Question about Maytag Legacy Series Top Load Washer
Replacikng the belt
Need to replace belt on washer
  • Anonymous Jul 03, 2008
    yes
    Scholar:
  • 196 Answers
Searching on line is a good way to find parts and some diagrams. For me to assist you I need a make and model number. With this I can walk you through the repair step-by-step
Posted on Jun 04, 2008
    Novelist:
  • 177 Answers
Do an on line search for Maytag parts, then add in your model number and various parts houses have diagrams on your model and belt. I like repairclinic,com or Partselect.com
Posted on May 28, 2008
The washer (#WBSR3140GWW) does not spin on the spin cycle and the clothes come out very wet. What could be wrong??
The most probable trouble is the belt is streched and needs replacing. To replace belt remove front panel by placing a putty knife about two inches inward from the ends of front panel push the putty knife in and release clips for front panel.remove panel and belt will on bottom under the motor. On a lot of GE washers the oil in transmission leaks and soaks belt in oil so soon new belt will be oil soaked and needing replacment again if ya see a lot of oil in base belt will fix temporarly till its oil soaked,the fix then is to replace washer since trans. replacement is more than new washer
Gene
Aug 03, 2011 | General Electric WBSR3140GWW Top Load...
My washer wont spin or agitate and there was a burning smell
Hi
Older top load washers use a belt to drive to transfer the energy from motor to drum. However, if the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell. The belt is located either from the back access panel or from the underside of the washer. The solution is to replace the belt with a new one. To replace the belt you can open the back lid of the washer
To replace the belt carefully pry up on front washer top to release plastic keeper pins, remove 2 Phillips screws from beneath lower front washer panel, slightly lift upward on panel to release. Now remove old broken belt, push new belt beneath large tub pulley and put belt on small motor pulley. After this push back belt tension /idler arm, start belt on large tub pulley, turn tub pulley by hand to run belt on, release tension on idler arm. Replace front panel and lower top.
Hope this helps... Please post back if you need more information.
Daniel
Jan 30, 2011 | Kenmore 24032\24036 Top Load Washer
Washer will fill and spin but will not agitate ge top load washer wwsr3130w0ww
It doesn't agitate If your washer doesn't agitate, check these: Lid switch Motor coupler Belts Clutch Drive motor Drive pulleys Transmission Agitator Lid switch If the lid switch is defective, the washing machine may not agitate or function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it. Motor coupler Many washers produced by Whirlpool® use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. If this happens, you need to completely replace it. Belts Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.) Clutch If your washer was made by GE®, it may use a clutch for agitating the clothes. As the clutch wears out, it may prevent the washer from agitating well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician. Drive motor Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor. Drive pulleys The motor or transmission drive pulley may be worn and unable to turn the drive belt. If so, replace the pulley.
Jan 02, 2010 | GE WBSR3140DW Top Load Washer
Belt needs replacing
Tip the washer back and the belt is underneath, just pull of and replace - simple.
Dec 29, 2009 | Admiral AW22 Top Load Washer
How to replace a belt on a washer
On some washers, mostly older models, a belt is used to transfer power from the motor to the transmission and pump. If that belt breaks, the washer will not operate properly but it will make sounds like it is doing something. If the belt slips or is loose, the washer may operate sporadically or erratically. It may make loud squealing noises and there may be a burning smell. Some models use two belts, one for the transmission and one for the pump.
To replace the drive belt, you will need to open the access panel or in some cases tip the washer onto its side to expose the belt on the bottom. Start by removing the back cover, and look for a belt. If you do not see a belt (or a place for a belt - the belt itself may have broken and is hidden from view) and you can see the floor then your washer is a direct drive model that does not use a belt. If you cannot see the floor because there is a steel floor in the washer, locate the motor and determine if it extends through the bottom plate. If so, then the belt is accessed from beneath the washer.
If you have to tip the washer over, place a large piece of cardboard on the floor to protect the floor and the washer's finish. Because a washer is pretty heavy, you will need an able-bodied assistant to safely tip the washer onto its side. Also, there will be some water remaining in the washer, so have sponges and towels ready to clean up any spill.
To remove the old belt unscrew the clamps securing the pump coupling ( a leathery or rubber flexible part that connects the motor to the water pump). Remove the pump coupling to slip the old belt out. Some models instead require you to loosen the motor mounting bolts and shift it inward to relieve tension on the belt. Remove the old belt.
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.
Replace the cover and test the washer for proper operation.
Thanks for using fixya
Regards
PCmania
Sep 27, 2009 | GE WBSR3140DW Top Load Washer
How to replace belt on washer sav515deww
Nothing to it. No tools needed. Just tip the washer back and place the belt on the pulleys. The motor is spring loaded place the belt on the pump and motor first then ease the belt around the main pulley. Have a MANUAL
Sep 05, 2009 | Maytag SAV515DE Top Load Washer
Replacing belt on maytag washer
Nothing to do but tip back the washer and reach under,grab the old belt and replace the new one. No tools needed because the motor pivots on springs.Check yor pulleys to see if any of them are stiff. This greatly increases the belt wear.
Apr 09, 2009 | Washing Machines
How do you tighten the belt on magtag washer
Hello sunny31,
If you believe the belt is slipping then the belt will need to be removed and replaced. There aren't any belt tensioners in your washer.. Can you provide the specific model # with a response so I can provide you with more information on how to resolve your problem?
Regards,
Rick
Dec 13, 2008 | Maytag Legacy Series Top Load Washer
Ge spacemaker washer and dry stackable.
if you have a broken belt... remove the back. and the drum support. then you can remove the belt... and replace it with the new one...pull back the pulley and them loosen the belt... let me know
Sep 16, 2008 | GE WSM2480DWW Unitized Spacemaker Washer...
I have a GE top loading washing machine. Model #wjrr4170gww. I need to replace the belt and can't seem to get the belt on. I know it is a tight fit, but my question is what is the trick to get it on.
Dear Customer,
Place the new belt over the transmission pulley first then place it over the motor pulley. If it is too tight, place the belt over the motor pulley's nearest edge and then slowly turn the motor pulley to pull the belt around and into the pulley. Replace the pump coupling or tighten the motor mounting bolts. The belt should deflect no more than one half inch when you press on the longest straight run.Replace the cover and test the washer for proper operation.
Thank You for using Fixya.. Good Luck!!
Jul 10, 2008 | Washing Machines
Washing Machines Logo
173 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
