Question about Audiovox Car Audio & Video
Looking for a wiring diagram for this alarm. the as-9491 appears to be the shock sensor. the rest of the alarm stuff has FCCID:ELVAR5C. the alarm doesn't work correctly, but is frequently preventing starting of the car. I want to disconnect the alarm system completely
ginko
  • 19396 Answers
SOURCE: car alarm preventing car from starting
Try removing the alarm system relay, some car alarm has also a fuse on the alarm that you can remove.
Many car alarms unlock by inserting and turning car key while you connect the battery.
Posted on Aug 19, 2008
1999 CONCORDE: check the battery terminals probably they are not tight enough...something like that happened to me just the lights turned on and the car seemed to be dead, the battery is still ok since then. I just needed to buy new terminals.
Posted on Nov 25, 2008
I am having trouble also but I need to know how to disconnect the alarm. I would appreciate it if you could help me out seeing that you have disconnected yours. Thank you
Posted on Jun 04, 2009
morse008
  • 1111 Answers
SOURCE: 2000 Chevy Impala, alarm remote issues
you should be able to however im not sure if it is associated with the on board system if all else fails reconnect it and maby change the batteries in the remote for a starting point
Posted on Sep 09, 2009
  • 634 Answers
SOURCE: i have volvo s40 2000, the alarm doesn't start when the car shocked, where i can found the shock sensor???
the shock sensor is mounted under the dash and is sometimes part of alarm box or separate unit, look for module under the dash and trace wires, it separate box it is often tie wrapped of a set screw, box it 1x1 to 2x2 box usually 3 wires, often attached to steering column or metal strut
Posted on Jun 09, 2012
Error code list
ALARMS THAT STOP THE DISHWASHER
A1 Want of water
Is the water cock open?
Does the water load solenoid valve work?
Is the water feed flow a min. of 5 l/min?
Is the water inlet filter clean?
Is the load solenoid valve filter clean?
Is the overflow inserted?
Do the tank/boiler pressure switches work properly?
C9 Automatic hood out of order
Alarm codes for automatic hood type dishwasher (see paragraph 9.2.1 Alarm codes for automatic
hood type dishwashers)
C12 Tank level sensor out of order
Are the connectors correctly connected?
Are connector contacts cleaned?
Does the air trap of the tank work correctly?
Is the level sensor broken (replace it with a new one)?
Alarm codes for automatic hood type dishwashers
When the alarm C9 appears, to facilitate fault-finding a parameter providing a more detailed indication has
been introduced.
The parameter is C9 and is found in the ron family.
The possible cause of the anomaly can be found (see next table) according to the value of the parameter C9.
E.g.: With an automatic hood type the alarm C9 appears.
Access the parameter C9 in the ron family.
Assuming the value displayed is:
20 ? During lifting, the current absorbed by the lifting motor has exceeded the threshold. This can happen if
a rack or other heavy material was placed on the hood.
ALARMS THAT DON'T STOP THE DISHWASHER (SHOWN ON THE USER INTERFACE AT REGULAR INTERVALS)
b1 Drain not efficient
Has the overflow been removed?
Is the water drain blocked?
Is the drain pump blocked?
Are the air trap and tank pressure switch clean?
Is there a constriction in the drain tube?
Is the pump breather pipe returning to the tank clogged or constricted?
Does the tank pressure switch work properly?
Is there a hole in the drain tube (only for versions with drain pump)?
b2 Overflow alarm
Is the load solenoid valve blocked? (see electrical wiring diagram - YV1 Filling solenoid valve)
Is the load solenoid valve relay stuck? (see electrical wiring diagram - RL5 relay of AP2 board)
C1 Boiler temperature rise too fast
Does the boiler level sensor work properly? The boiler could be empty.
Are no-original power resistances installed?
C2 Boiler temperature too high
Has the boiler temperature been changed (btC - increased above 90°C)?
Has the software alarm value been modified (bH,)?
Boiler relay/relays sticked (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board)?
C3 Tank temperature too high
Is the feed water above 60°C?
Has the software alarm value been modified (tHi)?
Is the rinse water temperature too high?
Is the tank relay stuck (see electrical wiring diagram - RL4 relay of AP2 board)?
C4 Tank temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST1 Tank
probe)?
Is the temperature sensor connector correctly inserted?
C5 Tank temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST1 Tank probe)?
C6 Boiler temperature sensor out of order
Is the temperature sensor broken or disconnected (see electrical wiring diagram - ST2 Boiler
probe)?
C7 Boiler temperature sensor out of order
Is the temperature sensor short-circuited (see electrical wiring diagram - ST2 boiler probe)?
C10 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor broken or disconnected?
C11 Rinse temperature sensor out of order (only on machines with temperature sensor on the rinse circuit)
Is the temperature sensor short-circuited?
C13 Rinse pump out of order (the water level of the boiler does not decrease)
Does the rinse pump work correctly?
Is there any bottleneck in the hose, that connect the air trap and the board sensor?
WARNING:
Alarms C2, C6 and C7 lock the boiler temperature control.
Alarms C3, C4 and C5 lock the tank temperature control.
In the case of alarms C6 and C7, the boiler waiting phase is not executed (the rinse may be performed
with cold water) and, during the initial warm-up and subsequent rinses ( btF > 0 ), the boiler heating
phase is not executed.
In the case of an open probe error ( C4, C6 e C10 ), the displayed temperature is 10°C
In the case of a shorted probe error ( C5,C7 e C11 ) , the displayed temperature is 99°C.
E1 Communication error
Is the connection between main board and control panel correct? Are the connectors correctly
connected?
Are connector contacts clean?
E2 Tank temperature low
Does the tank heating element work properly?
Are the dishwasher feed voltage and current correct?
