Question about Frigidaire Ovens
Error code f2 - Frigidaire Ovens
    President:
  • 1,796 Answers
Hi!!
The F2 error code description is OVEN TEMPERATURE TOO HOT, the proposed solution is to CHECK AND REPLACE OVEN TEMPERATURE SENSOR (RTD).
HERE IS A PICT. OF HOW THE TEMP. SENSOR LOOKS LIKE, IT MAY BE A LITTLE DIFFERENT ON YOUR UNIT. CLICK ON THE FOLLOWING LINK AND ENTER YOUR UNIT'S MAKE MODEL FOR PRICE AND AVAILABILITY. http://www.repairclinic.com/SSPartDetail.aspx?s=b2a13ec61i1015027&PartID=1015027 error code f2 - 2c7aaf0.jpg
Posted on Oct 04, 2010
  • Frigidaire Master
  • 3,051 Answers
Hello there:
The f2 error code is telling you that there is a temperature that what it is set at here is the code below and what should be checked or replaced hope this helps please let me know how this is going
F2 Oven too hot Likely a bad oven temperature sensor (should read 1100 ohms) Possible bad EOC (Electronic Oven Control)
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
E1 F2 error code
Check the ribbon cable for connection
Mar 27, 2013 | Whirlpool RBS245PDS Electric Single Oven
I self cleaned the oven and over 12 hours later am getting a f2 error. How do I fix it?
The F2 error code means that the oven over heated by at least 100 degrees and the oven temp.sensor needs to be replaced.
On the self clean cycle the oven temp can easily reach over 600 dergees and therefore the sensor thinks it got too hot. If you have not already done so the F2 can be cleared by pushing the CLEAR/OFF button on the control...if the F2 error code reappears the sensor has became defective and it would need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air WW30430P Stainless Steel Electric...
Whirlpool RBD245PDS15 Electrical wall double oven beeped .-... and showed F2 E6 code. Now it is dead other than interior light. No power surge, was not in use at the time. What is the code and how do I...
You to acces the electronic control and
1. Check keypad connector for firm connection.
2. Press CANCEL. If error code returns after 60 sec., replace keypad.
3. Replace control
Jan 06, 2010 | Whirlpool RBS245PDS Electric Single Oven
F2 error code
F2 E6 says this:
3. Replace control
Nov 10, 2009 | Whirlpool GBD277PD Electric Double Oven
My RBS275 oven has E0 F2 error code
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!#!#
Aug 16, 2009 | Whirlpool RBS275PD Electric Single Oven
F2 and F3 error codes in GE electric wall oven
Call GE answer center 1-800-626-2000 ask for tech help, Have you Model # off you data plate ready.
May 09, 2009 | GE JRP15 Electric Single Oven
F2 code on a oven mod#911-41069690
go to repairclinic.com click on repair help, then error codes... scroll to kenmore (it will give you a list by the first 3 digits of model number, who really made the machine.. (kenmore doesn't make anything) then go to appropriate brand and find error codes.
Feb 25, 2009 | Kenmore Ovens
Kebc207 oven error code E1 F2
This is information from the Tech Sheet.
Fault Code F2 - Error Code E1: Code Explanation: Keypad keytail not connected. Recommended Repair Procedure: 1. Check keypad connector for firm connection. 2. Press CANCEL. If error code returns after 60 seconds, replace keypad. 3. Replace control.
Jul 15, 2008 | KitchenAid KEBC207 Electric Double Oven
Ovens Logo
83 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
