Question about Kenmore Dryers
Kenmore dryer no heat - Kenmore Dryers
  • Kenmore Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Check your Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Check the Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Check to make sure you heating problem is not a lint build up in the discharge hose or the dryer,as this condition can cause heater/thermistor problems such as overheating of the heating coil leading to failure of the coil and burnout of the thermostat/thermistor due to overheat.
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside the air duct you will find the heating coil and the thermostats/thermistors. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time by removing the two wires and taping them together with electrical tape or with an ohm meter to test the thermostat/thermistor. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
(Thermal fuse.If it overheats the dryer will not operate. It's located on the blower housing. It cannot be reset. A vent clogged with lint can cause it to overheat. You can test it with an Ohm meter or continuity checker, if no continuity, replace it)
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Right after replacing a dryer element, always run the dryer on 'air fluff' / 'no heat', and go outside to verify there's plenty of air coming out your vent system.
If the vent's clogged, that new element can burn out very quickly.
For further instructions on how to replace the element go to the following website:
davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
This is a FREE answer, Please rate me
Posted on Oct 05, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Where is the heating element for a Kenmore heavy duty 60 series soft heat large capacity?
How to Replace Your Electric Dryer's Heating Element
www.davesrepair.com/DIYhelp/DIYreplacingWPLdryels.htm
How to Replace Your Whirlpool, Kenmore, Roper, or Kitchenaid Electric Dryer's Heating Element. Here's a common job that many folks are afraid of, but it's ...
Whirlpool / Kenmore Dryer Heater and Thermostat Test ...
? 7:40
https://www.youtube.com/watch?v=KZY9CQ_CqvY
Sep 13, 2010 - Uploaded by Bill Newberry
Basic checks for a Whirlpool made dryer. ... Whirlpool & KenmoreDryer Repair - How To Diagnose No Heat ...
Whirlpool - Kenmore - Maytag Dryer Not Heating Repair ...
? 2:42
https://www.youtube.com/watch?v=i95okOr2rOI
Mar 1, 2011 - Uploaded by ApplianceAdvice
It will explain step by step instructions on how to test the thermostats, fuses, and heating element inside the ...
How To Fix Dryer With No Heat ' Dryer Repair - PartSelect
Dec 12, 2015 | Kenmore Dryers
Kenmore Dryer 300 Series No heat , I check continuity to all parts , it ok , but still no heat on dryer What's wrong?
What is the model number?
Exactly which parts did you check?
Also, check the breakers. The breakers are 220 and one of them may have thrown not allowing it to heat but the dryer will run.
Oct 17, 2012 | Kenmore 400 6942 Dryer
My Kenmore dryer will not heat or turnoff. I have
the timer will not advance without heat.the dryer heats up when it reaches temp. the heat shuts off and the timer advances,when the heat comes back on the timer stops,send the model number next time,
Jul 31, 2010 | Kenmore Dryers
Kenmore 70's dryer, not heating,
Maybe timer, try a different heat cycle.
Feb 06, 2010 | Kenmore Dryers
Kenmore Elite HE4 gas dryer, no heat at all
The ignitor may be bad or the thermal fuse may be failed.
Aug 27, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore D433ele will not turn off...will not heat
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jul 31, 2009 | Kenmore 400 6942 Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
