Question about Raymarine Computers & Internet
Anyone know the proper order for the 8 wires in a hitachi network cable to match a raymarine network plug?
    Brigadier General:
  • 10,406 Answers
If your network-cable has "male" connectors at both ends, and the order of the wires is the same at both ends, i.e., a "straight-through" cable, then the network-cable will work fine.
Posted on Oct 04, 2010
Wiring connection diagram
Sorry but i do not know of any tv that uses ground wires,
if you mean rca cables these have coloured plugs either red,white and yellow or red blue and green,if you look into the sockets on the back of the tv you will see the matching colours
Sep 03, 2014 | SEIKI Digital SE322FS 32" LED TV 1366x768,...
How to hookup RL70CRC to boat wired for C70
There are 5 wires running out of the antenna and the 5 wires that you need to connect.
Oct 30, 2008 | Raymarine Computers & Internet
Tip
How to Crimping Network Cables
Tools and Materials You Will Need
Crimper with RJ-45 die.
Wire stripper
Wire cutter
RJ-45 plugs
Cat-5 UTP cable
Optional Tools
Wire Tester
Procedure
1. Strip off insulation
2. Untangle wires
3. Place wires in correct order &
straighten.
4. Trim wires to desired length.
Note:
If the wires are too long the plug will not
crimp onto the insulation for strength.
5. Slide wires all the way into the plug.
Make sure not to disrupt the color
scheme.
6. Crimp plug.
7. Repeat steps 1-6 for the other end.
8. Test wire using optional test equipment
or between working computer and hub
for patch (straight through) cables ,or
between switches for crossover cables.
Wire Color Scheme
Pin Color Diagram
1. Orange / White
2. Orange
3. Green / White
4. Blue
5. Blue / White
6. Green
7. Brown / White
Patch Cable
(Straight Through)
Both ends follow this
format.
8. Brown
Pin Color Diagram
1. Green / White
2. Green
3. Orange / White
4. Blue
5. Blue / White
6. Orange
7. Brown / White
Crossover Cable
One end as a patch cable
and the other as follows
8. Brown
on Dec 08, 2009 | Computers & Internet
Need a replacement cable for ray 230
Hi
For your 230, you need part number R49085 which should be able to be ordered by any Raymarine dealer. On the link below, scroll down to post #8.
Hope this helps you out.
-Steve
Ray 240 VHF how to obtain new cord
Feb 20, 2014 | Raymarine Ray54 Vhf Marine Radio Dark Grey
I would like to know the firing order of my 1995 chevy 3500 so I can change the spark plugs and cables
I could look it up for you, but it doesn't really matter.
The easiest way when replacing plugs and wires is to replace each wire and plug one by one. You can then make sure they are all routed correctly and held in by the proper clips. Make sure you match the length of the old wire to the new wire so everything lays correctly.
Dec 07, 2010 | Chevrolet 3500 Cars & Trucks
Connect an raymarine E120 Display to the RNS software in a PC
Try a cross over network cable from the PC to the E-Series. Raymarine Made each one of their cables as a straight cable so you would need to buy the cross over coupler or network switch box to use it with another unit. It's nothing different from normal networking with the exception that they have removed wires 4,5,7 & 8 from the cable and it's a straight. Give that a try.
Mar 21, 2010 | Raymarine E120 Multifunction GPS Receiver
I need to wire a network cable into a wall plate purchased at home depot. the plug is not rj45 but a block with 8 screws and different colored wires. the problem is the colors don't match cat5e wire.any...
I have tried this, and my suggestion is to go back and get the proper wall jack. How much are headaches worth to you? If they are worth more than the wall plate, just **** it up and get the correct one.
Jan 05, 2010 | Cat5e Computers & Internet
Changed heads due h/gasket ,tried to start engine however started but bad misfiring shaking etc checked leads now what ?
Hello; Sounds like firing order is incorrect. Recheck plug wires for proper cylinder match. The firing order is usually casted on the intake manifold.. Let me know, ok?
Six cylinders :153624
v-8 18436572,- 1546278 etc.
4 cyl -1342
GOOD LUCK
May 06, 2009 | 1996 Land Rover Range Rover
Which wires to connect when connecting a marine antenna to a raycraft gps
Hi. I have G series Raymarine and I listen the noise when swtich on I am not shure , may be from the ventilation (the fan).
I not find troubleshooting to G raymarine, I hope find the soulatoin thanks.
regard
kareem
Aug 03, 2008 | Raymarine RL70CRC GPS Receiver
Computers & Internet Logo
69 people viewed this question
Top Raymarine Computers & Internet Experts
David Payne
David Payne
Are you a Raymarine Computer and Internet Expert? Answer questions, earn points and help others
