Question about Kenmore 65924 Electric Dryer
Elec. dryer Belt is broken. I took the top off to find this. But do not know how to change the belt. What else do I have to take apart?
  • 1,122 Answers
Remove the front panel,find the idler arm wheel,the belt goes under the idler wheel and onto the motor pulley,put back together-mike
Posted on Mar 01, 2009
My belt is broken on my tumble dryer.took it apart and don't know how to put the new belt on
The belt goes around the drum, through the idler pulley onto the pulley on the motor. The idler fastens into several holes on the floor of the dryer.
Sep 29, 2011 | Dryers
My dryer drum will not turn...."how to change your dryer belt"
There are many styles and different models of dryers but the one thing they all have in common is the dryer has a belt that turns the drum.In the procedure below we will show you how to take apart your dryer,change your belt,and show you the correct threading of your belt. Here is a typical Kenmore dryer idler pulley(it has a plastic wheel on it) motor/pulley (the pulley is attached to the backside of the motor) and the belt configuration.Note the picture below.
Each different model dryer also has a different lint trap location. This location will have a bearing on how your dryer is taken apart and how to change your belt.
Note the location of your lint trap and choose the correct video on how to take your dryer apart. There are two different locations,on top,and in the door.
This video will show you how to take apart your dryer and change your belt if the lint trap is on top of your dryer
lint trap on top
This video will show you how to take apart your dryer and change your belt if the lint trap is inside of your door.
lint trap in door
This video will show you how to take your dryer apart and change your belt with the control panel in the front side panel r
control panel in front
This video will show you how to take apart your Maytag L shaped dryer and change your belt.
L shaped dryer
If you happen to run into an issue with your belt and pulley configuration all the diagrams are here click on the link
If this has helped you please consider giving us a 4 thumbs up on our rating.This procedure has saved you a minimum of $125.00
Thanks in Advance and Thank You for using Fixya!
on Mar 21, 2011 | Dryers
How do you put the belt back on? It was making a screeching sound so I took it apart and now cannot figure out to get the belt tight. I have it back on and back together but do not know how to get the...
you have to open back panel of dryer as well as the top. there will be a spring connected to the motor assembly. unlatch it, check your belt to see if it needs to be replaced. if cracked, replace. latch spring and belt should have tension.
Oct 25, 2010 | GE DWSR463EG Electric Dryer
Changing dryer belt on kirkland/whirlpool dryer took apart dryer but dont see where belt suppose to mount.
Hello. The belt goes around the tub and the tension pulley. In fact, it is always a good idea to replace both the belt and the idler/tension pulley at the same time. J.
If you want a schematic go to and enter your model number. J.
Jun 27, 2010 | Whirlpool LER4634J Electric Dryer
the belt is off or broken, changing the belt yourself can be tricky, you must remove the front bulkhead and door/panel assy, then you have to route the belt correctly from th motor to the belt tensioner, you may want to call a tech.
Jan 06, 2010 | Whirlpool LER5636P Electric Dryer
Belt replacement
Take the belt with you to an appliance store and they will match it up. Much like a fan belt on a car. You won't necessarily need the model if you have the belt. Next, it sounds like your assembly is broken. If this assembly looks to be in pieces, you may need a new one.
Feb 03, 2009 | Kenmore 73952 Gas Dryer
Old DANBY elec dryer DCD411 - drum belt snapped
most belts have the length written on or take belt to a good general spares stockist and see if it can ve matched
Aug 31, 2008 | Dryers
DRUM WON't TURN on my Roper Dryer
you can put the back back on, remove the 2 screws under the lint filter( if ones mounted to top of machine ), then the top tips back revealing 2 5/16 screws holding the front panel on. lift off hte panel and string new belt arond drum and hook ove rht e motro pulley , first passing the belt through the idler tension pulley. belt number is a 341241
Mar 12, 2008 | Roper RES7646KQ Electric Dryer
Help me install belt on electric dryer
need model and brand of drier
Dec 30, 2007 | Dryers
Kenmore 65924 Electric Dryer Logo
99 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
