Question about Compaq EVO D510 CMT P4 2.5/20GB/256MB (268899999) PC Desktop
Cuando enciendo mi compaq da tres pitidos y el monitor no enciende
2 Suggested Answers
bronk50
  • 27725 Answers
SOURCE: compaq evo no enciende
google translated
Compaq Evo will not start
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty
http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm
One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive power and data cables IDE SATA
the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty
computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error
even something as small as a faulty electrical or fan lead can cause you problems
motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail
check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in
check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat
Thermal compound is a sticky paste that is placed directly onto the CPU.
Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink.
hope this helps
Posted on Oct 18, 2012
Mi receptor optimus cuando enciende aparece power off y se apaga en pocos segundos
tengo un problema con mi stav-3770 y cuando lo enciendo me dice power off que debo hacer en ese caso ??
Jan 08, 2013 | Optimus STAV-3770 Receiver
No funciona bien mi computadora de mesa
Primero verifique para ver si puede arrancar en modo seguro presionando F8 varias veces justo cuando se inicia el equipo hasta que el menu de inicio aparece. Cuando el menu de inicio aparece seleccionar "modo seguro con funciones de red". Si puede arrancar todo el camino hasta en el modo seguro, entonces usted tiene un problema de controladores. Lo mas probable es que usted tendra que instalar la tarjeta de video o los controladores del chipset de modo seguro.
Buena suerte!
Jun 11, 2012 | HP Computers & Internet
Buenas, Enciendo el ordenador y aunque el led esta encendido y se abre la tapa del CD no se oye el disipador ni se muestra nada en pantalla
Buenos Dias,
Cuando enciendes el ordenador es normal que la tapa del CD se encienda. Ahora trata de nuevo de encender la netbook pero con el cargador conectado. Cuando conectes el cargador deja trata de encender de nuevo la netbook hasta que se enciendan varias de las luces. Y espera a que cargue el Sistema Operativo.
Jun 26, 2011 | Compaq Evo N800c Notebook
Falla me da pitido y no enciende Ayuda cual sera el problema
Hola,
Si son como tres pitidos, necesitas reemplazar la memoria
Nov 16, 2010 | Biostar MCP6P-M2 Motherboard - v6.0,...
Cuando enciendo mi tv no da imagen solo parpadea una luz de lamp y se apaga de nuevo lo hace tres veces y se desconecta el solo
usted nesecita una lampara nueva le recomiendo que habla a samsung , ya que biene toda la lampara comple i con isntrucciones como reemplazar la lampara
Sep 03, 2010 | Samsung HLP4674W 46" Rear Projection HDTV
No prende
Fito: Cuando la TV se apague, presiona los botones "Input" y "Menu" al mismo tiempo mas o menos por 8 segundos, el led comenzara a flashear, luego mostrara un codigo de error, cuando tengas el codigo, lo posteas de neuvo para revisarlo.
Jul 05, 2010 | Mitsubishi VS-50607 50" Rear Projection...
92 plymouth voyager 3.0 v6 plug order
cuando esta fria enciende un ratito y luego la apago y la vuelvo a encender se apaga, lo mismo pasa todas veces que la enciendo solo queda encendida si dejo mi pie en el acelerador lo quito y se apaga ese es el problema,es una plymouth voyager 1992 3.0
Jun 28, 2010 | 1992 Plymouth Voyager
Computers & Internet Logo
208 people viewed this question
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
