Question about Kenmore 16079 Built-in Dishwasher
Status Lights Blinking
The Air Dry , Washing, Drying, Sanitized, Cleaned, and 6 hr. Delay lights are blinking. Occasionally the drain pump will engage but then stops. Cannot get washer to complete a cycle or reset. Any ideas why the status lights are blinking?
  • 1 more comment
  • Anonymous May 27, 2008
    Our Kenmore dishwasher keeps "locking" and then when we unlock it it will not allow us to choose an option like normal wash, china wash, or any other options.
    Any ideas on why or what to do?
  • tuna60 Aug 05, 2008
    I have followed the manual pamplet instructions without resolution;
    I have cleaned the soap dispensers and rearranged the dishes;
    I have pushed every buttom on the sensor pad without resolution; HELP!!!
    mwg4@verizon.net
  • brett92703 Mar 01, 2009
    Sanitized light on front panel blinking after wash cycle is complete. Utensils and plastic containers still soiled. Pots and pans have white spots. Please help.
    Genius:
  • 1,122 Answers
Status lights blinking is trying to tell you something in the dishwasher is bad,go to your owners manual to see the fault codes first,then you can try turning the breaker off 30 seconds an on to see if it resets its self,if that does not work i think you might have a bad mother board,thanks-mike
Posted on May 28, 2008
Frigidaire FFBD2406NW0A then clean wash drying and 4 hour led lights are blinking
I appreciate your post, friend!
I understand that the clean, wash, and dry buttons on your Frigidaire dishwasher are blinking along with the four LED light. This appears to be a delay start cycle. I would recommend pressing the cancel button. If that does not clear the lights you can perform a reset and to do that you would need to disconnect power from the dishwasher for roughly ten minutes. I hope this is helpful. -Matt
Feb 20, 2015 | Frigidaire Dishwashers
Kenmore HE2 flashing lights
did the technician point out wat needs to be repaired
Aug 24, 2008 | Kenmore 46462 Front Load Washer
Blinking "Normal" light on a Maytag model
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Daniel
May 19, 2011 | Maytag Dishwasher
On my GU2400xtp, the green light over normal is blinking. pushing any function only changess the delay time from 1 thru 9. In order to get the delay time to illuminate, the power must be shut off and...
Try to do a reset of dishwasher. For your model it may require pressing the 2 keys in sequence within 6-8 secs. - HiTemp/ Heat Dry/ Hi Temp/ Heat Dry/ Hi Temp/ Heat Dry. All lights should light up and then press Cancel.
If nothing happens it is likely the thermal fuse has blown. See item 6 in this diagram. You could try and open the control panel and test the part with a multimeter.
You may need a special Torx head screw driver to open the screws holding the panel cover.
Hope this is helps.
Jan 28, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
My FP WA75T65GW1 7.5kg which I bought 6/7/10 is stopping at the spin dry stage
is there any status lights blinking indicating an error code ... open top console and remove tech sheet each indicator light blinking has a numerical value add each indiacator light together per tech shheet and that will give a total number and read error code
Jan 24, 2011 | Fisher and Paykel Washing Machines
Here again is my model and serial it stops in the middle of the cleaning cycle Kenmore 665.16773402 serial # ft0302854 Here is how I have been resetting the dishwasher. I hit the following sequence of...
Door latch.
Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options.
Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Oct 06, 2010 | Dishwashers
Control stuck on, with multiple light combinations
All this is normal except for the lights coming on. could be the panel control board.
Oct 08, 2009 | GE Dishwashers
Kenmore 16079 Built-in Dishwasher Logo
322 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
vince
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
