Question about Dell G6632 146 GB SCSI Ultra320 Hard Drive
Dell poweredge 2600 upgrade
Please if you can help me.... i have a dell PE 2600 with 3 hard drive (36gb, s, u320, 10k) i want to upgrade to 3 146gb ... what tipe of 146gb should i use???
  • fernanll May 30, 2008
    it sounds reasonable. i'll try your sugestions. thanks for your time..
Look at the service tag on the unit and go to support.dell.com to get the specs on the exisitng drives. Mine came with Seagate Ultra320 SCSI 80Pin 15K drives, You can shop for the 146GB versions and use your existing caddy's if you would like.
Posted on May 29, 2008
Windows server 2008 raid setup on a dell poweredge 2850
2 drives indicates they are RAID 1, which are mirrored. 2 x 36GB = 36GB. This is an industry standard config. If you make any changes you will lose the array making it RAID 0 (no RAID - no longer hot swap), and or the complete loss of OS / data.
Instead make another logical drive for data storage. You need three or four drives to set up as RAID 5, again an industry standard config.
Make sure to back up in all instances. GL
Nov 14, 2012 | Dell PowerEdge 2850 3.8GHz 2u Server...
Ugrade of DL380 G4 Server HDD Raid Array 36GB --->146GB Required
Do a ghost on the first hard drive install ghost on new hard drive and replace, I can provide more details on procedure just ask
Jul 25, 2008 | HP Compaq ProLiant DL380 G4 Server
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Apr 16, 2010 | Dell PowerEdge 2600 Server
Maxtor SCSI 36GB hard disk drive was removed from
if you are using raid go into the perc hardware utlity as it boots,try formating the drive there.maybe this will work.If you are using the dell open manage software you can probably format it there in windows.If you are not using raid enter the scsi utlity and do a format there.
Good luck
Sep 09, 2009 | Maxtor Atlas 10K III 73.4 GB SCSI Ultra320...
I'm having some trouble with a dell poweredge 2650 I bought off eBay.
You are not too clear, however I'll take a guess ..
1) Booting from CD ... older CD drives fitted to PE26xx range do not recognize Windows 2003 bootable install CD's .. the TS-L462C (a laptop drive) should be compatible with the PE 2650 (I know it works in my 2600)
2) Installing the Operating System onto the PERC SCSI Array drives .. a total pain .. with older OS (Windows 2000) you can use the 4 x floppy disk set to install and hit (F6 ? as I recall) to tell it to 'load a 3rd party driver' ... get the PERC drivers from the Dell site.
Alternative = toss the useless Tape Drive and install a set of SATA drives in the same space (a 3 drive Hot Swap caddy eclosure will fit = Icy Box or StarTech) .. you will need a PCI RAID card (such as Si3124) since the M'Bd has nothing but a combined floppy/TapeDrive IDE interfafce.
3) Finally, be aware that this is a SERVER level box .. spare parts & Dell 'official' upgrades are going to cost you an arm & a leg = and don't even ask what the special 'ECC parity' Memory sticks cost :-)
Jan 22, 2009 | Dell PowerEdge 2650 (PE2650BB) Server
DELL Poweredge 2600
The Dell original standard CD drive shipped with the PE2600 is incapable of 'understanding' the latest generation of bootable CD's (no matter what the BIOS says).
As far as I can tell, it's not fixable in the firmware ..
However you can swap it out for a more modern drive - such as the TS-L462C (which is a plug in replacement combined DVD reader / CD reader/writer - and Dell post the required drivers on their PE 2600 web pages, so I assume it must be a 'supported' solution)
Jan 18, 2009 | Dell PowerEdge 2600 Server
I need to add more hard drives to my poweredge 2600
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Jan 12, 2009 | Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
My operating system will not load
Try removing all of the hdds or just leave one that you think it works. See what happens.
Nov 07, 2007 | Dell PowerEdge 2500 Server
Dell G6632 146 GB SCSI Ultra320 Hard Drive Logo
334 people viewed this question
Alun Cox
