Question about Xerox WorkCentre M118 Black and White Copier
Power failure reaccuring numerous times How can we fix it?
  • Xerox Contributor
  • 185 Answers
Unfortunately, you probably have a bad AC power board. There are two possibilities 105E11660 or 101K45550 (These are the 110 volt part numbers)
You will probably need a technician to narrow it down further or install.
Whit
Item, Inc.
Posted on Oct 05, 2010
2003 gmc envoy . i have no leaks any where but my power steering does not work. IT IS HARD TO TURN. FLUID IS FULL! WHAT COULD IT BE ? HELP PLEAES
pump is not producing pressure
valve failure or internal failure
take it in to an accredited steering specialist shop for a pressure test and diagnosis
Jun 23, 2017 | GMC Cars & Trucks
The passenger power window wont go up?
NO COST PROCEDURE TO FIX IT:
1. Sit in vehicle
2. Ignition key is on
3. Door in question is openned
4. While door is open, press and hold power window button in desired window travel, keep button held
5. SLAM door closed with one hand while other hand holds button as per #4.
6. Watch window operate as it should.
7. Repeat 3-6 if necessary, usually the first try works!
NOW, for the naysayers that says you must replace power window motors etc, at $$$ cost because the above fix does not work, or is not long lasting fix, or less than a "professional fix".... Well then, when the window fails to operate again, apply same fix again at that time.
I have fixed my van this way numerous times (usually once a year), and to all I recommend this fix too, likewise do the same.
Apr 15, 2010 | 2006 Dodge Caravan
DST log contains previous errors.DST short test failed
Error Code: 0146
MSG Code: 2000-0146
MSG: 1:DST Log contains previous errors
Dec 22, 2009 | Dell Latitude D600 Notebook
6180 rebooting
Turn off the machine using the power button, unplug the power cord from the back of the machine, remove the ink cartridges, wait 2 min, press the power button to turn the machine on, wait until the printer prompts that the ink cartridges are missing, then replace the ink. If this doesn't fix it you may need to re-prime the ink lines using the directions at this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/.
Oct 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Control panel on gw395leps00 will show power failure
not sure if you need to replace your control panel, but if you do, you'll need this part http://www.repairclinic.com/SSPartOnly.aspx?PPStack=0&pop=1&ShHd=0&ShFt=0&PartID=1257027
your original "membrane switch" seems to have been replaced with this new (improved?) style. it fits your range and will presumably solve any short circuit problems you may be having with your original touchpad/membrane switch
Oct 01, 2009 | Whirlpool GY396 Electric Kitchen Range
2wire failure
Hi der... well the issue your facing is simple to say ur power adaptor is faulty. Usually its due to some electrical shorts or maybe some heavy lightnings. You can always have a remedy for it.
1st : Buy a new adaptor.
2nd: call ur ISP to have it replaced if ur still under some contract term or if the modem is still under warranty.
3rd : you can buy ur own ADSL2+ modem from supporting outlets . Make sure ur isp supports this modem.
This are the solutions for ur problem pal.. So make a wise decision.. Any needs and help post it to FixYa..ANd the experts here will fix ya..!
Aug 26, 2009 | 2wire (1000-000057-000) Modem
Pf??
PF means power failure.
For short outages the clock may still have correct time
(there is a battery backup for that), but the PF will
be displayed. Setting the clock will clear the PF
indication.
Press 'clock set-start' button, (under clock display)
enter time with numeric keypad,
press 'start' button. (to right of clock)
Jan 03, 2009 | KitchenAid KESC308LSS Electric Kitchen...
Reaccuring boot problem in vista
HII
i got one answer in web
please check out this
if this not help you
we can move furthur http://www.kqzyfj.com/click-3245371-10520244
Nov 24, 2008 | Microsoft Windows Vista Ultimate Edition
Ink system failure
Do this: Performing a power reset
  1. Press the On button to turn off the HP All-in-One.
  2. Unplug the power cord from the back of the HP All-in-One.
  3. Unplug the power adapter from the wall outlet and wait for 30 seconds.
  4. Plug the power adapter back into the wall outlet.
  5. Plug the power cord to the back of the HP All-in-One.
  6. Press the On button to turn on the HP All-in-One.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Sep 07, 2008 | HP Photosmart C7280 Laser Printer
No Signal problem
your lcd need a tech who could help you to repair the power failure.
Nov 30, 2007 | Acer AL1913 19" LCD Monitor
Xerox WorkCentre M118 Black and White Copier Logo
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
