Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
I need parts . where can i get a speed potentiometer?
  • 692 Answers
Isluna contact Electric Mobility @ 1-800-257-7955 ask for tech support and explain what you need. They should be able to help you Hope this helps
Posted on Oct 05, 2010
I need to get to the speed control to find a broken cord. I can get the appliance apart but cant get the speed control out.
A broken part ? or is only the potentiometer of the speed control thats damaged, but a wire that is broken ? without any force is hard to believe the spring element internally that moves along the carbon track of the potentiometer inbetween the speed control should have lost the contact pressure or only dirthy ?. where the resist for rpm mixing is lost. maybe marketing technical made to order it as a one-part assembly try contactspray in the potentiometer.
Aug 11, 2016 | Sunbeam Food Mixers
What causes a false reading 3 beeps-1 for throttle no good.But if i try the throttle on another pride machine it works perfectly
You may have a bad speed pot. The speed potentiometer is wired in series with the throttle potentiometer. Try testing the speed pot by testing the resistance or simply shorting across it to test. I usually replace both parts for a complete failsafe repair. Hope this helps.
May 15, 2016 | Pride Health & Beauty
Error 22-23-26
Precor Error Code 23
Error Code: 23 Manufacturer: Precor
Model: All Models
Error Description: Error 23, Motor Pulses Missing after Start Up - Indication that the speed sensor signal was lost while the unit was in operation. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Incorrect gap between the speed sensor and the speed sensor target.
  3. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  4. Intermittent connection of speed sensor or drive motor wiring.
  5. Badly worn drive motor brushes not able to make proper contact with drive motor commutator.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  3. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  4. Test all wiring and wire connections of the speed sensor and drive motor. Replace or repair necessary wire connections or wiring.
  5. Inspect and replace drive motor brushes if necessary.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Precor Error Code 22
Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
Recommended Action:
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
Precor Error Code 26 Error Code: 26 Manufacturer: Precor
Model: All Models
Error Description: Error 26, Motor Pulse Width Incorrect - Observation of the speed sensor signal and verification the signal from the speed sensor is appropriate for the requested speed. If an incorrect or erratic speed sensor signal is detected the error appears. Possible Reason:
  4. Damaged speed sensor target.
Recommended Action:
  4. Inspect the speed sensor target for any scratches or tears that could cause incorrect readings. Replace the speed sensor target if necessary.
Precor Error Code 22 Precor Error Code 23 Precor Error Code 26
May 13, 2014 | Precor C964 Treadmill
9.31 precor error 26 and loud noise
Model: All Models
Recommended Action:
Jan 25, 2014 | Dmm Vision Fitness T9500 Treadmill
Error messages ellipticals
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Recommended Action:
Jan 04, 2014 | Precor 546 Efx Elliptical, Upper Display...
Precor treadmill err26
Model: All Models
Recommended Action:
Dec 16, 2013 | Exercise & Fitness
Precor 9.45 err 26
Model: All Models
Recommended Action:
Feb 04, 2013 | Precor Exercise & Fitness
Precor Treadmill 9.21si Error Code 26, what does it mean
Model: All Models
Recommended Action:
Sep 07, 2012 | Precor Treadmill 9.21 9.21s 9.25 9.21si...
Speed error 26
Model: All Models
Recommended Action:
May 18, 2011 | Precor 923 LowImpact Treadmill
What does Err26 mean?
Model: All Models
Recommended Action:
Jan 20, 2011 | Precor C956 Treadmill with Cardio Theater...
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
77 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
