Question about Sony MDR-RF970RK Headphones
Can these be hooked up so you can hear the tv external speakers as well?
Hello I have a question that may seem simple to audio experts but i am stumped. I recently bought my grandfather the MDR-RF970RK from best buy. The outcome I wanted was to be able to watch tv with its external speakers and allow my hearing impaired grandfather to listen via the headphones. I can not find a way to hook these up without turning off the speakers. If anyone out there can help me I'd greatly appreciate it.
I have the headset running through an amplifier so my wife can listen at her volume level and I can adjust the headset volume for myself. The volume dial on the amp is set to zero; but the audio output jacks still provide plenty of volume to the headset. You can get a reasonable amplified for $100 or less
Posted on Aug 08, 2008
NO SOUND ON MY TV
check the simple things:
Does set have sound when a DVD etc. is connected via the audio/video jacks?
If using a box check to see volume not turned way down there (unplug box and after a short wait plug it back to let it reboot).
check in main menu that Speakers are not switched OFF.
If set has hook ups for external speakers--is set turned to Internal or External?
if no to all the above you have a audio circuit problem
May 16, 2012 | Televison & Video
How do i hook up a rca Rtd325w dvd home theater to a coby tft lcd flatscreen
You can use either the multi pin connector cable, or plug the white, yellow and red cables to the TV set at the DVD player input or "Video 1" and the the audio output of the TV Another red and white set of RCA cables into the audio input of the home theater. This way the TV can play through the home theater system when you are watching cable or over the air.
If you do not want to hear the TV audio, you should go to the audio properties and select "external speaker system" but if you do this the home theater system must be on to hear any audio from the set until you set it back to the TV speakers through the TV's setup menus again.
Apr 03, 2012 | RCA Audio Players & Recorders
I just sold my surround sound system and now I can't get the on board speakers to work.
Just check the rear of the television if by chance you have left any cable still connected to the audio output jack. If there the TV might be trying to redirect the audio to an external device not present. Sometimes it could also be a simple setting to be changed , . Check if you have a switch at the back of the TV stating External or Internal speakers. From the manual i got
A/V Receiver: The TV can detect audio connections on the DIGITAL AUDIO OUT jack and the right (red) analog AVR AUDIO OUTPUT jack.
Note for Analog A/V Receivers: When you disconnect an analog A/V receiver, manually change the Speakers setting to TV to hear sound from the TV speakers.
Press Menu on the remote-> Goto AV
Select Audio by pressing the right key
Under that the first option of Speakers -> select and set to TV.
Only then will the TV speakers play the audio.
Hope this Helps.
Mar 04, 2011 | Mitsubishi Televison & Video
I have lost all sound on my tv. You can hear snapping or popping but the sound is real faint on highest setting.
I am sorry to hear about your misfortune. Unless you changed some sound settings right before that happened then the likely cause is that your tv's internal speakers have blown. Which will cause that really faint sound even when the volume is all the way up.
If your TV has an audio out connection you can try hooking it up to surround sound or a receiver with some speakers. You may be able to use your tv this way and get sound.
Otherwise you will have to make use of your warranty if the TV is still covered. If not then there is nothing more I can suggest. Repair cost might be more than hooking it up to an external sound system.
Post back if you have any further questions or comments.Thank you for choosing Fixya.
-Daniel
Oct 17, 2010 | Televison & Video
I can't hear my tv speakers
If you are connecting your computer to your TV via the PC cable to look at the internet on your screen - you will also need to hook up an alternate audio cable from your computer to either external speakers or an audio receiver in order to hear sound - a PC cable only carries video from the computer to the television, no audio.
Apr 14, 2009 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Hooking up external speaskers to my Panasonic TV
you will need to buy a surround sound receiver. the new tv's do not have an external speaker jacks on them. you might also try a old stereo receiver hooked up to the tv's audio out jacks
Jan 24, 2009 | Panasonic 50" 720p Flat-Panel Plasma HDTV
Want to add an external speaker to TV
If you have audio out RCA jacks then you can hook up some computer speakers that have RCA jack inputs. If you don't have audio outputs and your TV has a HOT chassis then you won't be able to do it. If your tv has a switching power supply then you can install a jack to TV speakers, so they disconect when you hook up your other speakers, if you try and hook up speaker to the TV speakers then the impedence will change, and your audio output IC will get hot and short out.
Oct 26, 2008 | Televison & Video
Distorted audio
Audio amps on original set are fubar.
Jun 20, 2017 | RCA F36695BC 36" TV
Help
few tv sets have extra head phone volume option but many has either way, I mean if you put head phone, speakers will be off.
I dont know the model n make of your tv set.
May 27, 2008 | Sony MDR-RF970RK Headphones
Magnavox projection tv hookup to external speakers
The external (audio out) connectors are intended for use with an external amp, not direct speaker connection.
Sep 02, 2017 | Televison & Video
Sony MDR-RF970RK Headphones Logo
513 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
