User's guide for Tempstar SP80 gas furnace - Heating & Cooling
3 Suggested Answers
  • 3280 Answers
SOURCE: I need to replace a gas furnace thermocouple
HI follow the thermocouple lead back to the gas valve undo the silver nut foloow the lead back to the pilot and undone the nut on thermocouple or it may just pull out , or the burner might have to come out to replace it , if you arenot sure on this then a local gas fitter will do this .
Posted on Jan 26, 2010
  • 449 Answers
SOURCE: Tempstar gas furnace fan inducer comes on but
you have something activating ths pressure switch possible blockage in the intake or exhaust
Posted on Sep 10, 2010
I need wiring diagram for Tempstar furnace model nhgg100ah3
Request the wiring diagram directly from Tempstar.
Dec 31, 2016 | Heating & Cooling
Just installed a used tempstar nulk075dg03 turned on power and the blower fan wont shut off. turn the thermastat asking for heat the blower motor goes off and the glow comes on the fire lights for a c
its wired up wrong somewhere try to bypass the thermostat wires at the unit and confirm the unit works
then youll know more
other than this i would consult the installation guide and user manual first ...!!! get them from the makers site some makers manuals are not on the general google type search but readily available from the makers site
Dec 21, 2014 | Fasco Intercity Heil / Tempstar Furnace...
Gas valve clicks when furnace is running
is there a second call for a flame on during the heat cycle..it may be worn out or the signal to open is not strong enough..
Jan 08, 2014 | Honeywell Icp Heil Tempstar Furnace Spark...
Tempstar nugk125DK06 won't light. Changed from gas to lp and now won't light. Is there a way to bleed the valve?
Keep letting it cycle through eventually the gas will make it through the small outlets. You will likely need to reset power. It took me about 10 start cycles to bleed one two days ago
Jan 03, 2014 | Heating & Cooling
Tempstar pilot turns off
Based on your model number this furnace does not have a pilot light,instead it uses a hot surface igniter.typically it glows and when it gets hot enough the gas valve will open and the burners will light.When the igniter starts to go bad it will glow but not get hot enough to open the gas valve.If your furnace lights and the quickly goes out the flame sensor maybe dirty.
Oct 07, 2012 | Goodman GMS90703BXA Heater
Tempstar gas furnace fan inducer comes on but furnace will not ingnite?
Sep 09, 2010 | Heating & Cooling
I need to replace a gas furnace thermocouple on a Tempstar gas furnace. How do I do this? Part # SV9500M2682 on Tempstar model # NUG5100BHB2
Jan 26, 2010 | Heating & Cooling
Tempstar dc90 dual fuel system seems dead. the
Look for flashing light in bottom door and count flashes after furnace locks out. Read code or flashes with sticker on furnace panels.
Jan 10, 2010 | Goodman GMS90703BXA Heater
Heating & Cooling Logo
920 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
