Question about Malibu ML88TL 88Watt Low Voltage Power Pack with Timer
I have a Model ml 44t, when the temp outside became cooler my timer would not turn on the lights, it would stop rotating at the red post.
Http://www.intermatic.com/~/media/files/intermatic/products/instructions/professional%20lighting/ml44t%20trilingual.ashx
-I think your outdoor plug is connected to GFI plug in bathroom or kitchen >>> check reset on GFI.
-Next, plug your hair dryer into same outdoor plug to see if plug has electricity >>> electrical plugs outside wear out quicker, and get loose wires.
-Move timer cord to the other plug
-I don't know if a bit of WD 40 would help or not .... couldn't hurt to spry some on the pins at this point ...UNPLUG timer because WD is very flammable...
-Tips from manual mention checking for burned out bulbs ... I've seen that mentioned other places and don't know if bulb problems shorten life of low-volt transformer inside the box.
-I worked with timers for years, and never seen replacement clocks or transformers for Malibu-type timers
-Timers located outside get damp and dirty ... these things cause small gears inside timers to oxidize and clog so they don't work after a while ... again, a bit of WD-40 might help
Tips copied from manual:
• Make sure power pack is plugged in. Is outlet working?
• Turn manual ON/OFF switch to "ON" or rotate dial so "ON" tripper passes time line indicator.
• Is lamp burned out? Use another lamp to test.
NOTE: This lighting system is designed to last many years under normal conditions. However, lamps eventually burn out and operating with one lamp out can shorten the life of the others. IT IS IMPORTANT TO REPLACE BURNED OUT LAMPS PROMPTLY.
Conditions beyond your control such as abnormally high household voltage due to poor utility voltage regulation will also affect lamp life.
The timer has 1 year warranty.
Posted on Oct 05, 2010
Refrigerator quit working, power to compartment lights OK
If this is an American model refrigerator I will need to know the model number to see what may be happening. Can you post the model number? Thanks Sea Breeze1_10_2013_2_30_52_am.jpg
Jan 10, 2013 | Refrigerators
Tip
Setting Your Timer
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previ- ous time settings will be cleared from memory.
Program Using "Quick" Method:
2. Move the control lever to the ON position. The Red indicator light will start fashing.
3. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time.
NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will ac- cidentally set a wrong time.
4. Press the dial once to set the present time. The Red indicator light will go off.
5. Rotate the time dial clockwise to the frst desired ON time. The Red light will pulse momentarily with each click.
6. Press the dial once to enter the ON time. The light controlled by the switch timer will turn ON.
7. Rotate the time dial clockwise to the desired OFF time.
8. Press the dial once to enter the OFF time. The light controlled by the switch timer will turn OFF.
Repeat Steps 5-8 for each additional ON/OFF setting. Continue to rotate the time dial until the Red indicator light comes ON and stays ON, indicating that the switch timer is in AUTOMATIC mode
on Oct 06, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Need to set the timer properly. No instructions to follow. Want lights to come on at 6PM and off at 6AM. the timer has red and black pegs on the timer, HEL:P
Experiment with the timer.
Hook up the lights and timer. And read resource link below.
Put the trippers on the dial. Put red at 6pm and black at 6am.
Then manually rotate the dial two revolutions.
Turn the override knob to different setting, and then manually rotate the dial two revolutions.
Watch what the lights do as you rotate timer dial.
Then rotate dial two revolutions until current time lines up with stationary arrowhead located on inner dial.
The clock motor located inside timer rotates the dial, and trippers move small switch that turns lights on-and-off.
More resources with important tips for power pack:
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
http://waterheatertimer.org/How-to-set-timers.html
Sep 27, 2011 | Malibu ML88TL 88Watt Low Voltage Power...
I installed a new Intermatic 200w powerpack with 15 malibu lights using 131 watts. The lights turn on manually, but the timer doesn't work. How is this possible.
More information is needed.
Open following link for Intermatic-Malibu resources:
You say clock doesn't work.
