Question about Canon PowerShot A720 IS Digital Camera
Canon Pwershot A720 Date and Time Function
How do I activate the date and time function?
  • 3 more comments
  • Zaccar6 May 29, 2008
    I have set the date/time stamp several times. It will work for several days and then is gone. I changed the battery for the date/time function and it still will not stay set to the correct date and time-HELP
  • Anonymous Jun 05, 2008
    My problem is the opposite. How do I get rid of date and time on my photos? I want to view them on TV, but without the information. There is nothing in the information pack.There must be a way but I cant find it.
    Also will this show up on photo prints? I hope not I have about 800 shots!
  • Anonymous Jun 06, 2008
    The date will not stay set. Some times it will set for a few on off cycles, but then you turn it on and its back to zero looking to be set.
  • shirazfan Jul 04, 2008
    Each time I turn on the power to the camera it asks for time & date info to be entered. I enter it & it retains it until the camera is powered off, but next time the camera is turned on, the info needs to be re-entered.
  • broadis Jul 27, 2008
    We have the canon A720 and every time we turn it on we have to set date & time I put in new battery CR1220 and after shutting down the camera it does not hold the time & date. My son has the same camera so I tryed his battery in my camera and now they won't hold the date & time
  • 2,039 Answers
If you are trying to get the date/time displayed in your images, you need to set the recording size (L, M1, M2, M3, S, Postcard) to Postcard. You also need to turn the Date Stamp on in the Recording Menu (Use the Menu button, select the recording tab -- silhouette of a camera, and scroll down to Date Stamp).
Posted on May 28, 2008
There is a button cell battery "CR1220" which needs to be changed. Check the solution on www.cannon.com for instructions
Posted on Sep 24, 2008
How to date change in camera for display see date
Switch on the cameraPress MENU at the back You will 2 icons. One for camera and other for tools. Select tools settings
Scroll down to Date & Time settings. Press Set/Function. Change the date and time as per our time zone. Press again Set/Function. For display of date Select camera icon and on the drop down menu select display. By pressing the function key select the date /date and time. Press Set. The camera is set. Whenever you view picture it will display the date and time
Apr 26, 2010 | Canon IXUS 80 IS Digital Camera
Time and date resetting constantly...
This camera has a separate date battery. Lift up the small rectangular cover next to the main batteries. A small CR1220 battery maintains the date. Replace it and you should be OK. I just discovered this on the Canon web site.
Jan 10, 2010 | Canon PowerShot A720 IS Digital Camera
How do i set the time and date to stamp on my pics for canonsd870 is
hi the following procedure is to set the date and time...
just do the following steps carefully.
1. Push the function/set button. Press the directional button down to select Date and Time.
2. Push the directional button to the right then down or up to set the date and time. Then press the function/set button to save it.
Then: to put the date and time on your pictures,
3. Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
4. Scroll right to turn on the Date and Time Stamp, then up or down to until it says On.
Press function/set when your done.
That is your solution.after u set the date/time stamp is embedded in a picture, you can't take it out. ...
thank u
rate me
Jul 20, 2009 | Canon PowerShot SD870 IS Digital Camera
Date and time in prints
This function only works in "postcard" resolution. Press function button, and select postcard (1600 pixel width) resolution.
Jun 14, 2009 | Canon Cameras
I DONT WANT MY CAMERA TO HAVE A DATE...IT SHOW WHENEVER I PRINT MY PHOTOS. HOW CAN I REMOVE THE DATE? PLS. HELP.THANKS
hi the following procedure is to set the date and time... just do the opposite of dis and ur date and time will be removed..
thank u!!!!
May 26, 2009 | Canon IXUS i7 Digital Camera
Canon sd 750 how to put the date in the picture?
here is the solution:
The date and time can be included on the pictures taken only with the camera in postcard mode. You must also activate the date stamp option in the menu.
To set the camera into postcard mode, press the [Func.] button on the camera, then use the [arrow down] key to go down to the last option in the menu, and there you can choose the [Postcard mode]. Press [Func.] again to exit the function menu.
To set the date and time stamp, press the [Menu] button and then use the [arrow down] button to go to the [Date stamp] option in the menu. You can set this to "Date" or "Date & Time". Press the [Menu] button again to exit the menu.
dsc_include_date02_tcm14-520511.jpgyour date and time are set now
congratulations!
Rate this answer if it is working with you
thank you
with all my best regards
huetrichard@gmail.com
Feb 25, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
How to make date stamp option ON in Canon IXUS70 Model
Hi there, my name is Rob and I can help you.
To put the date stamp in a picture do this:
1) Make sure you have the correct date and time set in the camera. To do this:
Then:
2) Push the selector button up to the camera icon, and press function/set. Scroll down to Date Stamp.
That is your solution. Remember once the date/time stamp is embedded in a picture, you can't take it out.
Let me know if you have any further questions, and thanks for coming to FixYa. Please feel free to rate my solution a fixya.
Rob
Feb 19, 2009 | Canon PowerShot SD750 / IXUS 75 Digital...
Print date/time on pictures
The camera does not add the date and time to the image itself, but rather saves it in the file as it does other information.
When printing a picture you can select that you wish to add a date/time stamp.
Dec 17, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Unable to display Date or time in pictures taken from Canon PowerShot A720 IS
You have to select 'Postcard' for the image size -- on the same menu as L, M1, M2, M3, S, Postcard.
Oct 30, 2008 | Canon PowerShot A720 IS Digital Camera
Powershot A720 Date Function
Do you want date/time stamp?
If so, you will have to be in postcard resolution.
To achieve this you will put your camera in shooting mode, hit function/set button, arrow down to bottom left corner where you will see L, M, S and postcard modes. Select the one that looks like a postcard.
Hit function/set to get out of there. Now hit menu and go to setup menu (tools) and arrow down to date stamp and make sure it's on date and time.
images shot in this resolution will look good as 4x6 prints, but should not be printed any larger or they will look pixelated, not good quality for larger prints.
Either that or you can add date and time in the Zoombrowser program that came with your camera should you need larger prints with date/time stamp.
I hope this helps!
May 27, 2008 | Canon PowerShot A720 IS Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
947 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
