Question about Sceptre X20g-Naga III 20.1" LCD Monitor
My monitor has shifted 90 degrees so that the top is now on the eight side. how do i fix it?
    Sergeant:
    Champion:
  • 293 Answers
Press the button menu and select the rotation adjustment.
Posted on Oct 05, 2010
My acer screen is sideways. how do i fix it?
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Apr 11, 2013 | Acer Computers & Internet
I was wiping my keyboard when I accidentally inverted the display of the monitor. How could I revert the display back. Thanks
This actually happens a lot, and it's very tricky but simpleto fix.
Here is a full list of keys that someone on another website sent me for
screen orientation problems, in case it's ever useful.
Ctrl-Alt-Up - right side up
Ctrl-Alt-Right - 90 degrees
Ctrl-Alt-Down - 180 degrees
Ctrl-Alt-Left - 270 degrees
If these don't work you'll have to do it manually,
There is an icon at the bottom of the screen (now maybe the top) for yourgraphics properties. Right Click it
Select--->Graphics Options--->Rotation---> and make sure"normal" is checked
It will be weird with the screen inverted but give it a go.
Hope this helps
RJ
Jul 31, 2011 | Computers & Internet
I need a new battery for my 1986 Oldsmobile ninety-eight regancy sedan. fully loaded. what type of battery would i need?
Attributes Battery BCI # : 75
Battery CA @ 32 Degrees F : 775
Battery CCA @ 0 Degrees F : 630
Battery Height : 7 1/4"
Battery Length : 9 3/4"
Battery Posts Type : Side Post
Battery Reserve Capacity : 90
Battery Voltage : 12 volt
Battery Weight : 33 lbs.
Battery Width : 7"
Wet or Dry : Wet
A lead acid battery with the fallowing specs
group 75
Battery Width : 7"
Wet or Dry : Wet
Battery Width : 7"
Wet or Dry : Wet
Battery BCI # : 75
Battery Width : 7"
Wet or Dry : Wet
Feb 27, 2011 | 1986 Oldsmobile Regency
How do you fix a 90 degree tilted monitor sreen??
Ctrl-Alt-arrow key....try all arrows, one of them will correct it.
Dec 03, 2009 | Northgate 17" LCD Tilt Screen Innovations...
Display off 90 degrees
check the buttons on the front ..there should be one to change that back
May 02, 2009 | Dell E196FP 19-inch Flat Panel Monitor -...
My Computer Screen
My monitor problem is: it's screen display rotate 90 degrees to left, so we can't watch it normally, I can't work with some program (word, excel, and adobe reader, etc) because it's screen dislay isn't at vertical position but falling to left side. How can I fix this problem? Help me please.
Post by: Syukri Datasan
Aug 19, 2008 | Gateway FPD2275W LCD Monitor
Desktop is dispalyed horizontal on monitor
The Ctrl-alt direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation Ctrl-Alt-Up - right side up
(If that doesn’t work, try Ctrl-Shift-R)
May 31, 2008 | Acer X193W LCD Monitor
Monitor
The Ctrl-Alt-Direction key sequence is supposed to be used for changing your workspace. On my computer at work it changes the screen orientation.
This is a feature in Windows XP Tablet PC Edition. Which makes sense. But it looks like ATI Intel copied the keystroke for the same “feature” in their video card drivers. I can’t think of a good reason why I would need an always-on keystroke for this on a desktop PC.
When creating a keystroke-mapped feature that only 1% of your customers will want to use and the other 99%[1] are going to be confused by, put in a menu option to disable it and have it disabled by default.
To fix the issue press Ctrl-Alt-Up. To permanently fix the problem go to:
Start >> Control Panel >> Display >> Settings >> Advanced
Where it is after that it dependent upon your video card.
Mar 31, 2008 | Gateway FPD1975W 19" LCD Monitor
Samsung Monitor image rotates 90 degrees
Use ctrl+alt+ up Arrow key (you can also use use ctrl+alt+ left/right Arrow key)
Good Luck
Mar 27, 2008 | Samsung SyncMaster 240 T 24.1" Flat Panel...
SCREEN TURNED TO LEFT WHEN I HIT KEYBOARD WITH BOOK COVER
1. If you right click on the desktop and look at graphics properties, or something similar to that, then you should get a menu for your display adapter control panel. Usually the screen rotation is right there. Sometimes it's as easy as a CTRL + arrow key combination, but I'd rather see you adjust it from a menu.
2. Ctrl-Alt-Up - right side up
Ctrl-Alt-Left - 270 degrees (If that doesn’t work, try Ctrl-Shift-R)
3. If you have the intel video chipset, I believe pressing CTRL+ALT+ one of the arrow keys should fix your problem.
I think it was ctrl+alt+right, but if that doesn't work, try the other three arrow keys.
However, if that doesn't work (especially if you do not have intel video), then right click on your desktop, go to properties, and go to the advanced tab. There you should find some setting that will allow you to reverse the rotation.
Dec 06, 2007 | Logitech Cordless Desktop EX110
Sceptre X20g-Naga III 20.1" LCD Monitor Logo
43 people viewed this question
Top Sceptre Computers & Internet Experts
Robert Veldman
Robert Veldman
methjd
Are you a Sceptre Computer and Internet Expert? Answer questions, earn points and help others
