Question about Panasonic Audio Players & Recorders
Programa para presentaciones
Necesito el mejor programa para hacer presentaciones (como power point pero mucho mas moderno, interactivo
    Master:
  • 555 Answers
  • Panasonic Master
  • 19,396 Answers
Nececittas usar macromedia director
Posted on May 27, 2008
  • 1 more comment
  • Ginko
    Ginko May 27, 2008
  • Ginko
    Ginko May 27, 2008
    Vale, ahora se llama Adobe director porque adobe se compro a macromedia, de todas formas es lo mismo programa, el programa consente producir presentaciones interativas en plan anuncio de tele. Puede poner animaciones y filmados.
    Si se registra aqui puede descargar la version de prueba.
  • Ginko
    Ginko May 27, 2008
    Open office Impress es un buen software, praticamente tiene lo mismo que powerpoint, es como un clone.Lo bueno es que es totalmente gratuito, si quires descargalo del link en el comentario del otro esperto.
    Director es otra cosa, es mas dificil, si aprendes el utilizo es un software completo y profesional
    suerte
Where can I get a driver for my MLi 691H speakers? I am running XP.
The humming noise could be a earth loop problem.
This is caused by having the speakers/sub woofer connected to one power point and the computer connected to a different power point.
To eliminate earth loop problems, connect both the speakers/sub woofer and computer to only one power point. Connect all your equipment to one power point using a power board.
Apr 12, 2012 | MidiLand MLI-699 Computer Speakers
I have a Dell/Zylux A425 2.1 audio system for a Dell PC. The speakers don't seem to turn on at all - no sound, no pops on power up and no indicator light on control speaker. Circuitry shows power at...
It seem your amplifier doesn't work, nothing to do with your computer, you can check with any other source lik eMP3 player, etc. If you take apart the box, there are some SJ4558 dual opamp. In my panel three of them were not working. Check if they are working or not. TDA 8947J is the power amp ic, download the datasheet.
You can also check the input PINs there are article about it.
After I replaced the 3 bad opamp, worked fine like new.
Sep 01, 2011 | Dell Audio Players & Recorders
No enciende las vocinas para mi computadora son logitech x-530 quiero verificar como puedo cambiar los fusibles o verificar cualquier cosa que sea para cambiar pero como destapo los subwoofer para...
Primero trata con otra fuente de energia electrica otro tomacorriente u otro sitio a ver si no es el sistema de cornetas, para abrir el sub buffer solo encesitas destornilladores y verificar dentro el estaod de los componentes si tienes voltimetro mejor, cuidado con hacer cortos. pero no hay uan guia basica para eso, solo saber lo que haces.
Mar 14, 2011 | Logitech X-530 Computer Speakers
Como hago para conectarlo directamente al televisor? no me da sonido
Home speaker systems experience malfunction either because the music being played is inappropriately recorded. First attempt to select from the list of media music or video to ascertain the condition as recording related. Second, the adjustments on the media player equalizers mentionable as bass or treble of teeters audibility makes the type of sound preferred. Open to display the computer media player to select from the audio sound adjustment qualities. Most computer media players have auto sound adjustments either mentionable as jess, pop, reggae, as only mandible examples of regulating the sound quality features. Navigate through the media player to ascertain the most appropriate volume; sound ratios require achieving pleasant listening experiences. For example, ascertain from the speakers systems for any available volume adjustment buttons. Also, the media player has adjustments to volume where the computer task bar area has adjustment volume bottoms. Observing queenly the sound features on the computer repair restoration functionalities.
Feb 02, 2011 | Cyber Acoustics CA-5001 Computer Speakers
Mis parlantes del computador no emiten sonido, revisando los mandos de control del computador no registran ningún problema ,qué me siguiere hacer?
DID YOU SOLVE YOUR PROBLEM? IF NOT, I NEED TO BUY THE CABLE THAT CONNECTS THE SUBWOOFER TO TEH SPEAKERS IN CASE YOU WANT TO SELL IT,IM INTERESTED
JORGEIRUIZ@HOTMAIL.COM
SI NO TE EINTERSA O NO PUEDES SOLUCIONAR TU PROBLEMA , ME INTESA COMPRAR EL CABLE QUE CONECTA A LOS PARLANTES CONE L SUBWOOFER
Jan 05, 2011 | Dell HK395 Computer Speakers
I'm looking for a cable that will plug into this sub and then plug into a 4 pin USB port to play sound.
neecito el cable para la reparticion a diferentes bocinas en otras palabras el plug que sale de la caja del bajo o sea el amplificador.
Oct 25, 2010 | Logitech Z-340 Computer Speakers
Where can I find JBL platinum series speaker drivers?
Hi!
The kind of speakers usually don't effect what drivers you have to use. If you have your motherboard cd then you can install the sound drivers from that cd. And, if you still are unable to find them in the cd then please tell me the model no. of your PC(and/or model no. of the motherboard).
Please rate this solution as FixYa if found useful.
Thanks Rylee
Feb 20, 2009 | HP JBL Platinum Computer Speakers
BURN THE STK AND REGULER NOT READ PART NUMER PLEASE ROT GIVE TENGO SPEAKER MM5650 Y SE LE QUEMO EL AMPLIFICADOR O EL STK Y EL REGULADO Y SU PART NUMER NO ES VISIBLE NO SE PUEDE LEER
tengo uno igual, puedo abrirlo y mandarte la foto, yo tambien necesito que me envies una foto de como estan las conexiones porque un tecnico me les hizo cambios y no encuentro el diagrama original
Feb 02, 2009 | Dell 5650 Computer Speakers
No Sound!
Check on Control Panel >> Sounds
Nov 12, 2008 | Logitech X-530 Computer Speakers
Looking for schematic diagram for Dell MMS 5650
MY DELL MODEL 5650 SPEAKER SMALL IC HAS BEEN DAMAGE KINDLY SEND THE IC NUMBER
Apr 26, 2008 | Dell 5650 Computer Speakers
197 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
