Question about Mitsubishi WS-65807 65" Rear Projection Television
Power goes off after less than 1 sec. Error code is 2 - 2 when you press menu and input.
  • rthomas48060 Oct 04, 2010
    Do you know where I can by those parts on-line?
    Excellent!! Worth the money!
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code 2-2 means short protect which is either caused by bad convergence ICs and/or 2 Pico fuses (F9A05 and F9A04). You'll need to open the back of the unit and replace the parts that have gone bad to resolve this issue.
Please accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Oct 04, 2010
  • Rylee Smith
    Rylee Smith Oct 04, 2010
    There are repair kits available which includes repair instructions with the parts, if you want to do it yourself, you can buy and repair it yourself. Please accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
Magnavox error codes
check this
The Service Default Mode (SDM) is a technical aid that can be used to display the your TV error code.
Follow these instrutions exactly to place your set in SDM Mode.
For sets that still have video do the following.
  1. Turn your TV on
  2. Using the original Philips TV remote press the following keys. Press each key for 1 sec then press the next.
  3. From the remote press 0 6 2 5 9 6 MENU
  4. You should now see the letters "SDM" in the far right hand corner.
  5. If not do step "3' again.
  6. To display the error code hit the "Status" button on your remote.
  7. The TV can store up to "7" past errors.
For sets that have no video do the following.
  1. Turn your TV on
  4. Wait a few seconds. The red power light should begin to blink.
  5. The blinking sequence will determine the error code.
  6. You will have one long 5 second red blink followed by the error code.
Note: On some sets the TV will automaticaly blink the error code when its powered up without having to go into the SDM menu. If you power light blinks after the set is powered up jot down the sequence.
Example Error Codes from the power light.
( RED 5 Seconds ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 3
Example #2
( RED 5 Seconds ) off ( RED 1 Sec ) off ( RED 1/2 Sec ) off ( RED 1/2 Sec ) = Error Code 12
(Note:) Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
Jul 04, 2014 | Televison & Video
My mitsubishi tv comes on and goes right off
do self check when it (power light) goes off:
press and hold both menu and input buttons on front of set for at least five seconds and let both go.
power light will blink a two digit error code like, 1 blink, 2 blink and pause and repeat it several times.
The error code will narrow down where the problem is and most common one is 2,2
let me know what code you find.
Mar 28, 2012 | Mitsubishi WS-65809 65" Rear Projection...
Mitshubishi plasma tv ws65869 wont start green led on in a sec off
Not a Plasma by the model number listed.
When green power light comes on and goes off a few seconds later:
Press and hold on the front of the set both the Menu and Input (source) buttons at same time for at least five seconds and let both go.
Power light will blink a two digit error code like: 2 blinks, 2 blinks and a pause and repeat it several times.
If set has been unplugged it clears the errors and you must turn on and when power light goes out repeat.
Let me know error code found and I will help
Mar 11, 2012 | Mitsubishi Televison & Video
Will not turn on after manually pressing on button power is connected
TWO QUESTIONS:
1.) DOES POWER LIGHT JUST BLINK?
2.) IF POWER LIGHT COMES ON FOR A SECOND OR TWO AND GOES OUT, do the self check this set has:
when light goes out press and hold both the menu and input (device) buttons at the same time on the front of the set for at least five seconds and release both.
Power light in this case will blink a two digit error code like 2 blinks, 2 blinks, a pause and repeat it several times.
Let me know what error code you find and I will help you.
SD TECH
Nov 26, 2010 | Mitsubishi WS-55511 55" Rear Projection...
TV won't turn on.
Do the self check this set has:
when the power light goes off---on the front of the set press and hold both the MENU and INPUT (or Device) buttons for 5 seconds and then release both.
Power light will blink a two digit error code--most common is 2 blinks a pause and 2 blinks--it will repeat the code several times.
Let me know what the error code is and I will tell you what it means.
2,2 is most common and the most easy to fix.
If this information helped you rate this solution as I do this here for free.
Dec 28, 2009 | Mitsubishi WS-65712 65" Rear Projection...
IT WONT POWER UP
The model you have selected should have a self check feature: when turns off and the green power light goes off:
ON THE FRONT OF THE SET PRESS AND HOLD BOTH MENU AND INPUT(some sets the input is called device) together for at least 5 seconds and then release both buttons.
The power light should blink a two digit error code: for example: 2 blinks, a pause and 2 blinks--it will repeat the code about 10 times.
error codes for this set:
1, then 2 no error detected
2, then 1 X-ray protection
2, then 2 short protection
2, then 3 deflection circuit problem
2, then 4 vertical deflection problem
2, then 2 is the most common and easiest to fix.
Let me know what you find and if 2,2 I have detailed instructions for repairing that kind of trouble.
I am here to help people.
SD TECH
Oct 30, 2009 | Mitsubishi WS-55313 55" Rear Projection...
Tv mitsubishi ws-65315 doesnt turn on,only green light
Good Day, cutito35; 1. This model is equipped with a keyboard lock feature; this can be mistaken as a no power condition. To unlock the keyboard press and hold the "menu" button on the front panel for 10 seconds. 2. (Power LED may be on after plug in) check for no less than 4.4 volts DC at pin 3 of PC9A21 on the Power PCB, if low or missing replace PC9A21 part # 268P058020. 2.This model is also equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. Shutdown at power with self diagnosis error 2-2. Check for open fuses F9A04 and F9A05 part # 283P144080 on the +24 and -24 volt lines. If the fuses are open the convergence output circuit would be suspect. 2. Shutdown at power with self diagnosis error 2-1. At power on check for 12-volts DC at connector KH pin 8, if missing check IC9C51 part # 270P990010 and L9C52 part # 441D009020 on the Signal PCB. Good Luck, big IRISH.
Aug 29, 2008 | Mitsubishi WS-65315 65" Rear Projection...
No picture
Self test: Turn on and Press the input and menu buttons on front panel together and hold for 5 sec. after 5 sec the power LED will blink a 2 digit seq. This will let you know what error code. Count the first blinks then a short pause then the second blinks. Example 2-3, 3-4, 4-1. Let us know what it is.
Dec 05, 2007 | Mitsubishi WS-55807 TV
Oval shaped picture problem with Mitsubishi WS55807
Nov 21, 2007 | Mitsubishi WS-55807 TV
HELP
Oct 20, 2007 | Mitsubishi WS-55807 TV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
406 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
