Question about Philips 47PFL3603D LCD TV
I need a power supply board for a 47pfl3603d/27
3 Suggested Answers
  • 72 Answers
SOURCE: What could cause a Philips
maybe it was hanging out with the wrong crowd... just kidding.. The only way to find out is to open up the tv. Unless the smoke was coming from near the power cord. When you open up the tv, there will probably be some sort of burn mark on the circuit board where a capacitor may have blown. If this is the case (and provided that the circuit board wasn't damaged too badly, you can get a sodering gun, remove the blown capacitor(s) and see if you can find replacements at your local electronics store and then soder it back in. If not, you might need a whole new circuit board.
Posted on Mar 15, 2011
  • 125 Answers
SOURCE: my 47PFl3603d\27 47 in. LCD
If you don't know about electronics you should probably take this to a repair shop. If you do and you plan on fixing this yourself then [unplug] take the back off the unit and have a look. It should be rather obvious what was smoking. The board may look burned in the area. You already know which side it was from. If it was a cap it will look puffed. The solder on the bottom may have cracks from the heat. Maybe a resistor burned up. If you find out which component burned up, I might suggest buying two replacement parts because, odds are, there's a reason that one fried. That part will be up to you to figure out. Maybe a transistor or a diode shorted out somewhere. You'll have to trace the circuit back through and test out other components. Good luck.
Posted on May 01, 2011
How to fix philips flat screen tv
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
May 30, 2015 | Philips Televison & Video
Is a 473603d/27 phillip power supply board compadible to a 473063d/f7 power supply board
More than likely the old board just a, or a few, blow, capacitor(s). It you have a soldering iron, you can replace them yourself for just a couple of dollars.
Just look for puffed-up little can-shaped thingies, unsolder them, and buy replacements for a buck or two down at Radio Shack, and you should be "good to go"!
Easy fix, and cheaper than a replacement board.
I would think the /f7 board would work, if it has the same connectors as the /27 power supply board.
Jul 26, 2014 | Philips 47PFL3603D LCD TV
Philips flat screen plasma tv 47PFL3603D/27
There is no bulb in any plasma TVs. The fault should be with any circuit boards inside it.
Jun 29, 2013 | Televison & Video
Pop noise black screen smell
if you have a basic knowledge in electronic repair, the first thing you need to do is to remove the back cover of the tv to access the internal part. then you must check first the power supply board if their is a component that get burned. if ok, the next place to be will be the power inverter board and screen back light which the connector get burned.
Nov 02, 2012 | Philips 47PFL3603D LCD TV
Need to find out a part # for my philips 52PFL7403/f7 for the ir sensor
Join Date: Nov 2011 I have a Philips 47PFL3603D/F7 with the same problem. It was the IR sensor board causing the problem. You can search online to find the board, which almost everyone will most likely not have in stock, and cant be ordered. The part you need is this: 313926859181 IR Remote Sensor.
Models it will fit are as follows: Substitute Parts 313926859182
Known Models
MAGNAVOX 42MF438B/27
MAGNAVOX 42MF438B/F7
MAGNAVOX 52MF438B/27
MAGNAVOX 52MF438B/F7
PHILIPS 32PFL3403D/85
PHILIPS 42PFL3403D/27
PHILIPS 42PFL3403D/F7
PHILIPS 42PFL3603D/27
PHILIPS 42PFL3603D/F7
PHILIPS 47PFL3603D/27
PHILIPS 47PFL3603D/F7
PHILIPS 52PFL3603D/27
PHILIPS 52PFL3603D/F7
If you can find the board, great! A replacement board costs about $12.00. If you can't... we'll there is something you can try ; )
Either way, if you know it's the board, what's the harm in trying?
Remove the back from the TV. You can actually leave it on your stand to do this if you can spin it around to gain access to the back of it. Be sure to unplug everything first!!!
Looking at the back of the tv, the board will be located in the lower left side by the speaker. It will have 2 cables attached to it. Remove them, and take out the screw or two that holds it in place. There will be a plastic tab that keeps it in place also.
Take your fingernail and bend the tab back, and the board should come free. After that you should be holding the board in your hands. The side of the board with the connectors on it is the side you want to manipulate. There will be a tiny surface mounted capacitor beside one of the wire connection sockets. Take a utility knife and scrape it off/ you could use a soldering iron but it should come off very easy with a knife.
Plug it back in, and give it a try! If it works... great! If not, find a replacement board, and try that.
May 30, 2011 | Philips 52PFL7403D 52 in. LCD HDTV
What could cause a Philips M # 47PFL3603D/27 to start smoking?
Mar 15, 2011 | Televison & Video
Philips 47PFL3603D LCD TV Logo
257 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
