Question about Fossil Watches
How and where do I get a watchband replaced or repaired?
The pin that goes to the clasp on the watchband has broke. I don't have the
faintest idea how to go about having it fixed.
Any watch store should have a pin for you and they don't cost much. Good Luck. Bill
Posted on May 29, 2008
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
How do connect the strap to the clasp there is a stem in the middle of it preenting theleather strap from going through
This puzzled me too.
I finally figured out that the the stem is ther to keep the band from falling off if the connecting pins fall out. There is a small **** in the watch side of my watchband that goes over the stem,
Apr 04, 2011 | Stuhrling Emperor Watch
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    The clasp broke from my Fossil watch. Can the
    mcdevito75 here, Without seeing the watch it"s hard to tell, but I would figure the clasp could be repaired, but the cost may equal a new band and clasp. Look for a small watch repair shop in your area and compare repair cost of the clasp with that of a new band.
    Jul 06, 2010 | Fossil Watches
    The pin that holds the latch closed broke. Where May I find parts to repair the clasp.
    You may want to go to somewhere that can repair watches or a jewelery store and they may have a box of junk watch parts and they my be able to replace that part, the buckle or solder it back on if you have the part.
    Dec 04, 2009 | Fossil CH2470 Watch
    I have a silver/gold braided watchband and the clasp keep coming undone. Can I replace the band itself or have the clasp repaired. Marianne Wadle 515-28-50866
    Your watch clasp alignment is off , that's make it lose,, most of the time i able to fix it if not then replace with new one, I hope this info helpful
    from
    Amfix Jewelry & Watch Repair
    203 N. LaSalle Street
    Chicago, IL 60601
    Ph : 312 641 7000
    Email: info@goamfix.com
    Web: www.goamfix.com
    Aug 28, 2009 | Watches
    Missing hinge pins
    You will have to get a complete clasp assembly, which will have to be ordered from the factory that makes that model. If the clasp assembly is not available, A jeweler might have that part or be able to repair it for you.
    Mar 06, 2008 | Field and Stream FE6BI Wrist Watch
    Watches Logo
    188 people viewed this question
    Top Fossil Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you a Fossil Watch Expert? Answer questions, earn points and help others
