Question about Asrock P4I45GV R5 Motherboard
Hi, I really need your help, please help me. I get this CMOS Settings Wrong CMOS Memory Size Wrong Press F1 to Run SETUP Press F2 to load default values and continue ... and my keyboard doesn't work FYI : keyboard is OK, I already tried for different keyboard and the problem is same
  • global_ann01 Oct 06, 2010
    absolutely not work.. I need expertis
  • Asrock Master
  • 27,725 Answers
Press delete during boot up process enter BIOS then f1 for general help then run chkdsk/r/f which will automatically fix any corrupt files on your hard drive
hope this helps good luck
Posted on Oct 05, 2010
    I'm sorry ur help doesnt work!
    Please read this "my keyboard doesn't responding when CMOS setting wrong view on the screen " but hardware(keyboard) is OK 100%
  • Brian Sullivan
    Brian Sullivan Oct 06, 2010
    control panel ,keyboard hardware properties then you can select either general,driver,power management you can troubleshoot your keyboard or uninstal then reinstall or update driver,rollback,or uninstall driver there are many options you can try to fix your problem you can go control panel administrive tools computer management device manager keyboards then right click select properties under resources see if there are any conflicts......
    hope this helps
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
CMOS checksum bad Press f1 to run setup Press f2 to load default values and settinss Keeps comming up on star up
Your CMOS battery may be dead. That is the watch style battery on your motherboard. Choose f2. If the problem persists, change the battery
Feb 28, 2011 | E-Machines eMachines Desktop PC
AFTER SWITCHING ON, SCREEN STAYS FROZEN AFTER SAYING CMOS CHECKSUM ERROR- DEFAULTS LOADED
When starting your PC, the following error message is displayed:
CMOS wrong
CMOS MEMORY size WRONG
CMOS Checksum Bad
CMOS checksum error defaults loaded
Warning! CPU has been changed please re-enter cpu settings in the cmos setup and remember to save before quit!
You are prompted to:
Press F1 to resume
This is due to the fact that the CMOS, which contain data related to the BIOS, has been reinitialized and that your PC has been reset to factory settings.
Solutions:
Reinitializing the BIOS
  • Change BIOS battery
    • If the problem persist this may be due to the fact that the battery powering the CMOS (when the computer is shut down allows the CMOS to store information), is depleted.
    • The CMOS battery is a small pin found on the mother board, you can refer to the manual provided with your motherboard to change it or have the nearby computer technician change it for you if you don't want to risk any damage.
    • More information with: Replacing the battery of your motherboard (CMOS battery)
Post back if it is not working we will be happy to help you.
Hope this helps.
Cheers!!!!
Jan 12, 2011 | Sharp Actius PC-RD10 PC Notebook
I have some problem on my PC which is running window XP pro. When I switch on my pc. It will prompt me the message below: ''Overclocking failed. Please enter setup to re-configure your system. Press F1...
The BIOS settings are wrong. Press F1 when the pc starts to enter in the BIOS then on there you will see the Load default settings option: select it, Save and Exit. If the problem isn't fixed then you have some jumpers on the motherboard that are switched wrongly - take them all out and try again.
Nov 12, 2010 | Computers & Internet
Cmos setting not saved
Look at the CMOS reset jumper, located near the battery:
For normal operation there should be a cap shorting pins 1 and 2.
Set the jumper correctly, make sure it really shorts these two pins (once I've seen a jumper cap that didn't have the metal connector inside, only plastic), replace the battery and it should keep the CMOS settings.
Dec 19, 2009 | ASUS P5PE-VM Motherboard
I INSTALLED A NEW CMOS BATTERY BUT STILL NO EFFECT AFTER THE SHUTDOWN WHEN I RESTART IT THERE IS AN ERROR ..LIKE THIS CMOS SETTINGS WRONG ...CMOS SYSTEM TIME/DATE NO T SET...PRESS F1 TO RUN SETUP...PRESS...
Just replacing the battery will not set anything. You have to do the setting of the values. If you can run setup by pressing F1, then do that and set all the settings and then save before exiting. Make sure you save the settings by choosing the correct exit and re-boot option.
If the settings cannot be set nor saved, then make sure the poser is off or pull the plug from the wall outlet, then short the bios with the jumper to short the bios. This will reset the bios to the default settings. Turn on the system and then go to the bios settings and set the settings. Then use the reboot option to save the settings.
Nov 06, 2009 | ASUS P5PE-VM Motherboard
Cmos
You need to press F1 and go into the BIOS to setup and detect everything. You will need to set the date, verify it detects your hard drive and memory, and enable/disable items as you need for your system.
Once it looks good, do a Save and Exit.
Jan 16, 2009 | Computers & Internet
MY LAPTOP(hp compaq presario v2000)BEEPS TWICE AND DISPLAYS PRESS F1 TO RESUME OR F2 TO SETUP!pls help
Hi, and welcome to FixYa
The computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this issue can be caused by any of the below possibilities.
Solution:
If no new hardware has been added to the computer or the new hardware has been removed and you continue to receive the error, it is likely that there is an error or confliction with the CMOS. Press the key requested to enter setup and verify that all settings are correct. If everything appears to be correct try resetting the CMOS values to the defaults and/or Reset Configuration Data. Additional information about how to do this can be found on document CH000976.
If all settings appear to be correct, save changes and exit CMOS setup. If the error continues to appear, enter setup again and restore all CMOS values to default.
· See our CMOS page for additional help and information with the CMOS.
· Additional information about getting into the CMOS / BIOS setup can be found on document CH000192.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, it is also possible that the CMOS battery may be bad or failing. Generally; when this occurs, the computer is not holding the time or date correctly. If this is occurring it is recommended that the CMOS battery be replaced.
regards
/Teis the Wiz - -> Vote "FixYa" :-)
Dec 05, 2008 | Computers & Internet
Asrock P4I45GV R5 Motherboard Logo
248 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
