Question about HP Compaq nx7400 Notebook
Hi, i have a hp nx7400, it wont start or charge battery. tried with different adapters and with a docking station. when i push on button it will blink 8 times without battery connected, with battery connected and dc power it will blink alot and not stop at 8. does any one have a idea of wich component is most likly to be defekt?
  • HP Master
  • 1,183 Answers
Remove the battery from the portable and disconnect the Ac adapter. Press and Hold down the power button for 15 seconds.
Reconnect the Ac adapter only and power on the system. If the system is doing the same . The motherboard on the computer has gone bad.
You can read more on the same on the link below
HP support forum
Thanks for using Fixya
Proton
Posted on Oct 04, 2010
Will not start
It sounds like the DC charging port on the laptop may be damaged, or it may be the power cord...here's how to tell:
First thing....remove the laptop battery, click the battery back onto the laptop and try again. If this doesn't help then read on...
When you put the laptop on the dock, it is getting it's power from the dock connector on the bottom of the laptop. When it is not on the dock, it gets power from your DC adapter. Soooo......take the laptop off the dock and plug the DC adapter into the laptop. Do you see ANY led's light up (on the laptop) when you plug the power cord directly into the laptop? If not, then your DC power adapter for the laptop is probably dead. If you DO see any led's light up when you plug the power cord directly into the laptop but the power button won't turn the laptop on, then the power button on the laptop is the problem.
Take your laptop to an electronics store, and see if they have any universal power adapters for laptops (they come with tips to fit all major laptop brands). Test your laptop at the store with their new power adapter. If this fixes it, then buy the adapter. If this does not fix it, then you should take it to a reputable service shop to get the power button repaired or replaced......or call HP if your laptop is still in warranty.
Hope this helps!
Joe
Dec 27, 2013 | HP EliteBook 8530p Notebook
Wont charge my iphone
The adapter off the docking station can be faulty and so that must be checked for working voltage.
If there is voltage on the adapter then the socking station charging section can be faulty.
The failure of the regulator IC in the docking station cannot be ruled out. You will need to remove the docking station after making sure there is no voltage to the docking section to the phone.
Nov 19, 2010 | RCA RP5500I Docking Station
My HP 6715s works fine but wont charge? Hi, could somebody please help, the laptop works fine when i charge the battery in my sons (same model laptop) then put the batt back in mine, its not that battery...
Hi there
this is just a wild guess but i think that is you ac conector that is fry there is not fuses for that so the only option is to take it to a local repair guy an get it replace. depending where you are may run from $50 to $150 the repair since they have to take apart the laptop to change it the part is no more than $ 15 but labor is the costly here so maybe the docking station will be the best in your case .
Jul 28, 2010 | HP Computers & Internet
HP Elitebook 8540p is getting no video in docking station
Try this
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=au&prodTypeId=321957&prodSeriesId=4097214&swItem=ob-83668-1&prodNameId=4096169&swEnvOID=1093&swLang=13&taskId=135&mode=4&idx=4
Jun 23, 2010 | HP EliteBook 6930p Notebook PC
Dell D610: Does not charge w/ any a-c adapter/battery pack.
This seems to be a shot in the charging circuit of the motherboard. If in warranty call Dell hardware supoprt and they will do the needful in warranty. If the warranty is out try a local technician and maybe they can repair the board.
Aug 10, 2009 | Dell Latitude D610 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
Docking station
Hi!
I would suggest that you by-pass any docking stations and connect it directly via usb charger as most ipods do. And also, try to update Itunes and your Ipod Nano software.
Thanks and good luck! =)
Jan 04, 2009 | Apple iPod nano
Dell D600
If the docking station is not charging the laptop while docked, it may simply need to be plugged in using the power cord to recharge the battery.
Jul 21, 2008 | Dell Latitude D600 Notebook
DEAD PRESARIO 1925 NOTEBOOK
Try this, with laptop removed from docking unit:
1. Press and hold the laptop power button down, for 10 seconds.
2. Now remove the battery
3. Repeat step one above
4. Let the laptop sit for 10 minutes.
5. Reinstall the battery
6. Make sure docking station is unplugged, and insert laptop into docking station.
7. Plug in power supply (to dock)
8. Start the laptop.
9. IF IT STARTS, let it run a while to see if the battery is charging
10. Remove it from the dock and repeat steps 1-5 above and then go directly to 8 (start without connecting dock).
CONCLUSIONS: If the laptop started in the dock on step 9 but not 10 (only on battery), your battery or power regulator circuit may be damaged. However, if it starts in step 10 but not step 9, your docking station -or its AC power supply may be damaged Let me know how this comes out, please.
Jan 15, 2008 | Computers & Internet
HP Compaq nx7400 Notebook Logo
780 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