Is the relay RL4 (see electrical wiring diagram - RL4 relay of AP2 board) on the board disconnected
or faulty?
E3 Boiler temperature low
Does/do the boiler heating element/s work properly?
Does the possible remote control switch connected to the heating element work correctly?
Is there power at the remote control switch input terminals?
Do boiler relays (see electrical wiring diagram - RL1/ RL2/ RL3 relays of AP2 board) work properly?
CAUTION: IF THERE IS A MALFUNCTION ON RELAY RL1 AND THE BOILER HEATING ELEMENTS
ARE FED BY MEANS OF A REMOTE CONTROL SWITCH, THE BOARD DOES NOT
HAVE TO BE REPLACED; JUST MOVE THE BOILER HEATING ELEMENT CONNECTOR TO
ONE OF THE TWO FREE POSITIONS ON THE BOARD.
CAUTION: WHEN ONE BRANCH OF THE HEATING ELEMENT DOES NOT WORK AND THE
OTHER TWO CONTINUE TO FUNCTION, ON REACHING THE SET TEMPERATURE VALUE,
ALARM 3 DISAPPEARS AND REAPPEARS IN THE SUBSEQUENT RINSE PHASE. THIS
ALSO OCCURS WHEN A PHASE IS MISSING.
Dado
Sep 01, 2014 | Zanussi Dishwashers
How to install python 594 in a diesel
install like a regular remote start alarm. You will have to tap into the glow plug wire, and change the setting on the brain to "wait to start" for the glow plugs.
If you have not installed a remote start alarm before:
1.install the siren under the hood and run the wire through the fire wall into the cab.
2. Mount antenna at the top center of the windshield then run wire around and down to drivers floor.
3. mount shock sensor with a ziptie to the steering column (as long as the steering column doesn't move/rotate)
4. separate the wires you are going to need, from the ones you won't need.(specific per vehicle):12+, Gnd, Parking lights, IGN, IGN2, ACC, ACC2, Starter, lock, unlock, brake, glow plugs...
5. zip tie and tape off the unused wires.
6. use wire diagram and find then test the vehicle wires.
7. connect RS/Alarm to vehicle, plug in antenna and shock sensor, then attach siren.
8. BEFORE DOING ANYTHING ELSE-GO INTO PROGRAMING AND CHANGE THE SETTING FOR A DIESEL !
9. now you can test the functions of the RS/Alarm,
BE SURE TO KEEP A WINDOW ROLLED DOWN, OR HAVE A SET OF KEYS OUTSIDE THE VEHICLE!
Apr 13, 2014 | 477L Ask RXTX HHU Remote
Where is the starter relay in my 2004 Ford taurus
I was just looking at a wiring diagram and it appears that the alarm relay is used for the starter relay also.
anyway look on the left front fender in the engine compartment.I noticed two wiring diagrams, one for a seperate starter relay ,one for a shared relay with the alarm.You need te see which one applies to your car .
Good luck Gary
Oct 27, 2013 | 2004 Ford Taurus Starter Motor
2011 gmc terrain, security alarm goes off after doors are locked with key fob, it is erratic no set time when alarm goes off, keeping neighbors awake
Locate the sensors,one is faulty.Induction sensors just about everywhere(I think they are illegal)but most likely in the doors ,shock is preaty close to the alarm cdi,smal case with a dancing spring inside may be needed an adjustment in sensibility,it has a knob on the case,air volume sensors just over the head,in front,look like litle speakers (tiny)or microfons,unplug one at a time.Bst guess:adjust shock sensibility..
Oct 22, 2013 | 2011 GMC Terrain
I have volvo s40 2000, the alarm doesn't start when the car shocked, where i can found the shock sensor???
Jun 09, 2012 | 2000 Volvo S40
Orion 90cc quadbike, wiring diagram, with or without alarm.
By cutting alarm wires, the quad thinks it's being stolen.
Sep 01, 2017 | ATVs
I have a 2011 doge avenger with stock alarm and 504k shock added. when i remote start the car the horn blows for 2-3 secs. turning off 504k stops this. help
You are having this problem because the OEM alarm will shut off your engine and trigger your alarm when the hood is opened. Your 504k sensor is connected to your hood, so when you start your car remotely, the vibration is triggering your shock sensor and thus triggering your alarm. I had this same problem. You need to reduce the sensors sensitivity dramatically to help resolve this issue.
Jul 23, 2011 | Viper 504d Double Guard Shock Sensor Car...
My bulldog Model 2010 Alarm is too sensitive and
I got this from their website.
Adjusting the Shock Sensor Sensitivity
To adjust the shock sensor, disarm the system, press and hold Button #3 (Finder) until the alarm chirps four times
(approximately five seconds), immediately release the button. Tap your vehicle’s hood above the alarm at the sensitivity
level you wish. The harder you hit the car the less sensitivity the alarm will be. The alarm will then chirp three
times. The shock sensor is now set at this sensitivity. Any shock that is equal to, or greater than this sensitivity,
will sound the alarm. Set the sensitivity as often as you wish; however, the sensitivity level will remain set until
the battery is disconnected or you reset it. If you do not tap the car it will automatically go to maximum sensitivity.
This setting is only acceptable if the car is parked inside a garage. NOTE: The factory setting on the shock sensor
should be acceptable for most vehicles.
Sep 09, 2009 | Basic Remote Vehicle Alarm System
Car alarm wont go of
IS IT A FACTORY ALARM OR AFTERMARKET???
Jun 25, 2009 | 1997 Volkswagen Jetta
Car Audio & Video Logo
268 people viewed this question
Top Audiovox Car Audio & Video Experts
xxxxxx xxx
Jaime Hernandez
Are you an Audiovox Car Audio and Video Expert? Answer questions, earn points and help others
