Question about Troy-Bilt Pony Garden Tiller
I recently bought a second hand pony garden tiller and want to check and change oil in the tiller. Serial #496063 Can you tell me where to check the oil and how to change or add oil???
  • 3,740 Answers
Hi and welcome to FixYa. I am Kelly. You did not mention engine size but most of the "Pony" Tillers had a 250 cc Briggs and Stratton engine.
The owners manual is here::
http://www.troybilt.com/wcsstore/TroyBiltUS-CAS/Attachment/ownersManuals/tillers/769-03556.pdf
If you download the manual on page 23 figure 7-6 you will see the WHITE oil cap on the right side of the engine just forward of the belt. Unscrew that by placing a screwdriver across the 2 raised tabs IF you can not get it loose with your fingers. There is a dip stick with oil level indicators on it inside the engine.
Just forward of the dip stick in figure 7 - 6 there is a rectangular / 4 sided plug. That is the oil drain port. Changing the oil is a matter of removing the plug and waiting until all the oil had drained and then reinstalling the plug.
Oil is added via the dip stick port. (White 2 tab cap behind the oil drain plug near the belt area)
Since I do not have your engine number I could not get your engine manual for you. The engine number is stamped on the Air Shroud of hte engine and will be in 3 parts. I believe this is your engine number but not 100 % sure: 150212-2560-B8
The parts and owners manual are on this page. ( you will need to downloand each one)
http://www.briggsandstratton.com/engines/support/operators-manuals.aspx?NTT=150212-2560-B8
Engine: http://www.briggsandstratton.com/document/index.aspx?doc=277040WST_E_LO.pdf
Engine parts:
http://www.briggsandstratton.com/document/index.aspx?doc=MS3796_E_LO.pdf
Thanks for Choosing FixYa,
Kelly
Posted on Oct 04, 2010
I have an older Troy-Bilt tiller (model & serial # unknown) that when I start it (manual pull) it runs for a second and then shuts off. I checked the spark plug, fuel line and inline filter, fuel, oil...
could be bad coil. does it stay running with choke on? or half on, if so its a gas problem. could be the main jet is plugged in the carb. Or water in the carb bowl. Remove the bowl nut and let some gas run out the put it back in and try it. just guessing as not much info to go on.
Apr 26, 2011 | Troy-Bilt Pony Garden Tiller
What kind of oil goes in the crankcase of the troybuilt pony tiller
here are two websites that will help, the second on is a forum so it may be of more help,Tim:
http://www.ehow.com/how_7983565_use-troybilt-pony-tiller.html
http://forums2.gardenweb.com/forums/load/tools/msg1014281421084.html
Mar 22, 2011 | Mtd Garden
I have an old troy bilt pony rotertiller no serial tag
The decals r a good indication, they probably didn't have any more made than they needed. The only thing i can think of is, sometimes on the back side of the flywheel, (if u ever have it off) r some stamped numbers. One set of numbers is the month, and one set is the year it was made. Now that's the flywheel, but the engine should be the same year.
ballping
Jul 26, 2010 | Troy-Bilt Pony Garden Tiller
Pony Garden Tiller: does a tiller with a briggs and straton engine nee...
The pony tiller with a Briggs and Stratton engine only uses gas do NOT mix oil with the gas.
Frank
May 18, 2010 | Troy-Bilt Pony Garden Tiller
I have an older Troy-Bilt Pony Garden Tiller witha
From what I read you need a new rewind clutch and the spring and cord go into the housing. Briggs is easy to fix. contact me at kerryjonjon@yahoo.com and I can send you what you need or you can send it to me and I will repair it very cheap!! Parts are available at almost any small engine parts place.
Jul 17, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
432 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
