Question about Echo 30.1CC Chainsaw With a 14 In.bar and Chain
How to remove a clutch on a echo cs-400 - Echo 30.1CC Chainsaw With a 14 In.bar and Chain
SOURCE: how do I remove the clutch assembly from an Echo Cs-400 chainsaw
Turns out there is a reverse thread on the clutch hub (the "Y" shaped piece). I poked around some on the web and got some ideas, but they called for a special tool that it made by echo that fits in around the legs of the hub, and once you've prevented the crankshaft from turning by blockiing the piston, it turns (clockwise) with a wrench. I didn't have that tool, nor did I want to spend $19.95 to buy one, so I stuck a plastic toothbrush handle into the exhaust port to block the piston from moving, and used an open-end wrench just wide enough to fit over one of the legs in the "Y" shaped clutch hub. Then I took a large crescent wrench and closed it over the open-end wrench, right down next to the hub. So, if the saw is lying on its side, with the clutch facing up, the open-end wrench is inserted straight down straddling one leg of the clutch hub, and the crescent wrench is positioned horizontally gripping the bottom end of the open ended wrench to provide a "handle" for leverage. Holding the saw securely somehow (I used my elbow), left hand gripping the open-end wrench and pushing it down into the clutch so it won't slip out, I used my right hand to provide the clockwise motion on the crescent wrench as a lever/handle. Clutch popped free after a few seconds of pressure.
Hope this experience helps someone.
Posted on Jun 14, 2009
SOURCE: echo chainsaw clutch cs 370
the nut is part of the clutch bell housing just spin the bell counter clockwise and hold the flywheel or you can buy a tool that goes in spark plug hole its called a "dead stop"
Posted on Jun 22, 2009
  • 3 Answers
SOURCE: Purge pump removal
By studying an exploded parts diagram found online, I determined that it snapped out the top before the bracket slid out the front.
Posted on Jan 30, 2009
  • 582 Answers
SOURCE: Where do I find the proper tools to remove the
MOST OF THE TIME I USE A AIR GUN AND A AIR WRENCH .IT DEKIVERS THE FORCE WITH OUT BREAKING ANYTHING. A 3/8 INCH BUTTERFLY GUN WORKS WELL FORN THESE SMALL TASKS
Posted on Aug 26, 2009
  • 4088 Answers
SOURCE: Chain brake jammed on Echo CS400 chainsaw
You will need to release the brake by applying a very heavy screwdriver to the + shaped part of the brake coupling. Check the action of the brake handle and duplicate it at the the +. Hope this helps!
Posted on Jun 26, 2010
I received the cylinder assembly today. And when I opened up the package everything was there, but the ring for the piston was broken in half :
OH well free replacement is what you want then you will wait and why did you order from GREECE in the first place .
May 04, 2015 | Echo Cs-400 Chainsaws
How to replace clutch spring on a echo 650 chain saw?
id replace the entire clutch as if spring came out then therese got to be a reason
Mar 01, 2015 | Echo Cs-650evl Cs 650evl Chain Saw...
Replace clutch spring
You need to remove the clutch assy from the chainsaw prior trying to replace the spring. Be aware that the clutch assy is no longer available so be careful not to damage it on removal.
Mar 01, 2015 | Echo Garden
How to reassemble chain brake on an Echo CS-350T that jammed and was pulled apart by someone else?
From what I see you will need assemble thing leaving the main spring and brake cover off. Before attempting to put the main back in install a clutch drum inside the brake band. Then you slip on the main spring and pry the end on with a flat blade screw driver. Now install in the cover for the spring and brake. Reset the chain brake and remove the drum.
Now install the chain brake on the saw and test. Do not trip the chain brake without the clutch drum in place. If these are anything like the Husqvarna version after they get worn they will get where it is nearly impossible to reset.
Echo CS 350T Chainsaw CS350T Parts Diagram Page 7
Jan 12, 2015 | Echo Garden
Brand new Echo cs-400 chain saw: The chain spins fast on idle. Should'nt the chain be stationary on idle?
The manual is available here:
http://safemanuals.com/user-guide-instructions-owner-manual/ECHO/CS-400-_E
The idle speed of the negine may be too high.
Page 26 of the manual gives instructions for adjusting the speed with the "T" screw on the carburettor.
May 12, 2011 | Echo CS400 18" Chain Saw
Jun 25, 2010 | Echo CS400 18" Chain Saw
Where do I find the proper tools to remove the clutch assembly for an ECHO CS-345 chainsaw? I would also need a tool made to fit into the flywheel fins to prevent damage to the crankshaft while removing...
Aug 26, 2009 | Echo Garden
Trying to replace gear on echo cs 440 chain saw and not sure how to remove old gear
The IPL for a model 400 Echo can be found here:
http://www.echo-usa.com/pdf/documentation/CS400_C090_11_081007.pdf
It should not matter but please verify this fits your serial number.
From the IPL your saw has an outboard clutch. Use this the following as a guide. I didn't see any special tools on the IPL.
R² Drive Link Outboard Clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
  1. Check at the IPL for your saw to see if any special tools are needed.
  2. A length of starter cord or nylon rope may be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. It is probably a left handed thread (tighten it to loosen it).
    Let us know how it worked for you. GL
    Lou
Jul 02, 2009 | Echo Garden
Echo 30.1CC Chainsaw With a 14 In.bar and Chain Logo
410 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
