Question about Dryers
I have an older, about 4-5 years, electric kenmore 96575110 dryer that will not heat. It does it turns, the timer works fine; it just will not heat.
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.
If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place.
Note: This method works for most front loading machines.
Remove the electrical console that holds the timer switch, start switch, etc. from the top of the dryer. Be real careful not to knock any of the wires off of the timer switch or other electrical connections.
Remove the lint filter and the screws that hold the filter housing.
Then remove the top of the dryer.
Note: Some of the tops tilt backwards and do not have to be removed completly.
Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.
Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.
While you have the drum out, I would recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you a problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Tip
I have an electric whirlpool dryer about 4 years old..here are my issues and any...
This advice is for all ELECTRIC Dryers that have a "No Heat" problem.
Symptom: Dryer turns on, drum spins, but you have no heat.
Any of the following components are more than likely suspect as being bad:
Heating Element
Thermal Cut-Out
Hi-Limit Thermostat
All these components COMBINED, should cost less than $100. If you fix it yourself, you will avoid the additional cost for labor.
If the dryer isn't blowing ANY air at all, but the drum still turns, you may have a bad blower fan assembly inside the dryer. Or, the blower fan assembly may be clogged.
If your dryer performance has been failing (i.e., clothes taking longer to dry), it may be for a reason. You need to ask yourself when the last time you cleaned the dryer ventilation. If you can't remember, or if it has never been done, this can contribute to the dryer failing. All dryers need proper air flow in order to dry properly. If the ducting becomes clogged, the heating circuits will actually overheat and eventually fail. This usually results in the Thermal Cut-Out (TCO) blowing or the Heating Element failing or BOTH. When these components fail, they must be replaced. Remove the dryer hose from the back of the dryer and inspect it thoroughly from where it leaves the dryer to where it exits your home. It should be clear with no kinks or clogs. If your vent line runs under a crawl space make sure it is suspended above the ground and has no sags where lint could collect. RULE OF THUMB: The SHORTER and STRAIGHTER the vent duct, the BETTER. After you inspect the vent ducting, turn the dryer on and make sure you have forceful air flow coming form the dryer. This will prove that your blower fan is working properly or not. Since you stated that your dryer is not currently heating, the air will be cold, but you should still have some force behind it. If the air flow is weak, you need to clean the duct work INSIDE the dryer. It is important to keep a dryer checked routinely. I recommend once per season (that's 4 times per year). Dryers are the cause of many house fires. These fires are due to lint accumulations inside the unit catching on fire. A little preventive maintenance can prevent significant problems in the future.
Getting to the heating circuit to determine if the components are good or bad is the next step. If your dryer has the lint screen on the top of the unit, you will need to remove the back panel of the dryer to expose the heating circuits. If the dryer has the lint screen in the door, you will need to remove the lower kick panel under the door by using a putty knife to release the retaining clips. They will be located along the seam in the front about 2 inches in from each side. If this is a Kenmore Elite or Whirlpool Duet, the lower lick panel comes off by removing the screws under the bottom edge of the panel. (HINT: placing a block of wood under the front feet of the dryer can make access much easier). If your dryer has no lower kick panel, you have to remove the entire front panel on these models. This is accomplished by lifting the dryer top and removing the screws that hold the front panel in place.
NOTE: The heating circuit should be troubleshot with the dryer UNPLUGGED. Dangerous voltages are still present with the dryer turned off. Resistance readings are as follows:
Heating Element (located inside heater box) – remove the two leads from the ceramic terminals on the heating element and take a reading across the terminal points. It should read 9 - 13 ohms.
Thermal Cut-Out (TCO) (mounted to the heater box.) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
Hi-Limit Thermostat (mounted to the heater box, closest to the heating element leads) - unplug wires and take reading across connector tabs. Reading should be 0 ohms.
If any of the above readings are abnormal, replace the component. NOTE: If the TCO or Hi-Limit Thermostat is defective it is highly recommended by most manufacturers to replace BOTH components at the same time. They are often sold as a set. Without doing so, these components can cause potentially fail again.
I hope this information is helpful to you. If you need further assistance, please go to my profile at: http://www.fixya.com/users/jsrock516 and use the "Ask Me" feature for a quicker repsonse to your questions/comments.
on Nov 30, 2009 | Kenmore 62602 Electric Dryer
My kenmore elite electric dryer inconsistantly starts to heat and
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 27, 2010 | Kenmore 63942 Dryer
Kenmore Elec Dryer timer & Heat Element Failed
if you set timer on time dry it will count down but if you have it set on more or less it will not advance without heat,change out the heater and you will be fine
Nov 04, 2009 | Kenmore Elite HE4 Electric Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Extremely low drum heat but setting is on HIGH.
Electric (Kenmore - 60931) dryer takes forever (several cycles) lately to dry clothes set on high heat (actual heat in tub feels low though). There are no obstructions in the venting and the 240 volt connection is fine. The timer rotates the dial (timer motor working). Help!!!
Sep 15, 2008 | Zanussi TC7102W Electric Dryer
Electric dryer wont heat or turn off
there could be a temperature switch that tripps off. look at the diagram and trace also the power to the timer motor. it seems that you lost your power to your timer motor that is why the timer stays @ what ever setting you set it.
Feb 11, 2008 | Kenmore 63942 Dryer
Dryers Logo
87 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
