Question about KitchenAid Refrigerators
KitchenAid refrigerator, Model number: KSSO48FTX00 Serial Number: QU2324016 Temperature setting control for fridge is set at 37 degrees, but will only cool down to 46 degrees. Freezer setting is at -2, but will only go down to 27. Ice maker will not work. Help, please.
    President:
  • 1,099 Answers
Sounds like you have a defrost problem since the freezer side is working okay . It probably is not blowing cold air into the refrigerator side , so to check the defrost circuit , unplug the refrigerator and inside the refrigerator section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and forward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly through the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrigerator back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrigerator and reinstall the refrigerator control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired together and the replacement part comes with a new heater and bimetal already wired together . This would be the advisable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Take care in solving the the problem....
Posted on Oct 04, 2010
Kitchenaid side by side refrigerator/power is on/control panel display is lit up/Cooling is on/how do I reset the Temperature Display to get freezer at 0 degrees and fridge at 37 degrees
the temp you see are the temp valve inside, the set temp is only displayed while you are setting it. It maybe in defrost and you would see higher that set temp valves, if after an hour you do not see the temp come back down to normal operating values you should then see additional assistance.
Dec 29, 2017 | KitchenAid Refrigerators
I have a KitchenAid Refrigerator Model Number: KBFC42FTS. Bottom drawer freezer over cools -10 degrees.
Does that unit have a low temperature monitor built in? Maybe that is what is making the noise when your temps dip to -10 degrees. Actually, that is great because the lower the temps the longer you can keep food in the freezer so I would not be overly concerned about that aspect. BTW, have you tried to isolate the source of the humming noise?
Sep 19, 2017 | KitchenAid Refrigerators
That's interesting, -10 or colder is too cold and something is defiantly going on. This unit is controlled by a mulitple control boards, temperture sensors and other components. Question, what is freezer temp set at? Try increasing it by 3-4 degrees and see if that changes anything. Beyond that, I'm going to change the temp sensor first before doing any of the control boards. #29 is the temp. sensor. Good Luck
What should the temperature inside the refrigerator be, I have it set at 37
On the fresh food side you have it set at the proper temperature. Most thermostats have a scale from 1 to 7 or 9. If you set the thermostat at 5 this equates to about 37 degrees. Thermostat do lose sensitivity after a while and need to be replaces. The switch inside the thermostat wears out and the sensing bulb sometimes loses the fluid inside the sensor and the thermostat stops controlling temperature. So sounds like you have it set properly.
Oct 14, 2014 | LG LFX25960ST Stainless Steel French Door...
Where is the reset button on my electrolux fridge?
Good Afternoon Friend, thank you for your post! I see the temperature in your Electrolux refrigerator is too warm and would like to know how to reset it. May I please have your model number? The serial tag, which lists your model number, is typically located inside the cabinet, on the right side wall. With this information I can better address the issue at hand. In the meantime, please double check the temperature control. If the temperature is set too warm, set control to a colder setting and allow 24 hours for temperature to stabilize. Thank you - Z.
Apr 22, 2014 | Electrolux Refrigerators
I cannot adjust the fridge/freezer temperature
Hi, there
Purchase an appliance thermometer that is specifically made for refrigerators and freezers. These special thermometers were made to withstand cold temperatures and provide an accurate reading when exposed to such temperatures.
2Place the appliance thermometer in a glass of water.
3Set the glass of water with the thermometer in the refrigerator on the middle shelf.
4Check the temperature on the appliance thermometer after 24 hours.
The temperature should register between 37 and 40 degrees Fahrenheit (2 and 4 degrees Celsius) in order to store food safely.
Only barely above freezing -- say 34 degrees Fahrenheit (1 degree Celsius) is even better for food storage at the cost of slightly higher electricity consumption. But check that food is not slowly freezing in any part of the refrigerator, which could make it less palatable.
5Look for the temperature control dial inside the refrigerator if you have to adjust the temperature, and make it warmer or cooler.
If you can't easily see the control dial, check the owner's manual for a diagram that shows the location.
When looking at the refrigerator temperature dial, you may see numbers rather than degrees. The majority of refrigerators use a set of numbers, with the lower numbers representing cooler temperatures and the higher numbers representing warmer temperatures.
6Move the temperature dial in the necessary direction to adjust the temperature up or down. Be sure to move the dial only one number in either direction because it probably will not take much to change the temperature in the refrigerator.
7Adjust the temperature balance control if your refrigerator has such a dial or sliding switch. This allows you to direct more or less cold air to the refrigerator section from the freezer section.
8Wait at least 24 hours, and then check the refrigerator temperature again.
9Observe the amount of frost in the freezer section of the refrigerator if you are unable to properly set the temperature.
10Defrost the freezer if the amount of frost is more than .25 inches (.64 cm) thick.
11Repeat the steps as necessary until the temperature is within the safe range.
12Use a permanent marker to draw a line on the dial after you locate the best setting on the refrigerator temperature dial. This will give you a reference point in case your dial moves and needs to be adjusted in the future.
Hope that helps in solving the problem...
May 07, 2011 | Refrigerators
I am trying to return the freezer and refrugerator settings to 37 and 0 , how do I do that?
There is a dial or button pad inside the fridge that controls the temperature up or down.
some displays are not so clear so just adjust your fridge slowly either way until you get to the desired temperature
37 degree Fahrenheit = 2.78 degree Celsius
0 degree Celsius = 32 degree Fahrenheit
Oct 28, 2010 | LG Refrigerators
I have a Maytag refrigerator similar to the current model (GS2625GEKS), I purchased mine in 2003. Serial number unknown. All of a sudden my freezer is way too cold and my refrigerator is not cold enough....
If the number is similar we will have to go with possibilities. Sound like the auto damper has frozen itself shut between the fresh food and freezer compartments. Some are controlled electrically some manually and others are controlled with a thermostat probe. Your thermostat for one side could be defective and not allowing the damper to open. Your refrigerator must have the correct model number to proceed. What I need you to do is look for the vent through the rear of the refrigerator compartment and sometimes leads directly from the same wall as freezer. Many Maytag brands fall under same series and model similarities. The serial number is not as important to the service Tech as the model number. Look around the door frame near floor and kick plate.I can help but I will need the correct model number, Thanks, Sea Breeze
Feb 13, 2010 | Refrigerators
Whats the correct temperature the fridge should be set at? our milk goes off very quickly and nothing chills.
A refrigerator should be set for a temperature of 37 to 39 degrees F. Refrigerator controls are not usually marked in degrees but have indications for "warmer-cooler". Set the control toward the cooler side and check the temperature. Place a reliable thermometer on a middle shelf to check the temperature. If the refrigerator is not able to maintain a temperature in the 37 to 39 range then the cooling system may need service.
Oct 21, 2009 | Refrigerators
Temperature variation in freezer on Whirlpool ED22TQFXN
need your model number for unit reply but dont rare me till we are done get model num off serial plate in fridge
Jan 02, 2008 | Refrigerators
Refrigerators Logo
161 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
