b4 it shuts off is there any codes F1 or anything like that. Does the water start to fill? Does it start to rotate or anything at all b4 it shuts off?
Oct 27, 2008 | LG WM-2277HW Front Load Washer
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
