Question about Hitachi 51UWX20B 51" Rear Projection Television
Vertical lines on top half of picture have a bend. Manual convergence helps but unable to corredt problem. Drops when set is repowered.
  • 3 more comments
  • gtrouty Oct 04, 2010
    How 'prohibitive' if I do the work myself?
    I've read about replacing '2 STK convergence ICS,and some or all it resistors.' is this what your referring to?
    Can you get me the part numbers and instructions? How about the part number for the entire circuit board?
  • gtrouty Oct 06, 2010
    still waiting
    yOU WERE GOING TO GET BACK TO ME WITH PART NUMBERS.
    President:
  • 2,777 Answers
It is the convergence units themselves in the TV that are failing, that is why they help slightly but can't fully correct the problem. This is major hardware failure for sure, and on this older unit of Hitachi a very common problem. It is repairable but cost prohibitive to do so. You may want to look into just replacing the unit. Let me know though if you really want to attempt the repair yourself.
Thanks
Tim
Posted on Oct 04, 2010
  • 4 more comments
  • Tim Grayson
    Tim Grayson Oct 04, 2010
    Well it's pretty difficult for sure, but if you can do it yourself you're probably very inexpensive really, especially if you can pinpoint it down to capacitors / transistors that have the problem. Less than $20 really if you can do that, but that takes some serious electrician skills.
    Tim
  • Tim Grayson
    Yes that is it!
  • Tim Grayson
    Searching for them now.. just a bit..
    Tim
  • Tim Grayson
    Tim Grayson Oct 06, 2010
    Sorry about that! Just to confirm, this is a Hitachi 51UWX20B correct?
    I will post some parts for that model here in a minute..
    Tim
  • Tim Grayson
    It is going to be one of these parts on this listing, if you have the board right there you can easily identify which cap / part you need, but I am having a hard time finding a schematic with that info.
    They are on here for sure though:
    http://www.partstore.com/SearchPAResults...
  • Tim Grayson
    I understand but they are not easy to find, I usually can find them no problem but there is not much documentation for this 10 year old TV :(
    Tim
No picture, only colored vertical lines
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
Dec 30, 2012 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    Intermittent top convergance drops out ...north convergence drops out bottom half of picture ok samsung projection tv mod sp43h3ht
    The convergence ICs are starting to go and need replaced ASAP. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which explains the problem, how to fix it and where to get the parts. Let me know if you need more help. Thanks for using FixYa and for the great rating.
    hardrocko
    Apr 27, 2010 | Samsung Televison & Video
    Getting a picture but double visioned and red lines running through it
    This is 1 of 2 problems.
    1; Convergence(depending on the model of the TV, the convergence ic's will have cold solder joints) 2: vertical ic issues.
    If they are different colored lines & the picture also bends, it's a convergence problem. Else suspect a vertical problem. In the case of vertical issues, most of the time it's a defective capacitor (or cold solder joints.).
    if it's the 3-crt kind of big screen, it's possible for one of the tubes to be going bad.
    Feb 28, 2010 | Televison & Video
    SAMSUNG 61HL617 TV COME AND LATER ON IN SCREEN COMING LINE CROSSING BUT STILL LOOKING PICTURE
    This is 1 of 2 problems. 1; Convergence(depending on the model of the TV, the convergence ic's will have cold solder joints) 2: vertical ic issues.
    If it's the 3-crt kind of big screen, it's possible for one of the tubes to be going bad.
    It would be best to contact a pro to take a look on your TV and replace the defective components. This should not cost you too much.
    Feb 19, 2010 | Televison & Video
    Wavy picture at bottom half of screen looks like two different colors, top half convergence looks good bottom half of pictute looksbad . Can it be vertical coil on two piture tubes not being drivendue to...
    Projection TV sets have two very common problems listed below.
    Problem #1) Convergence
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
    You can get more information and a DIY convergenece repair kit with instructions from the link below.
    Here are some of the most common problems with these sets...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2 - Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Oct 26, 2009 | Pioneer SD-P50A5-K 50" Rear Projection...
    Red Convergence
    http://schematicscom.blogspot.com/
    http://homenol.blogspot.com/
    Visit these sites. Convergence procedure of projection televisions are given in detail.
    Mar 28, 2017 | Televison & Video
    Tosh widescreen ghosting vertical lines
    there is no convergence adjust in a 32" tv. Convergence is done when there is more than 1 picture tube, ie; 50" projection sets have 3 tubes so convergence can go out. post the model number of your set and we can help more, BMW Rider
    Dec 14, 2007 | Televison & Video
    Hitachi 51UWX20B 51" Rear Projection Television Logo
    37 people viewed this question
    Top Hitachi Televison & Video Experts
    Jaime Hernandez
    Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
