Question about Lexmark C533DN InkJet Printer
How to connect a laptop to a lexmark wifi printer
acdr
  • 1913 Answers
SOURCE: i am having problems connecting
check your windoes firewall and antivirus firewall .
also check ping to your network printer.
try to ping those ip if u get ping then it is ok.
check your printer and laptop gate way is same.
run this command in "run" iss "ping 192.168.15.1" ehchange your printer ip in this command.
thats it.
Posted on Nov 09, 2008
tbirdfan1
  • 3051 Answers
SOURCE: how do i turn my wifi on, on my lexmark x9350
Hi there
fi yopu go to internet connections and look for the wireless connection right click on it and see if you see enable this device than click on it if not you will need to make sure that there are no other connectons the computer is using for the internet ie dsl ok
Posted on Feb 28, 2009
the_fire
  • 432 Answers
SOURCE: print from laptop without using router to lexmark 6600 wifi printer
only if you get a wi fi access point and have a switch to connect the wi fi access point to but then you would have issues with NAT ( Network Address Translation ) which is used to be able to connect many computers to the internet through one internet connection.
Posted on Apr 30, 2009
adnanbhatti
  • 1188 Answers
SOURCE: lexmark p4350 printer no disc cannot connect to laptop
Click here first do go to the driver download page.
Next, click on the 'Download' tab and download the appropriate driver file for your Windows system. For example if your system is Windows Vista 32-Bit, click on Driver for Microsoft Windows Vista.
After you install this driver correctly, you will be able to connect your printer to your laptop, and subsequently start printing.
Posted on Oct 29, 2009
printmastert
  • 3344 Answers
Creating Customers For Life
    Verified Fixya Pro
    SOURCE: I NEED TO SET UP MY LEXMARK X4580 PRINTER TO MY
    you will need to install the printer software compatible for windows 7 available in the manufacturer's website for download. Check the version of your operating system if you have 64-bit or 32-bit OS. To check go to start > right click computer > click properties. Download the proper driver package by going to this link : http://bit.ly/dq2FVh . Click on Microsoft tab. Download cjq3500-4500Win7en.exe for 64-bit or cjb3500-4500Win7en.exe for 32-bit. Install the software. Hope this helps.
    Posted on Mar 09, 2010
    Have new router. How do I get my printer's wifi back up and running?
    Reset your printer's wireless network adapter first before re-connecting it to your new router's wifi network. Check this article from the Lexmark website on How to Reset the Network Settings Back to the Factory Defaults on the 'Impact' S300 and 'Interpret' S400 Series All-in-Ones.
    After resetting the printer, check this article on How to Install Lexmark S and Pro Series via Wi-Fi on Mac OS 10.x.
    We hope this helps.
    Apr 03, 2012 | Lexmark Interpret S405 Wireless All-in-One...
    Why won't my printer scan a document to my laptop?
    Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
    If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
    Dec 01, 2011 | Lexmark X5650 All-in-One InkJet Printer
    Why isn't it scanning a document to my laptop
    We want to be able to use the lexmark X7350 for two different laptops. We are using a WiFi.
    you will need to either share the printer from one laptop and configure the other laptop to use the printer on the other laptop.
    you will need to make sure your in the same workgroup for both laptops in order to share files/printers over the network.
    the other option is to buy a print server that will support your lexmark printer and connect to the network via either wifi or cat5.
    Sep 20, 2011 | Lexmark X7350 All-In-One Printer
    My printer is connected to another wireless network which is not the same as my laptop how do i connect it to the right one?
    I`ll guess You`ll have to connect your PC to the printer with the use of a usb cable.
    Then run the Lexmark software (Lexmark printer home) or similar (don`t know what you are using?)... Go to "settings"; and choose wireless setup utility. You`ll have to manually set the SSID (the wanted wireless network) and the WIFI password for this network. Hope this will help.
    May 23, 2011 | Lexmark X4650 InkJet Printer
    Connect via wifi
    first connect usb cable & power on of your printer
    then showing found new hardware than install it by your driver
    Apr 05, 2010 | Lexmark X4650 InkJet Printer
    Print from laptop without using router to lexmark 6600 wifi printer
    Apr 30, 2009 | Office Equipment & Supplies
    How do i turn my wifi on, on my lexmark x9350
    Hi there
    Feb 28, 2009 | Lexmark X9350 All-In-One InkJet Printer
    Laptop lost wireless connection to printer
    Is is a wifi connection? What type of connection do you use? Adhoc or infrastructure(meaning does it pass through the wifi router or direct to the laptop)?You may have to reconfigure your wifi.
    Sep 18, 2008 | Lexmark X3470 All-In-One InkJet Printer
    Lexmark C533DN InkJet Printer Logo
    137 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
