Question about KitchenAid Dishwashers
My KitchenAid KUDS01FLSS0 won't turn on when the "Start" button is pushed. Several months ago it began requiring multiple pushes to get it to start. All the cycle lights on the control panel work when pushed - except the "Start" button. Online & repair parts person suggested I replace the: - Tail Cable Ribbon; did not fix problem, then - - Electronic Control Board (interface) which also did not fix it. Should I replace the Electronic Control Board that is actually the part with the buttons and lights? I just don't think it's a fuse since all the lights on the control panel work, but it just doesn't start . . . Thank you -
BIKER T
  • 909 Answers
SOURCE: Won't start after repair
SUGGEST YOU PULL OUT PLUG THEN OPEN DOOR UNSCREW TOP SECTION OF PANEL TO GAIN ACCESS TO DOOR LIMIT. CAREFULLY BRIDGE BOTH WIRES OUT AND ALSO WITH WATER SWITCHED OFF, SWITCH POWER BACK ON. IF NOTHING STILL, CHECK POWER TO DOOR LIMIT. IF THERE IS POWER, EITHER THERE IS A LOOSE WIRING CONNECTION ON THE BOARD OR IT HAS AGAIN GONE FAULTY.
Posted on Aug 23, 2007
  • 3422 Answers
SOURCE: I have a Maytag QuietSeries
HI,
Just visit this link HERE and your problem will be solved.
Goodluck,
Please don't forget to rate the solution.
Posted on Apr 04, 2008
  • 9 Answers
SOURCE: Lights are on, but wont start
The water pump can hum and still have a defective coil.
Posted on Aug 31, 2008
  • 901 Answers
SOURCE: Flashing lights on Maytag dishwasher
Check whether the door is getting closed fully. Try pushing little hard. If the door close switch problem it may work.
Contact service for help if u can not proceed further with electrical circuits. Micro-controller board to be checked!
Posted on May 19, 2010
MNfisherman
  • 11896 Answers
SOURCE: Hi, I have a KitchenAid Model: KUDP02FRSS1. I
Control panel is the most likely the cause of your problem. A faulty door switch may also cause this.
Posted on Sep 21, 2010
Alarm won't turn off
Turn key to on position, but not start it. Push red button on left of steering wheel twice, then start
Apr 05, 2017 | 2001 Toyota MR2 Spyder
2008 Lexus ES350 won't start after multiple times
You will need the dealer to look at his, diagnosis of this problem takes special equipment and skills.
Oct 22, 2012 | Cars & Trucks
The Whirlpool Dishwasher GU 2400 won't staart
Sometimes I have to push the cancel button on my Kitchenaid and start over and push the selection buttons again. and then push start. Don't know if this will help.
Jan 07, 2012 | Whirlpool Dishwashers
My Kitchenaid dishwasher is acting up. Everything else works but when you push the start button it will not start. model # KUDM01TJBT0
What happens when you try to start ?Do you get any lights blinking?Do your hear any motor turning ?What happens?
Sep 09, 2010 | KitchenAid 24 in. KUDI01IL - Multiple...
Help - dishwasher won't start when I push the start button. It will, however begin drain cycle when I push the cancel/drain button
Here are couple things that might help, let me know if they do or not.
-The door must be closed within 3 seconds of pushing the start button.
-There is a part in the right front corner of the tub that you should be able to see with the lower rack out, it looks like a hat. This is the float, it will not let water enter the machine if it is stuck up, look to see if something has fallen under it. It should move up and down about 1/4" freely.
- Make sure someone has not turned the water off to the dishwasher, the valve is usually under the kitchen sink
If these do not help let me know if you have any blinking lights when you push a button or try to start it.
Apr 25, 2010 | KitchenAid 24 in. KUDI01TJ - Multiple...
Randomly won't start
Change the crank censer
May 30, 2009 | 1995 Subaru Legacy
My 95 legacy just had a problem not moving out of park. I ended up taking the console off and found the little button that is supossed to move when you push on the brake was not moving. With the cover off I can just push it with my finger. There may be a part to replace, I haven't had time to investigate further. I hope this helps. Joe L.
May 18, 2009 | 1995 Subaru Legacy
Dishwashers Logo
82 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
