Question about Toshiba Televison & Video
I have a Toshiba CE32C10 tube tv. I moved it into another room and it wouldn't turn on. I pulled the back off and found a fuse blown. I replaced the fuse and now it just makes a loud ringing noise. What could be wrong with it?
  • 6 more comments
  • thisguy6425 Oct 04, 2010
    It has no screen or power light
    it has no screen or power light
    it has no picture or power light
    Sorry I thought my comments weren't being sent. The noise definitely isn't coming from the speakers. Before I replaced the fuse all i heard was a relay click once. When I replaced the fuse it clicks once and begins to ring, almost like its powering up.
    The noise definitely isn't coming from the tube. When I push the power button to turn it off the ringing noise fades away i.e like a capacitor.
    Well I'm technically competent. I'm willing to take it apart and test the board with a multimeter. Is there anyway to test the tube for sure?
    If it were the tube could i replace it myself?
    President:
  • 2,777 Answers
Yikes that's not good, so it powers on now, but just has a ringing noise? Does the screen come on at least?
Posted on Oct 04, 2010
  • 3 more comments
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    Ok ok, one comment is enough. That is very strange. Does it sound like a particular part is making the noise or is it coming from an internal speaker / the tv speakers? It sounds like it could be the power supply itself going bad.... Can you locate the power supply and see if it's making the noise?
    Tim
  • Tim Grayson
    Man oh man, it sounds like the tube itself could have been damaged, the power supply could sound like that, even an individual bulb could produce a whine. I guess your best bet is to listen around inside the TV and try to locate what is causing it, too many possibilities to pin point it down over an internet "chat" of sorts... Someone is going to need to look at this in person if you want it fixed up.
    Thanks
    Tim
  • Tim Grayson
    Ah ok then yes it is probably a capacitor somewhere, or could still be the power supply... But that is going to be very difficult to find the capacitor that is causing the problem :(
    Tim
  • Tim Grayson
    Unfortunately not without replacing it... I would bet anything it's not the tube though... very very unlikely.
    Tim
  • Tim Grayson
    Tim Grayson Oct 05, 2010
    The tube is definitely one of the more difficult things to replace in this TV, and is usually a two man job to get the alignment right, so I would not recommend you try dong it yourself.
    Thanks
    Tim
Have a Toshiba 32" Toshiba Television model #CE32C10 will not hold the channels
Check and replace the main system control memory IC. It has damaged.
Mar 27, 2013 | Toshiba Televison & Video
No picture, sounds fine. Fuse blown
This set, I am sorry to say has no bulb and has no ballast circuit. There are three picture tubes inside this TV set. What exactly was the part you pulled out? Can you post a picture of the Part you pulled out?
Jul 29, 2007 | Toshiba 46H84 46" Rear Projection...
I moved my tv to a friends house while i moved. we turned it on without leaving it get to room temp. think i blew a picture tube how do i detect this and how much is it to be replaced and also what parts...
picture tubes do not "blow" go bad by going dark check your circuit board for fuses test them and, replace the bad ones as your high voltage circuit is what lights up your tv tube... tv tubes do go bad when they do they show "blooming" and, bad ion masking not a black screen unless the tv is a newer lcd / plasma screen then just replace the inverter board or, cold cathode
Apr 26, 2009 | Televison & Video
61a60 Toshiba Flyback
Have you check the HOT Q404?
I would suggest to check that transistor before you decide to replace the flyback. The way to know if you are getting high voltage would be to pay attention for like a charging/discharging static noise when you press the power button to turn the TV ON or OFF.
Let me know if you require further assistance.
Dec 18, 2008 | Toshiba 61A60 TV
MY SCREEN IS DARK OR BLANK EVERYTHING ELSE WORKS GOOD JUST NO PIC
Hello fixedopsmike,
There is a fuse in the TV set, if you would like to check and see if it has blown, here is a way you can do it:
1) Unplug the TV's power cord from the wall
2) Take the back off of the TV by removing the screws and slowly removing the back panel.
3) Look for a component that looks like a glass tube with metallic caps on each of the ends, this will be the fuse.
4) Visually inspect the fuse to see if it shows signs of being open (Blown) These signs are burn marks inside of the glass tube, an open conductor (wire) inside of the glass tube, or no visible wire inside of the tube.
5) using a multimeter set to resistance (R x 1) test the fuse for continuity (remove and change the fuse if found to be defective)
6) If the fuse is not bad, reinstall the fuse if removed, put the rear cover back on.
Now at this point we have determined if the problem is a fuse being blown or not, if you replace the fuse and the TV works great the problem is solved, if you replace the fuse and it blows again, or if the fuse was ok to begin with, then you have a problem that will require some knowledge of electronics pass the basics to continue on. At this point I would suggest that you call a qualified TV repair technician to troubleshoot and repair the TV in question.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Nov 22, 2008 | Toshiba MW27F51 27 in. TV/VCR/DVD Combo
Toshiba 32inch tv not working
I have a 32 lcd tv that I have to slap the back of in order to work, why is that?
May 05, 2008 | Televison & Video
Tv wont go from standby to on....
I SUGGEST TO CHECK THE INTERNAL FUSE , IT MAY BE OPEN
Dec 06, 2007 | Televison & Video
No video, Blown fuse f470, audio works great.
check your h uot transistorthen check pico fuses
May 26, 2007 | Toshiba 50HX70 50" Rear Projection...
Televison & Video Logo
82 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
