Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Ice and water dispencer dead, no lights nothing. The rest of the refrig is working fine. model gs6nbexrsoo
  • malibubert Oct 05, 2010
    Problem with the GS6NBEXR Side by Side Refrigerator
    The light is going out when the door is closed. Still the dispencer has no power. No lights or fuctions work on the dispenser
  • Whirlpool Master
  • 3,740 Answers
Power for the this is via the door switch. If the door switch has failed the dispenser will not work. See Item 25 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5165257&diagram_id=1301061#d1301061
Close up / part detail (3 terminal switch)
http://www.appliancepartspros.com/part_details.aspx?part_id=3108668
Try depressing the door switch with the door open and briefly tesing the dispenser. If the switch has failed the light in the freezer will always be on no matter the position of the switch plunger. If the light never goes out.... the dispenser will not work. I.e. bad door switch.
POWER OFF / Unit unpluged
You remove the switch by sliding a thin knife blade on the side of the switch and release the locking tabs and lift away from the inner liner wires attached.. Most have 2 tabs some only have one. This one appears to be on the right side of the plunger.
If you test the door switch and the problem persists / i.e. the light goes out when the plunger of the switch is depressed, just respond here and I will help you.
There is more we can do to troubleshoot.
Thanks for choosing FixYa.
Kelly
Posted on Oct 05, 2010
  • Kelly
    Kelly Oct 05, 2010
    Remove the door switch (Power off) and jumper the Black wire to the blue and black wire. i.e both wires that are not yellow.
    Then check for any dispensor panel lights and test for the water dispensing.
    Just a note about powering off any refrigerator. They need a 10 - 15 min rest period before re-applying power so tht the coolant system will staibilze and allow for compressor re-start.
    If this does not give you power, remove the upper hinge cover of the freezer door and check for any broken wires in that area. The cover canbe removed by placing a regular flat bladed screwdriver on a putty knife (scratch prevention) and then twisting at the edge of the cover to pull the cover OUT and UP on EACH side.
    Keep me posted on progress.
    Kelly
    Genius:
  • 1,478 Answers
With your ice maker not working properly, you might be wondering the reason behind the malfunctioning of your ice maker. Several factors could be involved in case your ice maker is not making any ice at all. It might be caused due to a defect in the water supply line. It could be possible that the water valve isn't getting any water. Check the water line at the back of the freezer for any blockage. Look for the water shut-off valve placed behind the refrigerator or under the sink and turn it off.
Next step would be to unscrew the copper line located at the back of the refrigerator. Now place the copper line in a bucket and turn on the valve to check if pressurized water comes out. The problem could also be linked to a defective tap valve. You could have it replaced. Since, freezer temperature can also be responsible for ice maker malfunctioning, make sure the freezer is not too warm.
Take care.
Posted on Oct 04, 2010
Ice maker and water dispencer don't work
Can be the water valves located on the back of the refrigerator. There are a lot of youtube videos to check the valve and replace them. Good luck.
Jul 03, 2016 | Kenmore Sears Refrigerator Replacement Ice...
Side by side ice maker won't stop letting ice out of dispencer unles you open freezer door
It sounds like a sticking actuator switch. the door light switch shuts off the auger motor when you open the door.
Aug 15, 2014 | Refrigerators
GE frig not cooling, both refrig and freezer. started with ice/water dispenser not working.
WR55X10942 Main Control Board This sounds like motherboard failure. I am not sure what your model number is but that will be important should you have someone to help repair your refrigerator. These problems are common on the Artica Profile Models. I will be here to help you repair if you should choose, Thanks Sea Breeze
Apr 24, 2013 | GE Refrigerators
No water from the Icemaker and Water Dispenser Dual Inlet Valve
if no water is going to both icemaker and water dispencer, check water supply to refrig. into valve.
If ok and valve is being energized by dispencer arm and icemaker, then it's probably a bad water valve
Dec 03, 2011 | Whirlpool Refrigerators
I am getting NO water out of dispenser. The ice works fine. It makes ice and dispences it. The only issue id the water. I have already replaced the 5 button control unit and this has not corrected the...
At the bottom of the freezer door ( remove the kick plate ) , there will be a water line . Follow this line , about 6 " to a connector . Push in on the white ring and pull out the line , at the same time . Activate the water dispensor pad and see if water flows from the line under the refrig . If it does , then the line in the door is frozen . Either raise the freezer temp for several days , so the line in the door will thaw , or , I have heard using an air tank will blow the ice out of the line in the door . If no water comes from the line under the refrig , while activating the pad , then replace the water valve , behind the refrig , the piece the wall water line connects to on the refrig . If the line is frozen in the door , pt # WR49X10173 , is the dispensor water line heater , which comes with installation instructions .
Nov 18, 2009 | General Electric GSH25JSXSS Stainless...
GE REFRIG
Most likely your water control valve for the icemaker side, you can check the ice maker by filling with water and when freezes and if dumps then the water control valve. Part number WR57X10032
Sea Breeze
Aug 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The Jenn Air refrigerator (model JFC2089HEP) has two doors for the refrigerator and a freezer in drawer underneath. Inside the refrigerator unit is a button to pour cool, filtered water. It just stopped...
if your refrig. is still making ice it is not the water servo, or in other words the water inlet. it could be the touch button is corroded or one of the wires came off switch. if the water dispencer works some times and sometimes it dosent, it is the water servo or water inlet valve. this opens and closes the water valve when you press button to get water or when the ice tray needs to be filled up. my g.e. refrig. did the same thing. and this is what it was....hope this helps you......thanks eddy
Jan 03, 2009 | Refrigerators
Sid by side ice dsspencer and water dispencer(all the indicator light suddently are shut off) not working
you could have a problem with your dispenser module. a burnt pcb that could lead to all of your problems. switches not working, lights not working, dispenser not working, etc.
check your dispenser module and if you find a burnt part or a burnt PCB, then replace it.
tnx 4 using fixya,
drcool
Oct 14, 2008 | Frigidaire FRS3R5EMB Side by Side...
Maytag mfd2561 water dispencer and ice maker issues
ther first refrig id have to see for better idea of problem but hte second with the flaps open and closing is going to need a high voltage board part num(12920710)---thats the part number i get wehn i look it up with the model MFI2568AEW. dont know where you got 12002608(that to is a h.v. board. which ever itssan easy enough repair to do yourself, its mounted on the rear of refrig and comes with programming instructions in the box
Mar 12, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
53 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