Add a comment with following information:
Do you have timer with analog dial?
Does dial rotate as time passes?
Does dial keep good time?
Have you put the black and red trippers in place?
Are trippers push all the way down?
Have you set current time by rotating clock dial 2 full turns before rotating dial to current time?
Intermatic/Malibu ML series timers come with 5-year warranty.
Product is covered by warranty.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 01, 2011 | Malibu ML200RT - Low Voltage Power Pack...
Timer on malibu transformer ML-44T is turning in reverse for no reason
There are no repair parts for power packs, but they do come with 5 year limited warranty.
http://www.intermatic.com/products/professional%20lighting/light%20expressions/power%20packs/ml44t.aspx
Contact Intermatic:
http://www.intermatic.com/customer%20service.aspx
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on timer or any do-it-yourself project.
Feb 20, 2011 | Intermatic ML44T TRANSFRMR WITH TIMER 44...
How temp. disable this timer, without loosing program
You posted under Paragon 42013-20 240Volt indoor-outdoor mechanical timer.
The 'program' is how you set pins on the dial.
Pins cause electrical switch to turn ON-OFF
http://waterheatertimer.org/Paragon-timers-and-manuals.html#42000
http://waterheatertimer.org/pdf/Paragon-42000-sell-sheet.pdf
For example if you disconnect electricity to this unit.
Clock dial stops rotating, but pins are not changed.
When electricity is connected again, manually rotate clock dial until current time lines up with red pointer.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Jan 27, 2011 | Paragon 42013-20 Timer
We have the intermatic timer Model EJ351 and when I go to set the timer at the beginning it does not flash. It is when I start from off to on. Mary Ann
Mary Ann:
It appears that it will start flashing when you move from off to on. Here are the directions from the web site.
Gary
20 seconds. The red indicator light will go off and any previous
light will start flashing.
dial while turning it. If you press the dial, you will accidentally
set a wrong time.
light will go off.
Rotate the time dial clockwise to the first desired ON time.
AUTOMATIC mode.
Dec 02, 2010 | Solar Intermatic Ej351c Indoor Wall Switch...
My Haier wine cooler (Model BC112G) has stopped working. Prior to it stopping, the pipes in the lower back became caked with ice. Any ideas what might have broken...and how/if it can be fixed?
let the thing totally defrost (24hrs)with the door open then switch it back on as a first step,the ice on the pipes stops the gas from turning from a liquid to a gas...thats how it cools..
Jun 03, 2010 | Haier BC112G Wine Cooler
Just as someone else wrote, I too have the Malibu light timer and have the blue & red pegs set to turn on (red peg) at 7pm and off (black peg) at 11pm. The lights will not automatically turn on...I...
The clock motor has gotten weak and is now overheating, and will soon stop turning. There are no replacement clock motors for ML series power packs.
Open following for Power Pack troubleshoot checklist and warranty information and other tips to keep power pack working longer:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html
Upvote the help.
Nov 09, 2009 | Malibu ML600TW - Low Voltage Power Pack -...
Programming
Use this procedure to manually program ON/OFF settings.
1. Move the control lever to the OFF-CLEAR position for about 20 seconds. The red indicator light will go off and any previous time settings will be cleared from memory.
1. Move the control lever to the ON position. The Red indicator light will start fashing.
2. Rotate the time dial clockwise at least one click, stopping at the half hour nearest to the present time. NOTE: During programming, be careful not to press the dial while turning it. If you press the dial, you will accidentally set a wrong time.
3. Press the dial once to set the present time. The Red indicator light will go off.
4. Rotate the time dial clockwise to the frst desired ON time.
5. The Red light will pulse momentarily with each click.
Sep 26, 2009 | RTO Intermatic Inc Ej351c Timer Night...
Malibu ML88TL 88Watt Low Voltage Power Pack with Timer Logo
235 people viewed this question
Top Malibu Hardware & Accessories Experts
Craig Butler
Craig Butler
Gene Haynes
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
