Question about Admiral Washing Machines
I have a LNC6747A71 clothes washer. It is leaking very badly from underneath the machine. I was a small leak at first, but is getting progressively worse with time
  • 2,272 Answers
A common way to access the washer workings is here. Remove the screws at the bottom of the front panel, pull the bottom of the panel out to release it from the top. Remove two screws just inside the top front of the top panel and the top will tilt back. Many times a leak can be traced to the pump, the pump is a common trouble maker. Center seals ( middle under outer tank ) is another common trouble maker. See how to take apart.
sometimes the belt does not slip correctly and the inner basket spins too quickly and some of the water is thrown up and over the tank cover. Many times a new belt and idler pulley is required to correct this, motor pulley is cleaned and the tank cover cover gasket is sometimes needed to be replaced.
Some leaks can be traced to a bad tub seal.... Center seal replacement repair aid. for the 356P3 seal kit.
There is a sediment tube on the wash basket. This sediment tube becomes brittle over the years and can break. This will cause water leakage into the outer tub during the wash mode. Since the pump is turning all the time the washer is running, the water will be pumped out too soon. The tube can also become loose and clang around during the spin mode causing a noise problem.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 04, 2010
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Washing machine leaking underneath
might simply be a small hole in the outlet drainage hose, this would explain why your machine leaks during the final spin, there is more pressure from the water inside the hose during the final spin than when the machine is draining. hope this helps.
Nov 11, 2013 | Hoover Washing Machines
Water leaks from underneath my top load washer
Could be pump with motor.I replace on mine,had water under.
Apr 12, 2013 | Washing Machines
My whirlpool duet front loader is leaking water? Not sure from where cause I havn't caught it in the act. But when I go in to get the clothes I have a puddle right under the front door. Cant tell if is is...
empty the washer. then remove the bottom panel of the machine.put some water in it and see if the water is leaking when it is filling or full.I have seen a small hole in the tub just behind the bottom counter balance where the mounting bolt goes you may need to use a small mirror to look under there.f94b104.jpg
Jun 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from bottom
Hello there:
If the washer leaks all the time, check these: Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate. Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician. Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it. Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub-
Apr 18, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire front load washer GLTF1240AS0 - noisy and leaves dirt/oil on clothes in dotted pattern (so dirt being put on thru drum at final spin?). Could it be oil leak? bearing?
good call.....
your bearing is leaking into the machine
you can verify this by simply removing the back
if the side walls are covered in ablack spray pattern
sometimes it does not leak on both sides (in and out) but if it is leaking your machine will get progressive louder in both aggitate and spin
Oct 09, 2009 | Frigidaire GLTR1670A Front Load Washer
Standing waterin the door opening seal after each load.
Sometimes small pieces of clothing get into drain system and plug off draing. Check before pump for clog.
Oct 02, 2009 | LG WM-2277HW Front Load Washer
Cold water hose or seal leak inside machine leaks into basin
Replace the water inlet valve. That is where the hoses connect.
Here is a link to show you how to access the inside of the washer..
Mar 20, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer leaking water from bottom
looks like you have to replace the RUBBER SEAL thats inside the tub at the center post , try this , remove the panel so you can see inside , put the washer to fill w/ water , and watch closely underneath the tub wheres the transmision is connected , and watch for LEAKS . hope this info helps
Apr 22, 2008 | GE WBSR3140DW Top Load Washer
Washer leaking
bestsy, your pump could be weeping. Sometimes they will develope a small leak and sometimes they let loose. They are easy to change, 2 clips and 2 clamps. Check out the photo, other things to check would be the hoses at the fill valve and the drain hose. Sometimes overloading will cause an oversplash. Catriver..post back.
Mar 21, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
46 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
