Question about Garden
What is the correct way to load the nylon trimmer line into a into a talon line trimmer where the line exits through two holes? Many thanks, John McBrearty
    Champion:
  • 248 Answers
Put trimmer lines in at same time winding in direction shown on head,
Posted on Oct 06, 2010
  • vilia Dec 13, 2010
    according to the manual: Use 0.065" replacement line, measure off 14' (4.3m). Loop line into 2 equal lengths. Insert looped centre into slot of spool divider.Tightly wind til 6" (154mm) of line is left.
    Lock each end of line into opposite holding slots(on the bump knob side of spool). Insert line though each eyelet i the spool carrier
How to string a talon garden hawk trimmer
https://www.youtube.com/watch?v=tXUrdUoS_PU
Mar 18, 2015 | Garden
Fuel hoses and filter need replacing and a spark plug for a Talon AT3351A line trimmer
The manual has some instructions for doing these tasks on the Talon At3351a Line Trimmer. Here is the link for the Talon At3351a Line Trimmer manual.
Jan 21, 2013 | Garden
How to attatch trimmer line to RYOBI ELT400
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hdy
Jan 30, 2012 | Ryobi Garden
Putting on another spool, do I thread the line through the hole in the side?
I feel that the END of your trimmer line should exit THROUGH the hole in the side. That hole should have a small metal grommet to alleviate wear on the plastic head unit as the string flies.
So string your line onto the spool and when you are done, run the END of the line through the hole in the side.
Jul 04, 2011 | Worx 10" 18v 2 In 1 Grass Trimmer/In Line...
Could you please explain how I change from the nylon line trimming head to the metal cutting blade on my Echo brush cutter model SRM-22GES? Thanks for your help.
To change the head on the trimmer you will need to turn the trimmer upside down as if you were going to take the head off to restring it, spin the head and look for a slot in the side of the head when you see the slot, keep spinning until you see it line up with a hole in the metal piece the head attaches to. Stick a nail in the slot and hole and turn the head off the trimmer, if I remember correctly the head is backward thread.
Follow the steps backward for putting the brush blade head on the trimmer.
Apr 25, 2011 | Garden
I have a Talon electric line trimmer AT2307A. When I press the start button, the bottom attachment with the nylon line does not spin even though the motor is running.
Halfway down the shaft of the line trimmer, you can detach the line trimmer attachment ( this in so you can fit a lawn edger attachment if need be). Unclip the line trimmer at that halfway point and the start the motor and see if that rod inside the shaft is spining, if so, reattach the line trimmer attachment and see if the nylon line spins, if so, it wasnt attached correctly, if not, then there a break in the flexible rod going to the trimmer head, most likely at the bend.
Dec 29, 2010 | Garden
Talon harrier mach 25 trimmer sn 000461 petrol flow problem will not start ?
Start at the fuel tank. Check the condition of the fuel filter, the fuel line inside the tank. Then check all fuel lines for brittleness and cracks. Then check the condition of the primer bulb. Last, but not least, remove the cover on the carburetor without the vent-hole in it and inside should be a very small circular fine-mesh screen. Make sure the screen is clean; if not, clean it.
Dec 01, 2010 | Garden
Line trimmer not starting
The primer button may have a hole in it due to drying out. The little plastic bubble may not be priming the carburator prior to start. Leave on full choke and pull several times if still no start check for fresh and correct fuel/oil mixture if required. I am assuming this trimmer is not electric. If trimmer still fails to start or starts and runs for a moment and shuts off replace the primer button, the carb. is sucking too much air.
Sep 21, 2009 | 2006 Eagle Talon
How do I open the spool of a Mightylite trimmer?
you have to turn the knob to the left to get off then just pull it off and you can get the line back in place
Jun 26, 2009 | Homelite Mighty Lite Lawn Trimmer
Can't find manual to 26ss mighty lite trimmer. how do i open nylon spool? trying to pull nylon out of holes (somehow they retracted into the spool as I tried to start trimmer).
Hello jonandchima:
This is a Homelite Product.
You can Order a Manual from this Site Addy;
https://register.homelite.com/contact_us/new and Fill Out the Required Information and Select "Need Manual" . Remember to Include the UT Numbers.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
May 12, 2009 | Homelite Mighty Lite Lawn Trimmer
Garden Logo
475 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
