Question about Crosman ® Quest cal. Air Rifle with 4x32 mm Scope
Crosman air rifle model "147"does not hold pumped up charge. Get resistance when pumping, but not enough is retained to fire rifle. Have lubricated piston but that doesn't help.
2 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: need help putting back together my air rifle.
http://www.crosman.com/pdf/manuals/CS1K77_CS1K77X%20EVP%20&%20PARTS%20LIST.pdf
If this is not your model the list is here
http://www.crosman.com/airguns/service/manuals/crosman-rifles
Eric
Posted on Jan 16, 2010
Instructions to mount scope
PDF]OWNER'S MANUAL - Crosman
www.crosman.com/pdf/manuals/M4-177-515.pdf
Translate this page There are two different rear sight options for the M4-177 depending on which model you purchase.) Option 1- ... the airgun in any way inconsistent with this manual may make your ... Adjust the rings on your scope to match the measurements of the top rail. ... Toattach the sling at both ends push the sewn webbing loop end.
Crosman M4-177 Multi-pump .177 Pellet Air Rifle Table Top ...
? 24:29
https://www.youtube.com/watch?v=s_0grKCOmX0
May 18, 2012 - Uploaded by Replica Airguns
ReplicaAirguns.com - Crosman M4-177 Pellet-BB Multi-pump Air Rifle ... -Single shot - bolt action with manual advance magazine.... I particularly like the removable iron sights and full rail formounting a scope or red dot sight.
Crosman M4-177: Installing and Adjusting the Sights ...
? 8:38
https://www.youtube.com/watch?v=x8XKOmb41QA
Aug 28, 2012 - Uploaded by Crosman
A detailed look at installing and adjusting the sights for the M4-177 and sighting ... Crosman MK-177 Pellet-BB Multi-pump Air Rifle Table Top ...
Crosman M4-177 shooting rev
Dec 20, 2015 | Crosman M4-177 Air Rifle
Crosman m4-177 multi pump wont fire but it keeps it preser
Hi A,
Here is a review of your bb gun. Crosman M4 177 Multi pump 177 Pellet Air Rifle Table Top Shooting Review
Here is a review and some fix-its video. Review Crosman M4 177 Multi Pump AR BB Pellet Air Rifle Fun and Accurate
Mcabees speed channel provides you with a complete video breakdown at his link. Offered is a 12 part series which other subtitiles. This video should solve your dilemma. Go to the link.
M4 177 M417 Hunting Part 1 M4 177 Teardown tune reassembly Part 1 of 10...
Fare. Well.
Oct 18, 2014 | Crosman M4-177 Multi-Pump Air Rifle, Adj....
I pump my .177 crossman gun but it will not hold pressure
Usually a 35cent seal that is now more because of shipping, call Crosman # in your manual or find at their web site.
Feb 09, 2013 | Crosman Recruit Multi-Pump .177 caliber...
Crosman 66c air rifle wont fire
See the service manual here:
Whether or not air is coming out of the muzzle when you fire it tells you a lot.
May 24, 2010 | Crosman ® Quest cal. Air Rifle with 4x32...
Pelet rifle won't fire
Does it leak out?, pump up?, trigger release anything? What are the symptoms? Anything stuck in the bore? I think Crosman will repair your gun at a fixed price, just get a hold of them and get permission to send it back.
Feb 13, 2010 | Crosman Phantom .177 Caliber Break Barrel...
It takes 12 pumps to get a strong shot off and side spring load d
Hi Guy
There are 3 types of air rifles. Pump, Spring, and CO2. You have a Pump. These work by compressing air into a cylinder at the base of your rifle (where the chamber should be) and releasing it when you hit the trigger out the back of the cylinder. In that is a few Rubber O Ring seals that deteriorate under higher pressure than they are built for (10+ pumps). For the performance to be improved you would need a new O ring from the manufaturer (only if your gun is expensive enough (300+??)(there are some air rifles that are break action with like 40 pounds of break and are spring. subsequently they fire at over 1000 fps up to 1300 or 1700 or something i cant remember, but the require a firearms license or to be bought and delivered to the local police shop and picked up) so if you rifle is expensive enough you can get a new part. If not you can get a new rifle unfortnately and keep that one as a beater. To maintain that gun donnot charge it past 11 Pumps this should prevent further deterioration.
As per the sring is a pain in the as to load your gun, that comes down to how expensive your gun is again. if you get a cheap one they usually have you hold open the chamber. Better models have a reccess inwhich you can rotate a plastic nub from the spring into to lock it down. Other models use clips etc.
My suggestion if you do decide to go get a new one. Buy a break action. You cant overpower them and they are extremely quick to reload. (the constant pressure of a break (same pressure each fire) can help you fire better too).
You could also take the gun apart A LITTLE BIT it is a few simple pieces. GL
Apr 03, 2009 | Crosman Optics
Will not pump up in order to fire
open the pump handle and spray a little WD40 into the piston tube and let the gun stand **** down for an hour or so. close the handle and try again. It seems the piston sticks and then separates from the linkage in the pump handle.
Apr 03, 2009 | Crosman Phantom .177 Caliber Break Barrel...
Crosman model 200 rebuild kit for the pump
You can order a crosman rebuild kit from:
Bryan and Associates
Anderson, SC
1-864-261-6810
Feb 08, 2009 | Crosman ® Quest cal. Air Rifle with 4x32...
Model 342 Benjamin Franklin 22 caliber air gun
I recently purchased a rebuild kit for my 342. I bought the kit from airgundepot. It was the kit for the
392 and I modified it a little. On the new plunger, you have to drill a hole in the center of it the same
size as the pin's smallest diameter. You can use all of the parts in this kit except for the small o-ring. I think it sold for about 39 dollars or so. My rifle was manufactured in 1972 and it fires like new.
Jun 03, 2008 | Crosman (4032)
Crosman ® Quest cal. Air Rifle with 4x32 mm Scope Logo
295 people viewed this question
Top Crosman Optics Experts
Anthony Coots
Anthony Coots
Level 1 Expert
raysaw
Are you a Crosman Optic Expert? Answer questions, earn points and help others
