Question about Sony KV-32V42 32" TV
Sony kv-32v42 After I turn on the TV, there is sound but there is no picture at all... sometimes the picture comes on after couple seconds later it goes off... also the timer/standby indicator is blinking continuosly... I left turned on for hours but nothing has changed... the tv manifacturer date is 1999 , the serial# 8007523 ... I love the TV it was awsome... but now it's broken.. can any one help me about this problem? thank you very much.
  • mozcan74 May 27, 2008
    thanks for the respond...can't i fix it myself? i'm a good handyman... what's the cause of the problem? thank you very much.
    Novelist:
  • 105 Answers
Your two options are to take it to a service shop, or the more likely and probably more cost effective option is to purchase a new Television. The newer model will have a far superior picture quality, cost less per inch of viewable area, and likely have more features than your prior T.V. as well.
good luck
Posted on May 27, 2008
  • Neal Brown May 27, 2008
    The problem is that it could be a number of things.
    It could be the tube itself, or it could be the circuit board that controls the tube - it is too hard to say without a tech running diagnostics on it. Purchasing the parts yourself would ultimately cost more than a new TV, unless you just happened to guess right. But then again, buying parts retail eats into the savings you would have from not hiring a service shop to work on it. I'm sure this is not what you were hoping for, but with the age of the unit - it is not likely cost effective to repair it even if you do it yourself.
I have sound but no picture...when I turn it tv has pictures but 2 minutes later it disappears
Hello
There is some loose or bad solderings on the CRT base board of your TV. CRT base board can be located at the back of the Picture Tube, just pluged onto it. Open the TV, and just resolder all the suspected point by applying a liitle more solder. Loose soderings are very difficult ot detect, and so I advice you to do the solderings to all suspected points. Also check the plug in strip solderings that comes from the main board to CRT base board also. Resolder all the CRT socket soderings also. Ok
If any more problems, contact me through Fixya.
Nov 19, 2010 | Sony KV-32V42 32" TV
Sony Trinitron, no sound for TV but sound with DVD.
it could be the signal strength for your cable isn't strong enough. alot of people are encoutering similar problems ever since the digital switch over
Mar 27, 2010 | Sony FD Trinitron WEGA KV-24FS120 24" TV
My Sony WEGA Trinitron 36'' TV has red instead of green, how do I reset the picture or fix this?
try this reset in this see if it works
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Sony-Trinitron-KV-32V42.htm
Mar 06, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
After I turn on the TV, there is sound but there is no picture at all... sometimes the picture comes on after couple seconds later it goes off... also the timer/standby indicator is blinking continuosly......
This is a good indication that the picture tube is starting to fail. If you feel comfortable with the back cover off, try the following:
1) Remove the back cover (set the unit on the floor)
2) Locate the flyback transformer (part with large red wire coming out the top)
3) There will be one or two controls on it. One should be labeled screen and the other focus.
4) Turn the screen control slightly clockwise.
If the picture remains on, then the tube is starting to fail and the "fix" will buy you enough time to locate a replacement.
Update this with the results,
Thanks,
Dan
Dec 22, 2009 | Sony KV-32V42 32" TV
GREEN GLOW IN THE LEFT UPPER CORNER AND RIGHT LOWER CORNER
Magnetized The set is probably magnetized and needs degaussing (demagnetizing).
All CRT type TV's have an internal demagnetizing circuit that is engaged when the set is first turned on after being off for the day.
If this circuit is working then you sometimes hear a "bonk" sound (about 1/2 a second long when the set is first turned on. If this circuit isn't working the set will become magnetized over time and will have to be degaussed using a degauss coil available at a TV repair shop (cost aprox. $35.00) and you should have the circuit checked at the same time. A set will also become magnetized if a large speaker (magnet) or motor is close to the TV.
Oct 02, 2009 | Sony KV-32V42 32" TV
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking screen
ON THE 36 INCH SONY THE PROBLEM LIES ON THE PICTURE TUBE.THERE IS A LEAKAGE EITHER HEATER TO CATHODE OR G1 INSIDE THE CRT.THE ONLY WAY TO FIX IT IS REPLACE THE CRT OR HAVE THE CRT GUNS CLEANED THRU PICTURE TUBE TESTER/RESTORER/REJUVINATOR AVAILABLE ONLY FROM TV TECHNICIANS.GOOD LUCK.4TUNE.
Jan 09, 2008 | Sony KV-35S42 35" TV
No sound or picture now
The set may have shorted the horizontal out put transistor since it kept coming on sometimes. This could be cause by the driver transformer arcing causing a "spike" in voltage going to you horizoltal out put transistor. Stargazer
Mar 31, 2007 | Sony KV-27FV16 TV
Sony KV-24FV12 Image intermittant Blackout
Hello Robert, the picture tube on your TV set is exausted. Please contact your nearest Authorized Sony Service for further help/advice. After all, Sony is a good choice. The next TV set you buy could be one of Sony-s Bravia LCD. Kind regards, Arpad
Dec 20, 2006 | Sony KV-24FV12 24" TV
Sony KV-32V42 32" TV Logo
131 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
