Question about Canon PowerShot SD600 Digital Camera
I have a 4GB PMY Optima memory card and my camera keeps advising of a memory card error. It says that the memory card is locked. Please advise. Thanks!
    Brigadier General:
  • 3,006 Answers
Your problem is that you have purchased an incompatible memory card and it's confusing your camera as it is unable to read it correctly.
You have a 4GB SDHC card, but your camera can only use the earlier specification SD cards up to a maximum capacity of 2GB. SDHC cards will fit in the slot, but your camera cannot use them and cannot be updated to use them; the limitation is one of hardware so there is no way to update it via revised firmware.
You have just two ways to fix this: use a 2GB SD card up to 2GB maximum, or change your camera to a later model which is SDHC compliant. Note that SDHC compliant devices can use both SD and SDHC cards without any problem.
I hope that you have found my reply to be comprehensive, informative and useful and that you now have a solution to your problem. Please take a moment to rate my answer.
Posted on Oct 04, 2010
  • Canon Master
  • 5,125 Answers
Take the card out of the camera and look for a tiny switch on the side. Move it down or up (depending on which way it moves). This write protect lever is very easy to shift on some memory cards. So put it back in the camera carefully.
I hope this helps.
(You could also check it in a computer with an appropriate card reader)
How to unlocked pny optima sd memory card 4gb
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Oct 28, 2011 | PNY 4GB Secure Digital High Capacity...
I have a PNY optima sd 4gb memory card and it tells me on my samsung camera card locked. What does this mean? and how do i unlock it?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Dec 11, 2010 | PNY Optima Pro 2GB Secure Digital Memory...
I have not been able to format SanDisk SDHC 4GB Memory Card on my Kodak Easyshare Digital Camera C530. I am regularly getting the message "FILESYS ERROR e00100. The Memory card is authintic & NOT...
The C530 uses MMC and SD cards. While SDHC cards will fit into the slot, they are electronically incompatible and will not work. You need to use MMC or SD cards, 2GB and smaller.
Nov 01, 2010 | Kodak EasyShare C315 Digital Camera
I inserted a new 4gb sandisk memory card and get a "card error" message with a "00001" in top right corner of display. any advise? thanks.
The 5022 is specified to work with SD cards. Your 4GB card is actually an SDHC card. While it will fit into the slot, it is electronically incompatible and will not work in the 5022. You need to use SD cards, 2GB and smaller.
Oct 11, 2010 | Vivitar ViviCam 5022 Digital Camera
PNY optima SD HC 4GB card will not read
Try putting a tiny piece of scotch tape over the lock slider. See if that works.
Dec 29, 2009 | PNY 4GB Secure Digital High Capacity...
Loaded new memory card, and screen reads memory card error-memory card locked. Removed new card from camera, nnlocked card, inserted card again, but received same message. Please advise.
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Dec 25, 2009 | Canon Cameras
Memory card locked
try to slide up the notch on the memory card...its on the lefthand upper part of the memory card...
Jan 01, 2008 | Samsung Digimax S500 Digital Camera
Card Error on a 4GB SDHC Sandisk Memory Card
I went onto the BestBuys site and found a link for compatible memory cards - The SanDisk SDHC isn't compatible with the Canon Poswershot SD750!! Only a 2GB card will work. The Lexar SD and the Kingston Technology 2GB will.
Dec 19, 2007 | SanDisk 4GB Secure Digital High Capacity...
Canon PowerShot SD600 Digital Camera Logo
165 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
