Question about Avanti FF1101W Top Freezer Refrigerator
My Avanti Chest Freeze Model CF98PSS will not freeze the green power light blinks but will not come on I turn the knob and the freezer sounds like its on. whats wrong? I have this for 3yrs
    President:
  • 1,099 Answers
A freezer is great for storing additional food that may not fit in your fridge freezer. If your chest freezer stops working, it's important to be able to troubleshoot it quickly so that food waste is kept to a minimum. Keep the following tips in mind if your chest freezer stops working.
Check the Electricity
If your chest freezer doesn't seem to be working at all, check the outlet that the freezer is plugged into. Unplug the chest freezer from the wall and plug something else in such as a lamp or digital clock. If the new appliance doesn't work either, you know the problem is with your outlet and not your freezer. If the appliance does work, you will need to refer to other troubleshooting methods.
Inspect the Relay
The relay is a component that helps power the compressor. It is housed in a plastic box with the motor terminals and the overload protector and is connected to the Compressor; the relay is the largest component in the box. Closely inspect the relay and make sure it is not burned out. The relay can also be tested using a multimeter. If you see any signs that the relay has shorted out, you'll will need to replace it. If the relay makes a rattling sound when shaken, this is also a sign that it has shorted out.
Examine the Compressor
The compressor is essential to the performance of your chest freezer. It is the motor that powers the entire cooling system and if your freezer has ceased to work, you need to check it. This unit is located at the back of the freezer and sits in plastic housing; it can be identified by its football shape.
You can tell that the compressor is broken if your relay is fine or if you hear a light hum followed by a clicking sound and silence. If your freezer is relatively new, it might still be under warranty and you could get a replacement compressor for free. If not, your compressor will need to be replaced by a professional.
Investigate the Thermostat
The fact that your chest freezer is not working could be down to the thermostat. This is the unit that regulates the temperature inside the freezer. To test your thermostat, remove the access panel on the side of the freezer. Next, use a screwdriver to remove the actual thermostat from the inside wall but do not disconnect the tube that runs from the unit into the freezer.
Set the range scale on Rx1 on your multimeter to test for continuity. If your multi-tester reads continuity, your freezer problem lies in another spot. If your multi-tester does not read continuity, it means your thermostat is not working and you will need to replace it. Remove the tube from the old thermostat and attach it to the new one. Screw the new unit into place on the freezer wall and make sure the tube is not coiled or kinked as this will prevent the new thermostat from working properly.
Hope this help.......
Posted on Oct 04, 2010
  • Brenda Roberts Mar 24, 2012
    Type your comment here...
Hi we have a norfrost chest freezer it is freezing everything but bread on superfreeze when we take it off of superfreeze it defrosted the bread
sounds like the thermostat is at fault or more than likely the refridgerant gas has partially escaped due to a leak, check te seals on the doors first. hope this helps.
Oct 09, 2016 | Freezers
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
I have a Skandiluxe CF 136 chest freezer & the orange (fast freeze) light is on all the time.
The compressor won't burn out just because it's running all the time. The plastic fascia pops out easily from behind(take the little panel off on the side) Set the thermostat to the middle of its range and switch the fast freeze off.
Oct 08, 2015 | Freezers
Fast freeze light on all the time is this right new belling 100 ltr chest freezer
No check your settings. You may try to unplug it for about a minute and then restart. If that doesn't work, call the mfr. they should help since it is new.
Feb 02, 2013 | Magic Chef Chest Freezer MCCF5WBX
My Avanti CF142 chest freezer won't work on normal setting. It will work on Quick freeze so I know the compressor is good. Any ideas why it won't work on normal setting. The green light won&
Sounds like your control switch is going bad. Good thing you have the quick freeze button. You may want to go ahead and replace it. The whole thing will go out soon. This is something you can replace yourself.
Jan 27, 2013 | Avanti 5.3 cu. ft. / 150 liter Chest...
The green lite has gone off on my chest freezer and there is no noise but fast freeze works
Does the noise start when you push fast freeze? It bypasses the thermostat. If the green light is out it may just be the light itself and nothing to worry about. Check power to the freezer!
Dec 28, 2012 | GE Freezers
Why dose the freeze only freeze around the top and not the bottom
Hi, Please check your fan for malfunction. Set the thermostat a little bit colder and observe your freezer.
Nov 05, 2010 | Avanti 3.4 cu. ft. / 96 liter Chest...
THE GREEN POWER LIGHT FLICKERS, AND COOLS ONLY WHEN THE FAST FREEZE POWER BUTTON IS TURNED ON
This sounds like the freezer stat is gone. If it is digital, there may be a power card issue but most chest freezers are run on a standard thermostat with the capillary running up into the base of the unit. Whilst sourcing the part, put a standard socket timer on to the plug to stop the unit running all the time.
Dec 09, 2009 | Magic Chef Chest Freezer MCCF5WBX
Avanti chest freezer cf199 will not freeze. A
Sounds like your freezer has lost its charge of refrigerant. That motor sound is the compressor. And the internal thermal overload is tripping it out every minute because refrigerant also cools the compressor motor. Have a licensed repairman find the leak, seal it,and recharge it with R134a refrigerant.
Nov 19, 2009 | Avanti 7.1 cu. ft. / 201 liter Chest...
Avanti FF1101W Top Freezer Refrigerator Logo
252 people viewed this question
Top Avanti Refrigerators Experts
John Tripp
John Tripp
john h
Are you an Avanti Refrigerator Expert? Answer questions, earn points and help others
