Question about LG DVD 5253 DVD Player
After pressing Pause button, the DVD player can not load the disc, dispays disc error, then disc eject
SOURCE: Toshiba SD-3980
http://www.tacp.toshiba.com/tacpassets-images/notices/sd-3980_sd-k750.asp
read that
Posted on Mar 23, 2008
mrgreenz
  • 962 Answers
SOURCE: dvd playback
Clean the DVD lens with isopropyl alcohol (rubbing alcohol) and a Qtip. Be careful not to press down too hard. Gently clean the lens all around. Changing Qtips if you see anty signs of debris or dirt on the tip.
Posted on Feb 06, 2009
  • 3 Answers
SOURCE: DVD IS STUCK IN PLAYER , SCREEN SAYS
There should be a small pinhole located in the front of the DVD drive, use a paperclip and insert it until you see the DVD drive tray open. Hope this helps.
Posted on Aug 05, 2009
  • 321 Answers
SOURCE: Can't get DVD out
Hi, thats is just a sugestion; if you can open the cover and removed the debris or so and clean the lens of the laser , and verify your belt loading ,is positioned under the disk tray,; and try to replaced this belt; and try to look if nothing block the mechanism..
hope that will help you
truely A.S..
Posted on Apr 15, 2010
kerguney
  • 577 Answers
SOURCE: A dvd is stuck in
Hi.I do not know if you can do it but no other way..Lets try it..
Please got a screwdriver and open the DVD case from the sides and back. It is simple, just some black screws. Then look in the unit and see and gently remove the disks by plastic holder open and sliding the disks out.
Then put the cover back on and put the screws back in. Should Work fine now.
I hope this helps you. Good luck.
Please let me know if you need more help.
Hope this helps! Take care and please Remember to rate/vote and
give me 4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Posted on Aug 26, 2011
WILL NOT EJECT DISC
What is the model number of your DVD player? You may try power resetting the unit and check if it helps. To power reset, turn OFF the DVD player and unplug the power cord from the electrical outlet for 30 seconds. Plug the power cord back into the electrical outlet and turn the player ON. Attempt to open the disc tray.
Depending on the model number of your DVD player, simultaneously press the POWER + STOP + EJECT buttons. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons.
NOTE: This step may not apply to all models as DISC1 is not available on all DVD players.
If this does not work and if the DVD player has DISPLAY and PREV buttons, press and hold the DISPLAY+PREV buttons for two seconds to unlock the drawer.
FOR SONY PLAYER's
This issue may occur if the disc is damaged or if the disc was not inserted properly into the Blu-ray DiscĀ® player. Follow the steps below to open the disc tray and eject the disc.
  1. Turn off the Blu-ray Disc player.
  2. Disconnect the power cord (mains lead) or AC adapter.
  3. Allow the disc player to remain without power for 30 seconds.
  4. While pressing the OPEN/CLOSE button located on the front of the disc player, reconnect the power cord.
    IMPORTANT: For some Blu-ray Disc Home Theater models it is necessary to press and hold the OPEN/CLOSE andPLAY buttons simultaneously, then reconnect the power cord.
    NOTE: This step may require the assistance of a second person.
  5. After reconnecting the power cord, when the tray opens, release the OPEN/CLOSE button.
  6. Remove the disc.
  7. If necessary, disconnect and then reconnect the power cord to recover the player.
Aug 24, 2015 | Televison & Video
Lg dp132 check region code
1.Switch on the DVD player without any Disc inside
2.The screen should display 'no disc'
3.Eject to open the DVD tray
4.While the tray is open, press the 'STOP' button then hold the 'ENTER' button for 5 seconds
5. A new screen will appear (Regional Management Test Code) which will allow you to change the region code using the up and down arrow keys on the remote control.
6. Change the code to '0' and press the PAUSE key to exit
Dec 30, 2013 | LG Televison & Video
I put a disk in and there was already one in now it wont eject
The disc tray does not eject when the OPEN/CLOSE button is pressed. Solution
sp.gif sp.gif Follow the steps below to troubleshoot this issue.
    IMPORTANT: The disc tray will not open while a disc is loading; this is normal operation. If this is the case, wait until the disc is finished loading before pressing the OPEN/CLOSE button to open the disc tray.
  1. Make sure the disc tray is not locked; if necessary,
  2. Perform a power reset.
    1. Press and hold the POWER button for 10 seconds until the BD player turns off.
    2. After the BD player turns off, press the POWER button again to turn it back on.
  3. Attempt to open the disc tray by pressing the OPEN/CLOSE button on the front of the BD player.
  4. If the disc tray still does not open and a disc is stuck inside, follow the steps below to force the disc tray to eject:
    1. Turn off the BD player.
    2. Turn the BD player back on.
    3. Immediately after POWER ON is displayed, press the STOP button on the front of the player. IMPORTANT: Only use the STOP button on the front of the BD player. The remote control cannot be used for this operation.
      NOTES:
      • The disc tray should eject and the BD player will turn off. If it does not eject, repeat steps A-C.
      • It may be necessary to press the STOP button in step C two or three times.
If the issue is still unresolved, service may be required
Sep 15, 2011 | Sony BDP-S300 Blu-Ray Disc Player
Cannot ejuect disc even when holding square button and channel button
unplug the DVD player for 10 - 15 mins... when you plug it back in the wall, press the stop/eject button quickly ( or else the player will try to load disc again.. you will have to repeat this again)
Jun 26, 2011 | Panasonic DMR-E55 DVD Recorder
''Bad disc'' error when any disc loaded in JVC XV-N670B DVD Player
There may be a connection to the problem, but it sounds like the laser assembly may need to be replaced as well as/or the mpeg printed circuit board(the printed circuit board) attatched to the laser assy. Good Luck.
Sep 26, 2009 | JVC XV-N320 DVD Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Upside down dvd inserted
FYI - This might damage the unit, but if you really need to get that DVD out then you can try this at your own risk!
Try unpluging the unit, then plug it back in and press the power button and a split second later press the eject button. This all needs to be done quickly otherwise the unit will try to load the disc.
Or
You can try letting the unit load the DVD. When the unit says "Please eject disc. Playback feature may not be avalible on this disc," press the eject button.
Apr 01, 2008 | Emerson EWR20V4 DVD Recorder/VCR
EJECTING ERROR/LOADING ERROR
yes, i send it in to alpine and they adjust it for like $100 or so.
Dec 28, 2006 | Alpine IVA-D310 Car DVD Player
Getting "HO7" when loading disc
After calling Panasonic, they suggested pressing the reverse skip (<<) button, the pause button and the open/close button all at the same time. The DVD player will then say "initialize." Turn off the player and unplug it for about 1-2 minutes. Plug it back in and turn on the player and load a disc. If the HO7 error code pops back up, you need to take it to a dealership for service. Or, at the price of DVD players these days, just get a new one - which is where I'm going right now.
Aug 21, 2006 | Panasonic DVD-RV27 DVD Player
LG DVD 5253 DVD Player Logo
19 people viewed this question
Computer Repairing
Computer Repairing
