Question about Brother 1034D Mechanical Sewing Machine
The blue thread keeps jumping put and i cannot get the machine to sew properly it is the KH 4300 model that i got 3wks ago and have tried every way possible to thread it with no joy help
    Genius:
  • 1,788 Answers
Call your dealer, because there is no Brother model called KH4300. You must have a Silvercrest or something.
Posted on Oct 04, 2010
I need to adjust the bobbin/lower thread tension on my Freesia Viking sewing machine.... Now I know why it was sold. I sew lots... but am at a standstill on how to remove or get to it to adjust it..
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
TROUBLE;UPPER THREAD KEEPS BREAKING;
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
TROUBLE;LOWER THREAD KEEPS BREAKING;
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
TROUBLE;MACHINE STARTED SKIPPING STITCHES;
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
TROUBLE STITCHES SHOWING LOOPS;
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 08, 2011 | Husqvarna Freesia 415
Needle keeps jamming, won't thread
Good day!
Good day!
Jun 07, 2011 | Janome D'cor Excel Pro 5124 Mechanical...
Necchi 535FA--the tension seems to be off. The thread keeps breaking or pulling out of the needle. When i sew on cotton it was working then when I switched to a stretchy faux crushed velvet the tread...
Good day!
Good day!
Jun 06, 2011 | Sewing Machines
My singer curvy 8780 has a timing issue the needle is scraping on the bobbin casement and will not sew,cleaned and oiled, changed needle turned off and on. any suggestions?
Good day!
Good day!
Jun 06, 2011 | Singer Curvy 8770 Electronic Sewing...
Keeps skipping stitches and knots thread
Good day!
Good day!
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
I cannot get the bobbin to wind on my Model 1260 Euro-Pro. It was working fine the last time I used it. Any ideas?
Good day!
Good day!
Jun 05, 2011 | Euro-Pro 1260DX Mechanical Sewing Machine
I have the error message that there is a mechanical problem and the guide says that the machine is stuck??? How would this be repaired?
Good day!
Good day!
Jun 05, 2011 | Feiyue FY100 Computerized Sewing Machine
Husqvarna Model 215: My t-shirt material got jammed. I cut it out and then lifted out the needle, cover plate, bobbin and metal plate over the teeth. Then I took out the casing or whatever it's...
Good day!
Good day!
May 24, 2011 | Husqvarna Huskystar 215 Sewing Machine
Riccor model 939FA thread keeps breaking, not shure if it is threaded correctly, manual lost years ago, thread has been nesting on bottom of material, now just breaking.
Try looking for a manual for your machine here.
http://www.riccar.com/help/manuals/
If your model number isn't listed try looking for a similar model or the number nearest to your machine.
Usually, sewing machines of the same brand thread in the same way. Hope this helps!
Sep 11, 2010 | Riccar R651 Mechanical Sewing Machine
Top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Jun 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Open Questions:
See all Brother 1034D Mechanical Sewing Machine Questions
Brother 1034D Mechanical Sewing Machine Logo
108 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
